Babyt 4th Gear June 18, 2012 Share June 18, 2012 Is it ok to park with steering wheel not in center position? I was told it is not good to do that? ↡ Advertisement Link to post Share on other sites More sharing options...
MrolexB 1st Gear June 18, 2012 Share June 18, 2012 Is it ok to park with steering wheel not in center position? I was told it is not good to do that? was told when parking in Msia, steer all the way to either left/right. so that car theives cannot tow ur car away ... Link to post Share on other sites More sharing options...
Acemundo Supercharged June 18, 2012 Share June 18, 2012 Is it ok to park with steering wheel not in center position? I was told it is not good to do that? what i heard is not too good because the long period the steering rest on one side creates prolonged pressure on either side of the power steering fluid or hydraulic. Link to post Share on other sites More sharing options...
Donut Supercharged June 18, 2012 Share June 18, 2012 Is it ok to park with steering wheel not in center position? I was told it is not good to do that? Thats what i was being told also. if not centre position, the wheel alignment will go crazy..... But i dont know how true it is. Its just a habit already. i always make sure its dead centre. Link to post Share on other sites More sharing options...
Passion 5th Gear June 18, 2012 Share June 18, 2012 Right and wrong. So many cars in Malaysia also parked head in with tilted steering wheel, nothing happen also. I think it is a myth. But can some expert please advise? Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 18, 2012 Share June 18, 2012 Most power steering are electrical type now. As long as you don't wrangle and wank at the steering wheel when it's parked, I see no harm whether the steering wheel is fully aligned centre or not. Link to post Share on other sites More sharing options...
StefanK Supercharged June 18, 2012 Share June 18, 2012 Most power steering are electrical type now. As long as you don't wrangle and wank at the steering wheel when it's parked, I see no harm whether the steering wheel is fully aligned centre or not. Hmmm... is this a job for Mythbusters or Topgear? Link to post Share on other sites More sharing options...
SimonTan 2nd Gear June 18, 2012 Share June 18, 2012 Technology improvement to electrical steering now. Even so, I guess the hydraulic steering should also have improved on the rubbers seals, etc. It might be true 20years ago....but now? Link to post Share on other sites More sharing options...
Mockngbrd Supersonic June 18, 2012 Share June 18, 2012 of cos not good la.. dun u know... park like that wait ur engine will piang one Link to post Share on other sites More sharing options...
Kingkong 5th Gear June 18, 2012 Share June 18, 2012 Well, the Altis I'm driving requires to turn the steering 45 degree before being able to lock it. If off-center were to cause problem to the steering, guess Toyota won't design it this way then. Anyway, I'm no expert in this area, just sharing my thoughts only. Anyone has better insights please share. Link to post Share on other sites More sharing options...
Gee 1st Gear June 18, 2012 Share June 18, 2012 Parking wheels not centered.. Imho not to the extent of damaging the balance nor alignment, the pressure is insignificant compare to cornering, even at 30kph on particular tire. But safe practices won't hurt either. Link to post Share on other sites More sharing options...
Sosaria Twincharged June 18, 2012 Share June 18, 2012 You can turn the steering wheel slightly to one side to activate the steering lock. Of course, anything to the extreme is no good, so it's probably not a good idea to park with the steering totally locked to one side's limit. Unless you're parking at an extreme slope and turn the steering in a direction to stop the car against the curb, in case the brakes fail. Even when learning to drive and park, the testers penalize you if at the end of the parking maneuver, the wheels are not aligned straight forward. But it's also true that in malaysia you can see lots of cars parked with steering turned to one side, either to counter slope, or to deter thieves. And their cars seem to last longer than ours, so... Link to post Share on other sites More sharing options...
Vegas Turbocharged June 18, 2012 Share June 18, 2012 in Singapore, normally reverse park with wheels straight in msia, always head in corner lot with steering all the way to left or right.... No issues with my alignment so far... Link to post Share on other sites More sharing options...
Acemundo Supercharged June 18, 2012 Share June 18, 2012 Right and wrong. So many cars in Malaysia also parked head in with tilted steering wheel, nothing happen also. I think it is a myth. But can some expert please advise? i think it is more a case of good practice than a myth. also i think cannot just quote the number of cars in malaysia parked with wheels turned to one side as your supporting evidence 1) most of these cars are probably parked for short while so they don't bother. i personally don't bother if i know i am parking one hour at most. also i think the motivation is to prevent car theft 2) even slight left or right is ok for most people who abide by this practice. most people are more mindful of full lock left or right. Link to post Share on other sites More sharing options...
Celicar Turbocharged June 18, 2012 Share June 18, 2012 I don't think it will cause problems. I have read that when parking on slope, a safety precaution is to turn the wheels such that if the handbrakes fails and the car rolls, the wheels will hit the curb and stop the car from moving. Anyway, if really want to talk about balance, how about uneven tyre pressure, uneven wear and tear to suspension etc? You can keep your steering wheel dead centre when at a stop, but so many other things can result in the same 'problems' you are trying to avoid. Link to post Share on other sites More sharing options...
Tjkbeluga 5th Gear June 18, 2012 Share June 18, 2012 Probably as myth as if you PCC too much, you'll become blind? Link to post Share on other sites More sharing options...
Donut Supercharged June 18, 2012 Share June 18, 2012 Probably as myth as if you PCC too much, you'll become blind? can yr reply be more decent? Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 18, 2012 Share June 18, 2012 Is it ok to park with steering wheel not in center position? I was told it is not good to do that? For hydraulic power steering, not center is ok as long as it is not turned to its extreme right or left. Those who have done bleeding on their hydraulic steering will notice that the fluid sprays out from the bleeding nipple at much bigger force at the extreme ends. So even under normal driving it is very damaging to the system if the steering is turned to the extremes. ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Mandai Bird Paradise
Going to Batam. Where to park overnight ?
