Nojoke123 1st Gear November 12, 2012 Share November 12, 2012 Getting a new storage water heater to replace the existing one that is leaking. What is the different between horizontal and vertical model ? ↡ Advertisement Link to post Share on other sites More sharing options...
Mazdaowner Moderator November 12, 2012 Share November 12, 2012 Getting a new storage water heater to replace the existing one that is leaking. What is the different between horizontal and vertical model ? No difference, your available space suited for which, use which one. Link to post Share on other sites More sharing options...
Ysc3 Twincharged October 29, 2015 Share October 29, 2015 Time to change mine... Anyone got lobang for a 25L unit? Right now using Joven JVA25 ... almost 11 years liow. Link to post Share on other sites More sharing options...
Strat 6th Gear October 29, 2015 Share October 29, 2015 for replacement, better to use back the same brand and model in order to use back the existing pipes Link to post Share on other sites More sharing options...
Donut Supercharged October 30, 2015 Share October 30, 2015 Time to change mine... Anyone got lobang for a 25L unit? Right now using Joven JVA25 ... almost 11 years liow. Joven is good mah.... use back the same brand. Link to post Share on other sites More sharing options...
TVT Supercharged October 30, 2015 Share October 30, 2015 Time to change mine... Anyone got lobang for a 25L unit? Right now using Joven JVA25 ... almost 11 years liow. 11 years is very good liao. I use Ariston 15L only last about 5 years.... Link to post Share on other sites More sharing options...
Little_prince Supersonic October 30, 2015 Share October 30, 2015 oT Abit How abt those gas water heater? Is it more worth than electric type? Link to post Share on other sites More sharing options...
Lala81 Hypersonic October 30, 2015 Share October 30, 2015 oT Abit How abt those gas water heater? Is it more worth than electric type? Upfront u incur quite a lot of cost, i don't see how it's economical. The gas water heater is more expensive than the normal storage heater (few years ago, citygas offered the heaters at v low cost to entice people to use). Now i think it's a lot more expensive than a normal 25L storage heater. U have to pay for the city gas connecting the pipes. My sis (PC) just got quoted $500 for connecting the pipes to the hob and the water heater. The upfront cost already wipe out whatever electricity savings u have. And the worry about more pipes for potential gas leakage. mlmlwml. Joven is good mah.... use back the same brand. I'm using joven also. No issues thus far. 2 years on. 2 Link to post Share on other sites More sharing options...
The_Bear Turbocharged October 30, 2015 Share October 30, 2015 Getting a new storage water heater to replace the existing one that is leaking. What is the different between horizontal and vertical model ? The water comes out side-way and it's a bitch. 1 Link to post Share on other sites More sharing options...
Ysc3 Twincharged October 30, 2015 Share October 30, 2015 Upfront u incur quite a lot of cost, i don't see how it's economical. The gas water heater is more expensive than the normal storage heater (few years ago, citygas offered the heaters at v low cost to entice people to use). Now i think it's a lot more expensive than a normal 25L storage heater. U have to pay for the city gas connecting the pipes. My sis (PC) just got quoted $500 for connecting the pipes to the hob and the water heater. The upfront cost already wipe out whatever electricity savings u have. And the worry about more pipes for potential gas leakage. mlmlwml. I'm using joven also. No issues thus far. 2 years on. i wanted to get gas heater in 2005 when SP was giving it out FREE WITH INSTALLATION !! but alas, when i called up to enquire .... i was told my flat go no piped-in gas ... so no freeby for me ... have to stick to elect heaters. 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic October 30, 2015 Share October 30, 2015 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 3, 2016 Share March 3, 2016 (edited) Anyone has experience buying anything from local online retailer - Cost Plus? Unsure if it's reliable, I sent an email enquiring on delivery charge. Reply was fast. Checked. I proceeded to order Ariston storage water heater and cooker hood. Naturally, I chose COD (since this option is available), not keen on accruing points on CC. That was about two weeks before CNY. Delivery didn't happen. I emailed them twice, but totally no response. Luckily, it's COD. Heng arrh. Edited March 3, 2016 by Kangadrool 2 Link to post Share on other sites More sharing options...
Mavwong 2nd Gear March 7, 2016 Share March 7, 2016 If you use Joven, if it's 3KW version. Make sure your installer change the wiring to at least 2.5mm per line best solid core type. Mine didn't change and the wire heat up and short and burn in half a year of usage. Nowadays installer only care about how fast they get their job done. Peng. Link to post Share on other sites More sharing options...
13177 Hypersonic August 4, 2016 Share August 4, 2016 If i replace the current storage heater brand to another new brand, can i use back the piping? Will there be any problem? Link to post Share on other sites More sharing options...
Volvobrick Supersonic August 4, 2016 Share August 4, 2016 Unless exact same model, they will have to change/bend the last bits. Anyway it should be all part of the installation. The expensive cost would be the bracket if the heater does not come with it. My last purchased came with bracket though. I am using Rheem, which should last more than 10 years. Link to post Share on other sites More sharing options...
Loki Supersonic August 4, 2016 Share August 4, 2016 Unless exact same model, they will have to change/bend the last bits. Anyway it should be all part of the installation. The expensive cost would be the bracket if the heater does not come with it. My last purchased came with bracket though. I am using Rheem, which should last more than 10 years. My Rheem was just changed. Lasted 9 year and leaked badly. The guy who replaced it told me that cannnot leave it on for too long. Switch it on, 5 mins, go shower and then quickly switch it off. 1 Link to post Share on other sites More sharing options...
13177 Hypersonic August 5, 2016 Share August 5, 2016 Usually what is the lifespan of a storage water heater? Anyone using Joven storage water heater? Any review on this brand? Link to post Share on other sites More sharing options...
Kb27 Supersonic August 5, 2016 Share August 5, 2016 After Ariston, my Rheem (probably 10 yrs old) died, I looked around and saw Joven and other brands. I took a chance on an unknown "alpha" brand. It's probably 7 yrs old now and still working well. ↡ Advertisement Link to post Share on other sites More sharing options...
Need Advice on Self Storage
Looking for storage space ...
