Kb27 Supersonic March 3, 2013 Share March 3, 2013 Ya, you're right.. But I hv the power magic installed so it would cut off the power before the battery is flat.. So the continuous recording is for a limited time only.. Don't trust power magic too much, especially if you have a small or older battery. You might find yourself looking for jump starts soon enough. ↡ Advertisement Link to post Share on other sites More sharing options...
Titanium 4th Gear March 3, 2013 Share March 3, 2013 I came to this conclusion as well. Images are clearer in the mornings. Get blurry in the afternoon when the weather is hot. I usually park my car in the open. At first I thought have to do with the settings (resolution, ev, freq -50hz 60hz). U also using X7? Those videos recorded after that are blur, think it take few hours to cool down n resume back to normal. Link to post Share on other sites More sharing options...
Nojoke123 1st Gear March 3, 2013 Share March 3, 2013 I came to this conclusion as well. Images are clearer in the mornings. Get blurry in the afternoon when the weather is hot. I usually park my car in the open. At first I thought have to do with the settings (resolution, ev, freq -50hz 60hz). Semiconductors tends to perform better at lower temperature; higher gain, lower noise figure, better sensitivity etc. Link to post Share on other sites More sharing options...
Cymagnus Clutched March 3, 2013 Share March 3, 2013 U also using X7? Those videos recorded after that are blur, think it take few hours to cool down n resume back to normal. Yup. Using X7. It blurred to the extend that I cannot see the car plate number of the cars that were less that one car length in front. Link to post Share on other sites More sharing options...
Nojoke123 1st Gear March 3, 2013 Share March 3, 2013 Yup. Using X7. It blurred to the extend that I cannot see the car plate number of the cars that were less that one car length in front. Install a fan to blow directly at the camera...LOL Link to post Share on other sites More sharing options...
Extremme 4th Gear March 3, 2013 Share March 3, 2013 I read in a few forums, even those better ones like Blackvue has overheating problem (ie blurred vision under the hot sun). I guess so far those really good ones like Itronics does not have such issue. "Yi fen jia qian, yi fen huo" Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 3, 2013 Share March 3, 2013 Don't trust power magic too much, especially if you have a small or older battery. You might find yourself looking for jump starts soon enough. Your power magic failed on you bro? I normally don't let the car cam run overnight to drain the car batt.. The power magic is just in case.. But thanks for the heads-up.. Link to post Share on other sites More sharing options...
Kb27 Supersonic March 4, 2013 Share March 4, 2013 Your power magic failed on you bro? I normally don't let the car cam run overnight to drain the car batt.. The power magic is just in case.. But thanks for the heads-up.. I don't have power magic, but I was called upon to provide jump starts for a few people. They always tell me "but it will auto-cut off.." The problem may be the cut off is too late for their battery to have enough juice to turn the motor over in the morning. Link to post Share on other sites More sharing options...
Titanium 4th Gear March 4, 2013 Share March 4, 2013 Yup. Using X7. It blurred to the extend that I cannot see the car plate number of the cars that were less that one car length in front. Same here and it takes an hour or more to resume back. Link to post Share on other sites More sharing options...
Titanium 4th Gear March 4, 2013 Share March 4, 2013 I read in a few forums, even those better ones like Blackvue has overheating problem (ie blurred vision under the hot sun). I guess so far those really good ones like Itronics does not have such issue. "Yi fen jia qian, yi fen huo" Ya, read about it too. Ok la, I under shade most of the time so not much an issue for me la. Link to post Share on other sites More sharing options...
Titanium 4th Gear March 4, 2013 Share March 4, 2013 I don't have power magic, but I was called upon to provide jump starts for a few people. They always tell me "but it will auto-cut off.." The problem may be the cut off is too late for their battery to have enough juice to turn the motor over in the morning. What your number bro! Next time i also call u to jump start for me ok? Link to post Share on other sites More sharing options...
macrosszero Turbocharged March 4, 2013 Share March 4, 2013 Whatever camera you buy, do check your camera's recordings every now and then. Don't wait till after an accident and you *need* the recording, then discover that your camera was a dud....... Link to post Share on other sites More sharing options...
Extremme 4th Gear March 4, 2013 Share March 4, 2013 Ya, read about it too. Ok la, I under shade most of the time so not much an issue for me la. me too Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 4, 2013 Share March 4, 2013 I don't have power magic, but I was called upon to provide jump starts for a few people. They always tell me "but it will auto-cut off.." The problem may be the cut off is too late for their battery to have enough juice to turn the motor over in the morning. Haha.. Ya.. true.. depends on the cut-off voltage setting.. mine is 11.8V if I not wrong.. But i wont try it la.. later cannot start then gotta call AA liao... haha ... Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 4, 2013 Share March 4, 2013 Whatever camera you buy, do check your camera's recordings every now and then. Don't wait till after an accident and you *need* the recording, then discover that your camera was a dud....... Ya.. true.. so need to do some SDCard housekeeping once in a while.. check and then format the card sometimes.. the only nuisance for me is that I cannot view the AVi files directly on my HU via the USB, bec my HU cannot read the files AVI version (think is encoded in MJpeg).. Link to post Share on other sites More sharing options...
Titanium 4th Gear March 4, 2013 Share March 4, 2013 (edited) Ya.. true.. so need to do some SDCard housekeeping once in a while.. check and then format the card sometimes.. the only nuisance for me is that I cannot view the AVi files directly on my HU via the USB, bec my HU cannot read the files AVI version (think is encoded in MJpeg).. Ya lo ya lo... I thinking of getting a iPad connection kit so that i can read the MicroSD card using my iPad2. alternative is to use Android Tablet lo. Edited March 4, 2013 by Titanium Link to post Share on other sites More sharing options...
Titanium 4th Gear March 5, 2013 Share March 5, 2013 I playback some of the video and noticed some blurriness on the left... Link to post Share on other sites More sharing options...
Lurpsexx 6th Gear March 5, 2013 Share March 5, 2013 I playback some of the video and noticed some blurriness on the left... Same here bro.. My middle n right side clearer while left end blur.. Can't see licence plate.. Think us the fish eye lens ba.. ↡ Advertisement Link to post Share on other sites More sharing options...
Petrol Discounts in Singapore
Roti Prata lover? Anyone?
Step aside Labubu, and let welcome Kodak
Cheapest Road Tax for sub 5 second 0-100
