Obscurest 1st Gear May 21, 2013 Share May 21, 2013 Folks, I need some advises on what brand to go for as all along I'm using top loading and now wana switch to front loading. I know there is no such thing as reliable thus just some feedback on ur current brand front loading washer and dryer like reliability or if you have a choice will you choose other brand or anything to look out for... Seems like nowadays a lot of Korean and jap brand machine is 2-in-1 washer cum dryer... No one has used this before and any issues? Thks. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic May 22, 2013 Share May 22, 2013 Must it be front loading? Link to post Share on other sites More sharing options...
Ingenius Turbocharged May 22, 2013 Share May 22, 2013 Whenever i see this kind of pictures with small children in precarious positions, i get very worried. 1 Link to post Share on other sites More sharing options...
Thedream 3rd Gear May 22, 2013 Share May 22, 2013 i'm of the opinion that those with electronic displays and buttons are much less reliable than those with just knobs and switches (like the one in the picture above). In any case, it should be good to get the extended warranty. 1 Link to post Share on other sites More sharing options...
13177 Hypersonic May 22, 2013 Share May 22, 2013 I also plan to replace my current washing machine, although no spoilt but have been using for over 10 years. Wonder which brand to get? 1 Link to post Share on other sites More sharing options...
RadX Moderator May 22, 2013 Share May 22, 2013 I gonna be kind here n not taje action In the archives here, if u search there was a lengthy discussion on this with all the sifus giving inputs Pls search n u will be enlightened Link to post Share on other sites More sharing options...
VellfireS 4th Gear May 22, 2013 Share May 22, 2013 I gonna be kind here n not taje action In the archives here, if u search there was a lengthy discussion on this with all the sifus giving inputs Pls search n u will be enlightened wow.. boss.. tio 4D ah? Link to post Share on other sites More sharing options...
RadX Moderator May 22, 2013 Share May 22, 2013 wow.. boss.. tio 4D ah? Today I kind Tmr one kind No la this one long ago no discuss but is here in one of threads Be kind to animal Link to post Share on other sites More sharing options...
Genes 6th Gear May 22, 2013 Share May 22, 2013 Folks, I need some advises on what brand to go for as all along I'm using top loading and now wana switch to front loading. I know there is no such thing as reliable thus just some feedback on ur current brand front loading washer and dryer like reliability or if you have a choice will you choose other brand or anything to look out for... Seems like nowadays a lot of Korean and jap brand machine is 2-in-1 washer cum dryer... No one has used this before and any issues? Thks. Currently using Bosch washer/dryer. So far so good. Washes clean, and not too noisy to my ears. Electrolux is another good brand to consider. If u have deeper pockets, get a Miele washer dryer combo. Hearsay super reliable Link to post Share on other sites More sharing options...
Silver_blade Turbocharged May 22, 2013 Share May 22, 2013 My experience with washer/dryer combi hasn't been good so far. I have 3 such machines in the past 8yrs. They were Bosch, LG and Samsung. All had some kind of electronic problems that caused water not able to be drained or not able to dry, etc... Maybe just my luck. All the problem can be repaired and probably cheaper than to replace, but some of the parts take up to 3 weeks to arrive. So I chose to buy replacements. I have since switched back to 1 washer, 1 dryer. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 22, 2013 Share May 22, 2013 (edited) For dryer, just get a simple knob one will do. No need any fancy stuff like anti-crease, etc. Set the time you want and half/full power, that's it. Been using the Electrolux one for 4 years Liao, no issue at all. It does what it is suppose to do - dry clothes. Now I think 300+ only. Dryer got 2 types, venting and condensing. Venting need a hose to push out the hot air, condensing no need. Edited May 22, 2013 by Fcw75 Link to post Share on other sites More sharing options...
Silver_blade Turbocharged May 22, 2013 Share May 22, 2013 Currently using Bosch washer/dryer. So far so good. Washes clean, and not too noisy to my ears. Electrolux is another good brand to consider. If u have deeper pockets, get a Miele washer dryer combo. Hearsay super reliable Bosch is the best among the 3 brands I had. Feel solid and quiet. Link to post Share on other sites More sharing options...
Newdrive 1st Gear May 22, 2013 Share May 22, 2013 front loading washing machine from what i research before buying for my mum (was using top loading previously), saves more water. Link to post Share on other sites More sharing options...
Paddie 3rd Gear May 22, 2013 Share May 22, 2013 Would not recommend you to get a combined washer/dryer, unless you intend to use it only as a washer and only have the dryer function as a standby for very occasional use. If you use both the washing and drying functions, it can take 3-4 hours for the complete cycle. The drying is also a lot less efficient than a normal dryer. If you are someone who uses the dryer regularly, or even once a week, I would highly suggest you get a normal front load washer and stack a dryer on top of it. Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 22, 2013 Share May 22, 2013 (edited) I also plan to replace my current washing machine, although no spoilt but have been using for over 10 years. Wonder which brand to get? 10 years no spoil? Which brand are you using? I would use the same brand again. Edited May 22, 2013 by Jamesc Link to post Share on other sites More sharing options...
Ingenius Turbocharged May 22, 2013 Share May 22, 2013 (edited) 10 years no spoil? Which brand are you using? because he hardly use it la. Edited May 22, 2013 by Ingenius Link to post Share on other sites More sharing options...
Knighthunter 4th Gear May 22, 2013 Share May 22, 2013 (edited) My electrolux washing machine and dryer now is passing 8th year, no major problems except the dryer motor capacitor blew one time after replacement it work again until now. I think chosing washing machine is not critical but dryer buy good one and get those with dryness sensor, it will save a lot in electricity, running dryer is ain't cheap especially those models with timer base. Edited May 22, 2013 by Knighthunter Link to post Share on other sites More sharing options...
Cpcsscc Neutral Newbie May 22, 2013 Share May 22, 2013 I have just changed my washer/dryer too. Using Brandt (from France). Washer is a bit noisy compared to my previous Jap National brand top loading one. But so far ok as long as can wash my clothes clean. Heard front loading is more water-saving than top load. ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Anybody bought those portable car washer
Dish washer really earn a decent pay!
WORX Hydroshot Portable Power Cleaner
Looking for window cleaning machine or equipment
Rinai Gas Tumble Clothes Dryer
Air blower/dryer
Air blower/dryer
