Viceroymenthol 6th Gear September 15, 2013 Share September 15, 2013 Hi bros, as you know, when car gets older and cat becomes dirty, the exhaust flow also less efficient and results in lower power and higher fuel consumption. What do you guys do then, short of buying a newer car or changing to a new LEGAL cat? ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 15, 2013 Share September 15, 2013 Hi bros, as you know, when car gets older and cat becomes dirty, the exhaust flow also less efficient and results in lower power and higher fuel consumption. What do you guys do then, short of buying a newer car or changing to a new LEGAL cat? No need to change...do an "Italian Tune Up" will do...Off the A/C.. find a empty road...used max 2nd gear...pull the revs to 5500rpm..hold there for 2-3 km...Lim Chu Kang Rd the best...or go M'sia NSHW...to run. Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 15, 2013 Share September 15, 2013 No need to change...do an "Italian Tune Up" will do...Off the A/C.. find a empty road...used max 2nd gear...pull the revs to 5500rpm..hold there for 2-3 km...Lim Chu Kang Rd the best...or go M'sia NSHW...to run. Like that the autotrans up lorry 1st before the cat. ... Link to post Share on other sites More sharing options...
Solar Turbocharged September 15, 2013 Share September 15, 2013 oh.. first thoughts after reading your subject is to clean the 'insides' of the cat until gim gim kut kut & got nothing inside Link to post Share on other sites More sharing options...
Solar Turbocharged September 15, 2013 Share September 15, 2013 Like that the autotrans up lorry 1st before the cat. ... shouldn't be. these are within operational range... it don't go beyond redline nor jerking down the tranny abruptly. imo this is aka 'clearing carbon' is actually good for the car. Link to post Share on other sites More sharing options...
Yuan 6th Gear September 15, 2013 Share September 15, 2013 Hi bros, as you know, when car gets older and cat becomes dirty, the exhaust flow also less efficient and results in lower power and higher fuel consumption. What do you guys do then, short of buying a newer car or changing to a new LEGAL cat? Maybe I can learn something new here because I have not cleaned the cat before. I either drive hard on NSHW or I drive locally for long distance. Most of my cars lasted more than 150,000 km within the first 4 years and I do not have any problem or issue with my cat. Link to post Share on other sites More sharing options...
Watwheels Supersonic September 15, 2013 Share September 15, 2013 Hi bros, as you know, when car gets older and cat becomes dirty, the exhaust flow also less efficient and results in lower power and higher fuel consumption. What do you guys do then, short of buying a newer car or changing to a new LEGAL cat? Dun mind post the link on where you get this info. As the name of the device suggests I only know the function of it is to convert harmful exhaust gases to harmless gases. Even with that info I'm sceptical. LoL... Coz it's not that efficient in conversion of the gases until it's properly warmed up. So I'm very curious as to how you get your info. Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear September 15, 2013 Author Share September 15, 2013 http://m.dummies.com/how-to/content/how-to...converters.html Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear September 15, 2013 Author Share September 15, 2013 http://auto.howstuffworks.com/question4822.htm Link to post Share on other sites More sharing options...
Divers 2nd Gear September 15, 2013 Share September 15, 2013 Hi bros, as you know, when car gets older and cat becomes dirty, the exhaust flow also less efficient and results in lower power and higher fuel consumption. What do you guys do then, short of buying a newer car or changing to a new LEGAL cat? Bro, Go do carbon cleaning. Heard many reviews. Quite good. FC up and restore power. Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 15, 2013 Share September 15, 2013 Like that the autotrans up lorry 1st before the cat. ... Har,Gearbox so weak.?1st time heard.!I did this so many times...no problem..just 2-3 km...not 20-30 km. Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 15, 2013 Share September 15, 2013 Bro, Go do carbon cleaning. Heard many reviews. Quite good. FC up and restore power. Good for 3000km..after that back to a square one. Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 18, 2013 Share September 18, 2013 Good for 3000km..after that back to a square one. no choice as in SG, too much city driving Link to post Share on other sites More sharing options...
okayenergy April 25, 2018 Share April 25, 2018 Yes,do carbon cleaning to maintain the work of catalytic converter Here is best way to cleaning cat,engine without dismantling(http://www.okayenergy.com/industry-news/catalytic-converter-cleaner.html) Link to post Share on other sites More sharing options...
Evillusion Supersonic April 25, 2018 Share April 25, 2018 Yes,do carbon cleaning to maintain the work of catalytic converter Here is best way to cleaning cat,engine without dismantling(http://www.okayenergy.com/industry-news/catalytic-converter-cleaner.html) okay........if drop by tonite can do? Which one is better? Pakistan or Iraq branch? 1 Link to post Share on other sites More sharing options...
okayenergy April 25, 2018 Share April 25, 2018 okay........if drop by tonite can do? Which one is better? Pakistan or Iraq branch? Hey,Where are you now? Maybe it is better to tell us your contact so can check and arrange for you. okay........if drop by tonite can do? Which one is better? Pakistan or Iraq branch? Hey,Where are you now? Maybe it is better to tell us your contact so can check and arrange for you. Link to post Share on other sites More sharing options...
Evillusion Supersonic April 25, 2018 Share April 25, 2018 Hey,Where are you now? Maybe it is better to tell us your contact so can check and arrange for you. Hey,Where are you now? Maybe it is better to tell us your contact so can check and arrange for you. thanks........but no thanks. Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged April 25, 2018 Share April 25, 2018 Lol ↡ Advertisement Link to post Share on other sites More sharing options...
Car carpet cleaning
Car carpet cleaning
Roomba - Vacuum Cleaning Robot (VCR)
Interior Cleaning
Interior Cleaning
What's Your Come Home SOP during COVID?
DIY cleaning throttle body
Throttle body cleaning
