Furrynadz 5th Gear July 10, 2015 Share July 10, 2015 (edited) what is the original manufacturer offset for the rim. 9" i believe its too wide for a 225/40/18. stand corrected... 225 is 8 inch rim on 8.5 is stretch on 9 is epic Currently looking at 18" 9jj offset 32 rims, Can it fit 225/40/18 tyres? Any safety concern? Cornering ok? TIA corner hard ur tyre sidewall might come out the rim its a like a pot belly uncle wearing a small shirt exposing his beer belly to the little chicks Edited July 10, 2015 by Furrynadz ↡ Advertisement Link to post Share on other sites More sharing options...
Dieselord 2nd Gear July 11, 2015 Share July 11, 2015 Thks all bros for advice.. Will look for 8jj rims instead.. Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 11, 2015 Share July 11, 2015 Thks all bros for advice.. Will look for 8jj rims instead.. 225/40/18 accept 7.5 to 8.5 8.0 to be is optimum can share you car you drive? see some boy racer running on over wide rim I really scare and not sure is the shop or WS who sold and install the oversize (width) aware that it carry a risk as mention from above especially fast cornering. Link to post Share on other sites More sharing options...
Dieselord 2nd Gear July 11, 2015 Share July 11, 2015 I'm driving lancer Ex.. Looking for rims tt flush with car... Understand offset 35 will flush... But saw ppl selling e rims tt i enquire.. Tt y ask e qns.. Link to post Share on other sites More sharing options...
Dieselord 2nd Gear July 12, 2015 Share July 12, 2015 Nw saw another rims, 8.5j et 31..haha I Know 8.5 optimum for 225/40.. But is still ok, right?? For my car, heard ppl says flush is 35.. Will et 31 fail e inspection? TIA again... Link to post Share on other sites More sharing options...
Roberttan 5th Gear July 13, 2015 Share July 13, 2015 Nw saw another rims, 8.5j et 31..haha I Know 8.5 optimum for 225/40.. But is still ok, right?? For my car, heard ppl says flush is 35.. Will et 31 fail e inspection? TIA again.. anything not Original is against the Rule and regulations in Singapore But LTA has given some room for after market replacement But is has to be International certified. your tyre size is fine for this case ,but the rim ( 7.5 to 8.5) optimum is 8inch. Offset is more flush with those ard 30?. is correct. under the Guide line your tyre shouldn't protrude out your fender, otherwise you will be FINE or Fail inspection Link to post Share on other sites More sharing options...
Dieselord 2nd Gear July 13, 2015 Share July 13, 2015 anything not Original is against the Rule and regulations in Singapore But LTA has given some room for after market replacement But is has to be International certified. your tyre size is fine for this case ,but the rim ( 7.5 to 8.5) optimum is 8inch. Offset is more flush with those ard 30?. is correct. under the Guide line your tyre shouldn't protrude out your fender, otherwise you will be FINE or Fail inspection Thks bro for advice.. :) Link to post Share on other sites More sharing options...
tiresonline Neutral Newbie June 6, 2017 Share June 6, 2017 I completely agree with you, tires are the only element between road and your vehicle, so compromising on this factor is not a good idea. One should make a regular check on their tires; it is must for the safety purpose. Apart from that you can easily save some extra amount if you regularly check your tires. [:)] Link to post Share on other sites More sharing options...
clarkdaniel January 9, 2018 Share January 9, 2018 Ithing after 6000 km after check you tires condication. 1) vehicle alignment 2) vehicle balancing 1 Link to post Share on other sites More sharing options...
Yymail22 2nd Gear March 16, 2018 Share March 16, 2018 Hi. It was when my car was parked with front wheels steered to max that I discovered the inner edge of both tyres have severely worn. Is this the result of front wheels not properly toed-in or -out (alignment)? Or due to damaged part(s) of suspension/wheel assembly etc? Appreciate your advice/opinion/input. Link to post Share on other sites More sharing options...
Fitvip Supersonic March 16, 2018 Share March 16, 2018 Hi. It was when my car was parked with front wheels steered to max that I discovered the inner edge of both tyres have severely worn. Is this the result of front wheels not properly toed-in or -out (alignment)? Or due to damaged part(s) of suspension/wheel assembly etc? Appreciate your advice/opinion/input. Imho, it looks like toed-out! Link to post Share on other sites More sharing options...
Optramagnum 6th Gear March 16, 2018 Share March 16, 2018 Hi. It was when my car was parked with front wheels steered to max that I discovered the inner edge of both tyres have severely worn. Is this the result of front wheels not properly toed-in or -out (alignment)? Or due to damaged part(s) of suspension/wheel assembly etc? Appreciate your advice/opinion/input. Looks like it's toe out. Anyway your tyres need replacement. The groove depth is almost flush with the depth indicator. Probably, after you replaced with new tyres, go for alignment also. If they are different shops, show this pic to the alignment shop. Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 17, 2018 Share March 17, 2018 Hi. It was when my car was parked with front wheels steered to max that I discovered the inner edge of both tyres have severely worn. Is this the result of front wheels not properly toed-in or -out (alignment)? Or due to damaged part(s) of suspension/wheel assembly etc? Appreciate your advice/opinion/input. below are the possible caused Wheel alignment out Loose joint damaged front suspension system aggressive wheel off set any expert can share ? Link to post Share on other sites More sharing options...
Yymail22 2nd Gear March 17, 2018 Share March 17, 2018 Thank you to all who have advised. I personally think it is mis-alignment because the wear is uniform and occur at both front tires. If it is suspension system, the wear would have been uneven all around the surface. As for joint worn out, I have no clue how it will affect the (type of) wear. Any recommendation on specialists doing wheel alignment? Thank you again for your input. Link to post Share on other sites More sharing options...
Ysc3 Twincharged March 19, 2018 Share March 19, 2018 (edited) deleted Edited March 19, 2018 by Ysc3 Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 20, 2018 Share March 20, 2018 Thank you to all who have advised. I personally think it is mis-alignment because the wear is uniform and occur at both front tires. If it is suspension system, the wear would have been uneven all around the surface. As for joint worn out, I have no clue how it will affect the (type of) wear. Any recommendation on specialists doing wheel alignment? Thank you again for your input. just to further share my views Suspension system failure can not just caused uneven wear all round but also wearing on 1 side particularly inner part of your tire due to worn suspension mounting etc Worn joint like can also caused such problem because of loose joint became toe out which can not corrected by Alignment job. An workshop expert will able to tell you more when your car is with him Link to post Share on other sites More sharing options...
Yymail22 2nd Gear March 22, 2018 Share March 22, 2018 just to further share my views Suspension system failure can not just caused uneven wear all round but also wearing on 1 side particularly inner part of your tire due to worn suspension mounting etc Worn joint like can also caused such problem because of loose joint became toe out which can not corrected by Alignment job. An workshop expert will able to tell you more when your car is with him Thanks. I will find a day to visit a workshop. I am also wondering: if the suspension on one side is at fault, will it cause both front wheels to have similar and same degree of wear (on the inner edge)? Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 22, 2018 Share March 22, 2018 Thanks. I will find a day to visit a workshop. I am also wondering: if the suspension on one side is at fault, will it cause both front wheels to have similar and same degree of wear (on the inner edge)? Suspension fail on one side means either the arms broke or shock absorbers leaked with no pressure. tyres wears depends on which components broke down ↡ Advertisement 1 Link to post Share on other sites More sharing options...
This is Why You Should NOT Fit OE Tires To Your Car!
What tires for SUV?
What tires for SUV?
Tread Depth
Tread Depth
Dunlop SP Sport LEMANS LM705
Used Truck / tractor tires.
How close to wear indicators before changing tires?
Checking notifications
