Checking up your tires
Ihave10cats
what is the original manufacturer offset for the rim.
9" i believe its too wide for a 225/40/18.
stand corrected...
225 is 8 inch rim
on 8.5 is stretch on 9 is epic
Currently looking at 18" 9jj offset 32 rims,
Can it fit 225/40/18 tyres?
Any safety concern?
Cornering ok?
TIA
corner hard ur tyre sidewall might come out the rim
its a like a pot belly uncle wearing a small shirt exposing his beer belly to the little chicks
Edited by Furrynadz
Thks all bros for advice..
Will look for 8jj rims instead..
225/40/18 accept 7.5 to 8.5 8.0 to be is optimum
can share you car you drive?
see some boy racer running on over wide rim I really scare and not sure is the shop or WS who sold and install the oversize (width) aware that it carry a risk as mention from above especially fast cornering.
I'm driving lancer Ex..
Looking for rims tt flush with car... Understand offset 35 will flush... But saw ppl selling e rims tt i enquire.. Tt y ask e qns..
Nw saw another rims, 8.5j et 31..haha
I Know 8.5 optimum for 225/40.. But is still ok, right??
For my car, heard ppl says flush is 35.. Will et 31 fail e inspection?
TIA again...
TIA again..
anything not Original is against the Rule and regulations in Singapore
But LTA has given some room for after market replacement But is has to be International certified.
your tyre size is fine for this case ,but the rim ( 7.5 to 8.5) optimum is 8inch.
Offset is more flush with those ard 30?. is correct.
under the Guide line your tyre shouldn't protrude out your fender, otherwise you will be FINE or Fail inspection
Thks bro for advice.. :)
I completely agree with you, tires are the only element between road and your vehicle, so compromising on this factor is not a good idea. One should make a regular check on their tires; it is must for the safety purpose. Apart from that you can easily save some extra amount if you regularly check your tires. [:)] [:)]
Hi.
It was when my car was parked with front wheels steered to max that I discovered the inner edge of both tyres have severely worn.
Is this the result of front wheels not properly toed-in or -out (alignment)?
Or due to damaged part(s) of suspension/wheel assembly etc?
Appreciate your advice/opinion/input.
Hi.
Imho, it looks like toed-out!
Hi.
Looks like it's toe out. Anyway your tyres need replacement. The groove depth is almost flush with the depth indicator. Probably, after you replaced with new tyres, go for alignment also. If they are different shops, show this pic to the alignment shop.
Hi.
below are the possible caused
Wheel alignment out
Loose joint
damaged front suspension system
aggressive  wheel off set
any expert can share ?
Thank you to all who have advised.
I personally think it is mis-alignment because the wear is uniform and occur at both front tires. If it is suspension system, the wear would have been uneven all around the surface.
As for joint worn out, I have no clue how it will affect the (type of) wear.
Any recommendation on specialists doing wheel alignment?
Thank you again for your input.
just to further share my views
Suspension system failure can not just caused uneven wear all round but also wearing on 1 side particularly inner part of your tire due to worn suspension mounting etc
Worn joint like can also caused such problem because of loose joint became toe out which can not corrected by Alignment job.
An workshop expert will able to tell you more  when your car is with him
Thanks. I will find a day to visit a workshop.
I am also wondering: if the suspension on one side is at fault, will it cause both front wheels to have similar and same degree of wear (on the inner edge)?
Suspension fail on one side means either the arms broke or shock absorbers leaked with no pressure. tyres wears depends on which components broke down
