Keithchue 5th Gear August 6, 2014 Share August 6, 2014 dear guys, asking on behalf of friend. she got a fit, 2006 model, having problems with ignition coil. was told to replace all 4 rear ignition coils. due to budget constraints. would like to just replace the faulty one, any recommendations to how about doing this ↡ Advertisement Link to post Share on other sites More sharing options...
Kangadrool Supersonic August 6, 2014 Share August 6, 2014 highly recommend to replace all in one shot as old coils are well...... oil coils. It's not expensive if you buy your own parts and can be easily DIY for most cars. Link to post Share on other sites More sharing options...
TVT Supercharged August 6, 2014 Share August 6, 2014 Like this: http://troubleshootmyvehicle.com/honda/1.7L/how-to-test-the-ignition-coils-1 Link to post Share on other sites More sharing options...
Sorrow 2nd Gear August 6, 2014 Share August 6, 2014 Just addon, what's the average costs per coil as there seems to be various prices for igntion coil ranging from 40 per pack of 4 (searched thru old thread) and costing 1XX per coil? Link to post Share on other sites More sharing options...
Keithchue 5th Gear August 6, 2014 Author Share August 6, 2014 thian seng charges 90 per coil.. friend Honda fit had 8 of them, to be change individually. so it is quite ex... Like this: http://troubleshootmyvehicle.com/honda/1.7L/how-to-test-the-ignition-coils-1 where can I get some mechanic to test the coils out? any recommendations? Link to post Share on other sites More sharing options...
Sorrow 2nd Gear August 6, 2014 Share August 6, 2014 thian seng charges 90 per coil.. friend Honda fit had 8 of them, to be change individually. so it is quite ex... where can I get some mechanic to test the coils out? any recommendations? I see, I rememebr seeing P69 coils pack of 4 If I dun recall wrongly think 60 bucks thus the qns. Wondering why such a big disparity 8 coils sweatz Link to post Share on other sites More sharing options...
Vega Turbocharged August 6, 2014 Share August 6, 2014 If can diagnose which cylinder misfire, just change the coil for that cylinder. But most of the time, if one coil starts to fail, the rest will follow. Better to change all at one go. Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 6, 2014 Share August 6, 2014 (edited) Faulty Coil-ON-Plug can be easily detected with a laser tachometer. Run the engine, and target the laser on each coil and take not of the RPM. The one with low or no RPM is not performing as normal and need to be replaced. Edited August 6, 2014 by Yeobh Link to post Share on other sites More sharing options...
Kspchew 2nd Gear August 6, 2014 Share August 6, 2014 Would suggest to replace all at once to save some labour cost. The rest would fail one by one after replacement of the bad coil. I did the same for my old car, replace only the faulty one, then the other two failed and I got left stranded on the road. And if your friend still insist, you can try Autosavers at Toh Guan (look for Ah Boon) or Autosavers at Woodlands (look for Ah Ming). Link to post Share on other sites More sharing options...
Fastfive1 5th Gear August 6, 2014 Share August 6, 2014 Serious? A Honda Fit has 8 coils? I thought it should only have 4? Can try this. http://www.ebay.com/itm/Set-of-4-07-08-Honda-Fit-Ignition-Coil-B2871-4-on-Plug-Coils-Pack-30520PWC003-/130893082172?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AHonda%7CModel%3AFit&hash=item1e79d5ee3c&vxp=mtr Link to post Share on other sites More sharing options...
Kangadrool Supersonic August 6, 2014 Share August 6, 2014 The older DSI engine has 2 spark plugs per cyliner. Serious? A Honda Fit has 8 coils? I thought it should only have 4? Can try this. http://www.ebay.com/itm/Set-of-4-07-08-Honda-Fit-Ignition-Coil-B2871-4-on-Plug-Coils-Pack-30520PWC003-/130893082172?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AHonda%7CModel%3AFit&hash=item1e79d5ee3c&vxp=mtr Link to post Share on other sites More sharing options...
TVT Supercharged August 6, 2014 Share August 6, 2014 where can I get some mechanic to test the coils out? any recommendations? Sorry, this I dun know. The older DSI engine has 2 spark plugs per cyliner. 2 sparks per cylinder means more powerful engine ?? Link to post Share on other sites More sharing options...
Kangadrool Supersonic August 6, 2014 Share August 6, 2014 This I fully agree - change all. Just like spark plugs, you MUST always change all. Some picky people even insists that all plugs must be of the same batch coming out from the same carton box. If can diagnose which cylinder misfire, just change the coil for that cylinder. But most of the time, if one coil starts to fail, the rest will follow. Better to change all at one go. Link to post Share on other sites More sharing options...
Fastfive1 5th Gear August 6, 2014 Share August 6, 2014 The older DSI engine has 2 spark plugs per cyliner. That's interesting. Link to post Share on other sites More sharing options...
Keithchue 5th Gear August 6, 2014 Author Share August 6, 2014 The older DSI engine has 2 spark plugs per cyliner. ya, 2 spark plugs per cylinder, 4 in front with 4 coils, and 4 behind with another 4 coils.. damn sweat to replace the plugs, now to replace the coils, Sorry, this I dun know. 2 sparks per cylinder means more powerful engine ?? according to gurus, it is more fuel saving and more power should you want it.. it can out accelerate from start from my twin charged jetta, despite 1.3l NA, Honda rocks.. Link to post Share on other sites More sharing options...
Vega Turbocharged August 6, 2014 Share August 6, 2014 ya, 2 spark plugs per cylinder, 4 in front with 4 coils, and 4 behind with another 4 coils.. damn sweat to replace the plugs, now to replace the coils, according to gurus, it is more fuel saving and more power should you want it.. it can out accelerate from start from my twin charged jetta, despite 1.3l NA, Honda rocks.. the first 30m maybe but after that, your twin charged will tear the i-dsi into pieces. seriously, a lot of workshops don't like to change spark plugs for the i-dsi engines as it is very troublesome...... Link to post Share on other sites More sharing options...
Keithchue 5th Gear August 6, 2014 Author Share August 6, 2014 the first 30m maybe but after that, your twin charged will tear the i-dsi into pieces. seriously, a lot of workshops don't like to change spark plugs for the i-dsi engines as it is very troublesome...... ya, but it sucks....to see a small Honda in front of u..haha ↡ Advertisement Link to post Share on other sites More sharing options...
hello
hello
hello
hello
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Class 4 Driving License
testing again
testing again
test
test
