Osiris 1st Gear September 28, 2016 Share September 28, 2016 actually was thinking to leave the spare tyre at home and put a tyre repair/inflation kit in the boot instead... wonder how many KG's this saves though but guess about 15kg-20kg or more (rim + tyre)? Someone I know was rear ended in a vios with spare taken out. From the accident pictures It became a hatch. ↡ Advertisement Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear September 29, 2016 Share September 29, 2016 well, from past exp waiting 4 hrs in the cold in uk... , it is better to have the spare tyre, the repair kit can only handle minor repair such as nail etc, if it is a major blow out, only option would be tow truck or tyre replacement truck.. true and can imagine waiting 1-2 hrs under hot sun in Singapore . Someone I know was rear ended in a vios with spare taken out. From the accident pictures It became a hatch. isn't the chassis part of the frame behind the rear bumper? the impact with the Vios sounds serious, or Vios has a big 'crumble zone'. I was rear ended by a cargo truck on expressway last time . Only the rear gate portion of my SUV was damaged. Everything else including brake lights were ok. Link to post Share on other sites More sharing options...
Osiris 1st Gear September 29, 2016 Share September 29, 2016 Hatch back have reinforced rear. My previous stream was rear ended at around 70kmh. The damage is very slight to the exterior. But there are internal reinforced parts that has to be replaced. I don't know what they are called. I don't know much about vios. I drive to Malaysia so the spare stays Link to post Share on other sites More sharing options...
Notitwain Clutched September 29, 2016 Share September 29, 2016 Any altis owners here bypassed your audio unit so as to enable viewing of video and usage of GPS even when the vehicle is moving? If so, able to advise cost and workshop? Link to post Share on other sites More sharing options...
Kklee 6th Gear September 30, 2016 Author Share September 30, 2016 What is your speed for good fuel efficiency? I believe mine is about 80km/h. Link to post Share on other sites More sharing options...
Sglanevo 2nd Gear September 30, 2016 Share September 30, 2016 for safety and stabilty. pls install bars. can go basic setup with UR bar in SG or Msia. me mix with UR and TRD front Tower Bar frm Borneo motor. 3pt Lower strut bar and rear Anti roll bar frm UR. out altis comes with Stock rear Torsion bar. gng to change soon. ordering TRD torsion frm USA. be safe bros. Link to post Share on other sites More sharing options...
Deschua55 Neutral Newbie October 3, 2016 Share October 3, 2016 Hi all, driving an Altis bought in Oct 2015. Wanna ask if anyone is able to connect Samsung Galaxy S7 to the stock HU? I've tried Miracast/MirrorLink, with iAuto installed on my phone, still doesn't work. Anyone has any advice? TIA! :) Link to post Share on other sites More sharing options...
Osiris 1st Gear October 3, 2016 Share October 3, 2016 (edited) Using s7 also can't connect Got "fail to connect" Will ask during servicing Edited October 3, 2016 by Osiris Link to post Share on other sites More sharing options...
Altis2016 1st Gear October 4, 2016 Share October 4, 2016 If I remember correct, it was mentioned that mirroring can only be done thru cable. Link to post Share on other sites More sharing options...
Altis2016 1st Gear October 4, 2016 Share October 4, 2016 What is your speed for good fuel efficiency? I believe mine is about 80km/h. Not really sure. I assume it is between 70 - 90. When I travel along a relatively smooth traffic road @ 70, sometime the car FC can increase by .1 On a relatively smooth traffic local highway, i find it better when it is below 100. Link to post Share on other sites More sharing options...
Deschua55 Neutral Newbie October 4, 2016 Share October 4, 2016 If I remember correct, it was mentioned that mirroring can only be done thru cable. OIC... you mean USB or HDMI-MHL cable...? Link to post Share on other sites More sharing options...
Altis2016 1st Gear October 4, 2016 Share October 4, 2016 HDMI-mhl bro. If I am not wrong, it was mentioned in the Manuel. Link to post Share on other sites More sharing options...
Osiris 1st Gear October 4, 2016 Share October 4, 2016 (edited) For those not using the other key. You can set to battery saving mode Press unlock 2x while holding the lock button. Red color indicator will blink 4x Cancel by pressing any key when yo u want to use I usually swap key after every 10k service If I remember correct, it was mentioned that mirroring can only be done thru cable.Checked the manual. It say go to wifi select start Miracast Miracast by definition should be wireless Mirrorlink otoh uses cables like usb Edited October 5, 2016 by Osiris 1 Link to post Share on other sites More sharing options...
Chongsf 1st Gear October 5, 2016 Share October 5, 2016 For those not using the other key. You can set to battery saving mode Press unlock 2x while holding the lock button. Red color indicator will blink 4x Cancel by pressing any key when yo u want to use I usually swap key after every 10k service Checked the manual. It say go to wifi select start Miracast Miracast by definition should be wireless The other key has a metal tag with number on it. Do not lose it. Link to post Share on other sites More sharing options...
Osiris 1st Gear October 5, 2016 Share October 5, 2016 The other key has a metal tag with number on it. Do not lose it.For non smart entry ok. For smart entry, just take a picture and saved in on cloud. Eg Google doc Link to post Share on other sites More sharing options...
AltisOwner Turbocharged October 5, 2016 Share October 5, 2016 For those not using the other key. You can set to battery saving mode Press unlock 2x while holding the lock button. Red color indicator will blink 4x Cancel by pressing any key when yo u want to use Thanks, I tested and it work. Link to post Share on other sites More sharing options...
Sglanevo 2nd Gear October 7, 2016 Share October 7, 2016 Thanks, I tested and it work.i did it when i read the user manual. but choose to remove the battery instead. juz in case, the battery leaks and dmg the circuits. Link to post Share on other sites More sharing options...
Jermel Neutral Newbie October 9, 2016 Share October 9, 2016 Hi guys, i came across this forum when researching abt altis. Will be collecting mine at the end of the month. Do guide me along as it is my 1st time getting a ride. Can i still join the whatapp grp? ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Land Cruiser Mini
Toyota bZ4X (2026) Part 2
2022 Toyota bZ4X
2022 Toyota bZ4X
