ER-3682 Supersonic July 28, 2021 Share July 28, 2021 3 minutes ago, Didu said: Yes, a brand new ride. Anyway,all Start/Stop System can be off with a Button,buy a Car you like. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
sake Twincharged July 28, 2021 Share July 28, 2021 7 hours ago, Didu said: Agree. I just need a simple point A to B car without ASS complexity. What current models are available on the market that are ASS-less? Lexus IS300 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 28, 2021 Share July 28, 2021 10 hours ago, Didu said: really? Attrage has no idle stop? Thanks bro. Attrage shall be my next ride then. Make sure you consider properly before you buy the Attrage...it is not very good. Link to post Share on other sites More sharing options...
Didu Turbocharged July 29, 2021 Share July 29, 2021 19 hours ago, ER-3682 said: Anyway,all Start/Stop System can be off with a Button,buy a Car you like. I'll press button to disable idle stop every time on my current car. I really hate it. Link to post Share on other sites More sharing options...
Didu Turbocharged July 29, 2021 Share July 29, 2021 8 hours ago, ER-3682 said: Make sure you consider properly before you buy the Attrage...it is not very good. Please share.....ehhh which part no good leh? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 29, 2021 Share July 29, 2021 (edited) 13 minutes ago, Didu said: Please share.....ehhh which part no good leh? The drive. 🤣 It’s just a point A to point B car. Don’t expect any driving pleasure. Edited July 29, 2021 by Fcw75 1 Link to post Share on other sites More sharing options...
Didu Turbocharged July 29, 2021 Share July 29, 2021 1 hour ago, Fcw75 said: The drive. 🤣 It’s just a point A to point B car. Don’t expect any driving pleasure. I tell you a secret. My OC uses the car more than me. Btw, I read somewhere mild hybrid also have no idle stop feature. Does that mean 2021 Mazda 3 is a viable option for me? 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 29, 2021 Share July 29, 2021 2 minutes ago, Didu said: I tell you a secret. My OC uses the car more than me. Btw, I read somewhere mild hybrid also have no idle stop feature. Does that mean 2021 Mazda 3 is a viable option for me? Mild hybrid should have idle stop feature. Otherwise, it is pointless. 1 Link to post Share on other sites More sharing options...
Xers007 Supercharged July 29, 2021 Share July 29, 2021 6 minutes ago, Didu said: I tell you a secret. My OC uses the car more than me. Btw, I read somewhere mild hybrid also have no idle stop feature. Does that mean 2021 Mazda 3 is a viable option for me? she use the car more than you but you hate to press that button more than her.... 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic July 29, 2021 Share July 29, 2021 8 minutes ago, Didu said: I tell you a secret. My OC uses the car more than me. Btw, I read somewhere mild hybrid also have no idle stop feature. Does that mean 2021 Mazda 3 is a viable option for me? Some (all?) mild hybrid even turn off the engine during cruising. And they can cruise a long way several hundred metres or more) with the engine totally shut down. Not sure about M3. 1 Link to post Share on other sites More sharing options...
Didu Turbocharged July 29, 2021 Share July 29, 2021 37 minutes ago, Volvobrick said: Some (all?) mild hybrid even turn off the engine during cruising. And they can cruise a long way several hundred metres or more) with the engine totally shut down. Not sure about M3. In that case, mild cars are not for me. Link to post Share on other sites More sharing options...
Didu Turbocharged July 29, 2021 Share July 29, 2021 40 minutes ago, Xers007 said: she use the car more than you but you hate to press that button more than her.... This proves there's no such thing as a secret in the forum. 😂 1 Link to post Share on other sites More sharing options...
RachelKim 1st Gear July 29, 2021 Share July 29, 2021 I actually like the start-stop function on my Mazda 3 M-hybrid. With M-hybrid i feel it work better than those without. The start stop is smoother, barely any noise and delay when restarting from stop. Maybe the psychological effect that it helps to save a bit fuel works for me. For M-hybrid there is also a bit of regen braking build in to recharge the tiny M-hybrid batt that powers electronics within (No sure if AC power is included). Link to post Share on other sites More sharing options...
Atlantis80 1st Gear July 31, 2021 Share July 31, 2021 On 7/29/2021 at 4:08 PM, Didu said: I'll press button to disable idle stop every time on my current car. I really hate it. I press the off button switch to disable it too. Haha. ASS is bad for engine mounts 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic July 31, 2021 Share July 31, 2021 I think mild hybrid does not need a starter motor. The electric motor is used to move the car from stand still until the car is moving and then the ICE takes over. So you don't get the noise and shudder on engine start up. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 31, 2021 Share July 31, 2021 I think many isnt aware the alternator car makers are using has more functions now. It actually takes over the function as a starter motor (starter-motor still there to do what it does) when the start stop is activated eg. when the lights turn green and the brake pedal is released. And it also has a regen function when the car is slowing or braking to recharge the lead acid battery(non hybrid cars) or the hybrid battery. For my current car the crank pulley is powering only 2 things via the serpentine belt, the aircon compressor and the alternator....that's it. Even the water pump has gone electric. For older cars the water pump used to be a mechanical pulley run by the serpentine belt that draws power from the crank pulley. Same for the power steering hydraulic system. All these parts have been converted to be powered by electricity. Due to more car parts relying on electrical power eg. parts I mentioned above, dashboard used to be analog rather than a screen that runs on electric power, safety sensing sh!t all running on eletric power...that the mild hybrid system has become a necessity. So when your new type of alternator goes up lorry it will cost you a bomb to replace it. 2 Link to post Share on other sites More sharing options...
Didu Turbocharged August 1, 2021 Share August 1, 2021 21 hours ago, Watwheels said: I think many isnt aware the alternator car makers are using has more functions now. It actually takes over the function as a starter motor (starter-motor still there to do what it does) when the start stop is activated eg. when the lights turn green and the brake pedal is released. And it also has a regen function when the car is slowing or braking to recharge the lead acid battery(non hybrid cars) or the hybrid battery. For my current car the crank pulley is powering only 2 things via the serpentine belt, the aircon compressor and the alternator....that's it. Even the water pump has gone electric. For older cars the water pump used to be a mechanical pulley run by the serpentine belt that draws power from the crank pulley. Same for the power steering hydraulic system. All these parts have been converted to be powered by electricity. Due to more car parts relying on electrical power eg. parts I mentioned above, dashboard used to be analog rather than a screen that runs on electric power, safety sensing sh!t all running on eletric power...that the mild hybrid system has become a necessity. So when your new type of alternator goes up lorry it will cost you a bomb to replace it. For luxury models, buyers are more concern about features, comfort and performance, than maintenance cost. So maybe the manufacturers can justify designing it that way. However, I feel that following such design trend is not going to help the bread-and-butter models in the long run where consumers are more concern with running cost. Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 1, 2021 Share August 1, 2021 21 hours ago, Watwheels said: I think many isnt aware the alternator car makers are using has more functions now. It actually takes over the function as a starter motor (starter-motor still there to do what it does) when the start stop is activated eg. when the lights turn green and the brake pedal is released. And it also has a regen function when the car is slowing or braking to recharge the lead acid battery(non hybrid cars) or the hybrid battery. For my current car the crank pulley is powering only 2 things via the serpentine belt, the aircon compressor and the alternator....that's it. Even the water pump has gone electric. For older cars the water pump used to be a mechanical pulley run by the serpentine belt that draws power from the crank pulley. Same for the power steering hydraulic system. All these parts have been converted to be powered by electricity. Due to more car parts relying on electrical power eg. parts I mentioned above, dashboard used to be analog rather than a screen that runs on electric power, safety sensing sh!t all running on eletric power...that the mild hybrid system has become a necessity. So when your new type of alternator goes up lorry it will cost you a bomb to replace it. By then, car would have been changed. ↡ Advertisement Link to post Share on other sites More sharing options...
Rich people's lifestyles
To be Happy, start thinking about Death!
Discriminatory practices towards the aged
The 2017 Alfa Romeo Giulia
Man who removed bus stop bench to check its dimensions for f
Stop False Accusation
