Red_ryder 1st Gear January 12, 2016 Share January 12, 2016 My 10 year old car has a lot of scratches around the door handle area, probably caused by fingernails. I'm changing car this year so I was wondering how to avoid that again. Nowadays I heard there is a nano-coating treatment that forms a protective layer around the paint. Is that enough to protect against these kind of scratches, or still need to install the transparent laminate film? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Heman75 Supercharged January 12, 2016 Share January 12, 2016 My 10 year old car has a lot of scratches around the door handle area, probably caused by fingernails. I'm changing car this year so I was wondering how to avoid that again. Nowadays I heard there is a nano-coating treatment that forms a protective layer around the paint. Is that enough to protect against these kind of scratches, or still need to install the transparent laminate film? The answer is no... i have nano coat on my new car from AD. you will still get scratches. they are not as hard as u think. they just make your washing easier that is all. the best option is wrap your car. but it is only a car sure will have scratches some where so dont get too up tight 4 Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 12, 2016 Share January 12, 2016 cut your nails. 5 Link to post Share on other sites More sharing options...
Mr_b20 6th Gear January 12, 2016 Share January 12, 2016 speechless... 1 Link to post Share on other sites More sharing options...
RH1667 Hypersonic January 12, 2016 Share January 12, 2016 (edited) cut your nails. Edited January 12, 2016 by RH1667 2 Link to post Share on other sites More sharing options...
Forte3737 5th Gear January 12, 2016 Share January 12, 2016 Dun waste money. All those 9h hardness are gimmicks. Link to post Share on other sites More sharing options...
Kangadrool Supersonic January 12, 2016 Share January 12, 2016 de-nails or wear gloves. 6 Link to post Share on other sites More sharing options...
13177 Hypersonic January 12, 2016 Share January 12, 2016 Best option is to wear gloves whenever you open your car door to avoid scratches. Lol. 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic January 12, 2016 Share January 12, 2016 de-nails or wear gloves. White gloves right? Macam in high end boutiques lol 2 Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 12, 2016 Share January 12, 2016 scaly wear those cycling type with fingers sticking out, still kana scratch. Link to post Share on other sites More sharing options...
Red_ryder 1st Gear January 12, 2016 Author Share January 12, 2016 All joking aside, maybe because my car is black so the scratches are very obvious. They are behind the door handle, in the cup area. You guys don't have this? Link to post Share on other sites More sharing options...
Forte3737 5th Gear January 12, 2016 Share January 12, 2016 All joking aside, maybe because my car is black so the scratches are very obvious. They are behind the door handle, in the cup area. You guys don't have this?Whatever it is,more will appear. If you dun believe, you can try those glass coating. Only waste money. Cheapest is buy super resin Polish Link to post Share on other sites More sharing options...
Opel17 6th Gear January 12, 2016 Share January 12, 2016 All joking aside, maybe because my car is black so the scratches are very obvious. They are behind the door handle, in the cup area. You guys don't have this? Apply a thin layer of transparent nail varnish to the door handle recessed portion. Alternatively, spray a layer of those transparent lacquer which is commonly used for PCB board. Link to post Share on other sites More sharing options...
Count-Bracula Twincharged January 12, 2016 Share January 12, 2016 cut your nails. wear gloves . . and a mask like Kato! My car also have lots of scratches around the door handles but can be removed by those swirl/scratch removal cream. No problem. 1 Link to post Share on other sites More sharing options...
Angcheek Hypersonic January 12, 2016 Share January 12, 2016 cut your nails. cut your wording .... 1 1 Link to post Share on other sites More sharing options...
Mercury1 Turbocharged January 12, 2016 Share January 12, 2016 You can buy the film specific for door handle areas (think its 3M brand) but only states have. Have to buy from ebay and bring in. You can also consider door edge laminates if you fear paint chipping off at the edge Link to post Share on other sites More sharing options...
Forte3737 5th Gear January 12, 2016 Share January 12, 2016 Let's say you manage to protect the door handle area. Then come the door dents. How to protect further? Link to post Share on other sites More sharing options...
Maddriver 4th Gear January 12, 2016 Share January 12, 2016 My 10 year old car has a lot of scratches around the door handle area, probably caused by fingernails. I'm changing car this year so I was wondering how to avoid that again. Nowadays I heard there is a nano-coating treatment that forms a protective layer around the paint. Is that enough to protect against these kind of scratches, or still need to install the transparent laminate film? Actually you don't need to worry about those finger nails scratches at the door handles..Get a polish and you can easily polish them off. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Battery for Honda Vezel
Talking Point >>> Is your CPF enough for retirement?
Takata airbag recall
