marciateng Neutral Newbie January 18, 2020 Share January 18, 2020 I used to visit Gary's. Until I found out that they fitted used parts on my car. They are cheap for a reason. Anyway, it was a bad experience owning a Volvo. ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 18, 2020 Share January 18, 2020 1 hour ago, marciateng said: I used to visit Gary's. Until I found out that they fitted used parts on my car. They are cheap for a reason. Anyway, it was a bad experience owning a Volvo. Do say more. What model you were referring to and the experience you had. Link to post Share on other sites More sharing options...
marciateng Neutral Newbie January 19, 2020 Share January 19, 2020 21 hours ago, Hamburger said: Do say more. What model you were referring to and the experience you had. I had all kinds of problems on my S60. Gearbox, engine oil leak, radiator leak, coolant mix with engine oil etc It was one after another. Gary's using used parts was a bad choice- the parts don't last. In the end, someone recommended me to Alan's United. Saw quite a few Volvo there. However, I gave up on the car shortly after. 2 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic January 19, 2020 Share January 19, 2020 The newer 2.0 4-banger engine? Aisin gearbox should last. Or it's the Ford dual clutch box? 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 19, 2020 Share January 19, 2020 Maybe a T2 or T4? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie February 18, 2020 Share February 18, 2020 Hi all. Driving a 2016 S60 D4. Does anyone know what's the viscosity of engine oil used? No info on local Volvo website. Egyptian Volvo says 0W 20. Thanks in advance. Cheers! Link to post Share on other sites More sharing options...
Newbie26 Hypersonic February 18, 2020 Share February 18, 2020 On 1/19/2020 at 10:33 PM, marciateng said: I had all kinds of problems on my S60. Gearbox, engine oil leak, radiator leak, coolant mix with engine oil etc It was one after another. Gary's using used parts was a bad choice- the parts don't last. In the end, someone recommended me to Alan's United. Saw quite a few Volvo there. However, I gave up on the car shortly after. Sometimes a bit of heng sway had s60 petrol before, never had any problems except battery died once many general workshops can service volvo nowadays, using used parts charged at new part rates is not acceptable very hard for most to verify especially when they send a photo of the new part 3 Link to post Share on other sites More sharing options...
Sparcoray Clutched March 30, 2020 Share March 30, 2020 Current Volvo S60 Owner, I do recommend MTE (https://m.facebook.com/mtetune/) for their knowledge in Volvo or any makes of cars. Arrange an appointment to go diagnose the issues and get it solve before things get worst that leads to higher cost of repair. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic March 30, 2020 Share March 30, 2020 MTE expensive boh? Now economy going to collapse, better find cheap cheap WS. Link to post Share on other sites More sharing options...
Sparcoray Clutched March 30, 2020 Share March 30, 2020 1 hour ago, Volvobrick said: MTE expensive boh? Now economy going to collapse, better find cheap cheap WS. Contact them to give you a quote. I’m just another customer Link to post Share on other sites More sharing options...
Carpediem Neutral Newbie July 25, 2020 Share July 25, 2020 Any of the gurus here know where to locate maintenance plans for Volvo? I have problem locating mine ('15 S60 D4). Previously it is provided in the owners manual but now there's nothing.. Wearnes also quite secretive about it.. 🙄 TIA! Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 25, 2020 Share July 25, 2020 https://www.google.com.sg/amp/www.volvohowto.com/volvo-service-plans/amp/ 1 Link to post Share on other sites More sharing options...
Carpediem Neutral Newbie July 25, 2020 Share July 25, 2020 1 hour ago, mersaylee said: https://www.google.com.sg/amp/www.volvohowto.com/volvo-service-plans/amp/ Thanks alot @mersaylee! I found this also but found it hard to believe the timing belt etc are to be done only at 240k.. So i went and ask a few workshop, they told me like petrol car, all major servicing at 100k. 🤨 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 25, 2020 Share July 25, 2020 13 minutes ago, Carpediem said: Thanks alot @mersaylee! I found this also but found it hard to believe the timing belt etc are to be done only at 240k.. So i went and ask a few workshop, they told me like petrol car, all major servicing at 100k. 🤨 Same with gearbox oil, timing belt better to do it at 120k if not 100k for piece of mind. Link to post Share on other sites More sharing options...
Carpediem Neutral Newbie July 25, 2020 Share July 25, 2020 1 hour ago, mersaylee said: Same with gearbox oil, timing belt better to do it at 120k if not 100k for piece of mind. Got it. Thanks! Link to post Share on other sites More sharing options...
Beregond Supersonic July 25, 2020 Share July 25, 2020 1 hour ago, Carpediem said: Thanks alot @mersaylee! I found this also but found it hard to believe the timing belt etc are to be done only at 240k.. So i went and ask a few workshop, they told me like petrol car, all major servicing at 100k. 🤨 I dun know about volvo. But my toyota commerical timing belt replacement is set computerise. When the mileage reach to replace it will prompt. Dun know if volvo have that function Link to post Share on other sites More sharing options...
A320Skipper Neutral Newbie August 17, 2020 Share August 17, 2020 I’m quite keen on one of the previous generation Volvos like the V40 or S60, but I do have concerns about the availability of spare parts for these cars given that Volvos are not very common in Singapore and the world, and they are no longer in production. For those in the know, are parts typically hard to find for less common cars down the road? Link to post Share on other sites More sharing options...
Volvobrick Hypersonic August 17, 2020 Share August 17, 2020 16 minutes ago, A320Skipper said: I’m quite keen on one of the previous generation Volvos like the V40 or S60, but I do have concerns about the availability of spare parts for these cars given that Volvos are not very common in Singapore and the world, and they are no longer in production. For those in the know, are parts typically hard to find for less common cars down the road? Stockist at sin ming Unico. Or buy off the internet. Plenty of choices from eBay to Aliexpress or specialist sites. ↡ Advertisement Link to post Share on other sites More sharing options...
2026 Volvo EX60 BEV
2026 Volvo EX60 BEV
Are station wagons making a come back with sedans fading?
Where to get Workshop Manual
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
