Neutrino Supercharged January 1, 2019 Share January 1, 2019 thats the reason i ended the fibre termination point at my door and ran my modem so that the wifi signal will run straight to my son's and daughter's room. My room i used cable broadband as the signal from the ont needs to turn more than 90° which i dont think is possible. My hdb layout...... maybe this top managements pips need a mil just like yours.......will open up their mind to all possibilities.... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 1, 2019 Share January 1, 2019 No ethernet cable port on my laptop and no HDMI port on my small Dell XPS laptop Can I connect to router to my laptop using a USB 3.0 cable and will that give a high download rate. Just want to check the speed. Oh, using USB cable I am not sure. Have to see what experts here say. 2 Link to post Share on other sites More sharing options...
Neutrino Supercharged January 1, 2019 Share January 1, 2019 (edited) i still using a desktop to watch youtube and surf internet..... Edited January 1, 2019 by Neutrino Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 1, 2019 Share January 1, 2019 Maybe the 9 pins monitor cable...hahaha. Just joking... Link to post Share on other sites More sharing options...
Evillusion Supersonic January 1, 2019 Share January 1, 2019 What cabling do you use from your desktop to the TV in your room??? BTW I have been trying to 'cast' or mirror from my desktop and laptop to my TVs. No luck. Computers and TVs 3 years or less old. Dunno why got problem. Anyone have success at this and can give tips?? i using the normal rgb cable for the audio and the 15 pin vga for the video.... 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 1, 2019 Share January 1, 2019 Yesterday went to a friend house. Yes, the white trunking they used to connect from ONT to STB is unsightly. My HDB was ready in 1999. Whole unit got unsightly white trunking. Thanks to these trunking, it was ez to connect from ONT to STB. Link to post Share on other sites More sharing options...
Neutrino Supercharged January 1, 2019 Share January 1, 2019 (edited) This is because Starhub management didn't do any thinking. If they chose a STB with a wireless adapter like those android boxes then you don't need to put the ugly trunking to your bedroom. Its amazing how dumb people in top management can be. Some people have 2 or 3 set top boxes in their homes can you imagine how much ugly trucking they will have from their living room? Maybe Starhub can try getting smarter people in top management. We've all got TV and FM radio points in every room of our HDBs and the cabling to them is hidden. Why didn't Starhub make the transition from fibre termination point in the cupboard outside our flats to the normal cabling also outside in the cupboards.which connects to the TV and FM radio points in each room. All that cabling is already hidden. My HDB was ready in 1999. Whole unit got unsightly white trunking. Thanks to these trunking, it was ez to connect from ONT to STB. Our HDB completed in 2011. I asked the reno to put draw wire in the false ceiling. Also got Air Con trunking in each room and through walls. So Starhub contractors used ceiling draw wire and a/c trunking for fibre connections. No unsightly new trunking. Edited January 1, 2019 by Neutrino Link to post Share on other sites More sharing options...
Zxcvb Turbocharged January 3, 2019 Share January 3, 2019 We've all got TV and FM radio points in every room of our HDBs and the cabling to them is hidden. Why didn't Starhub make the transition from fibre termination point in the cupboard outside our flats to the normal cabling also outside in the cupboards.which connects to the TV and FM radio points in each room. All that cabling is already hidden. Those old TV FM radio points are using coaxial cables, which are obsolete in today's high tech speed. They cannot meet current speed data transfer for your internet and HD/UHD/4K/8K TV. Even a CAT5 ethernet lan cable is faster than the coaxial cable. Now is CAT6, even faster. Fibre optics is still the current leader, but due to cost, LAN cable is use to connect up the rest of the house. 1 Link to post Share on other sites More sharing options...
Neutrino Supercharged January 3, 2019 Share January 3, 2019 Those old TV FM radio points are using coaxial cables, which are obsolete in today's high tech speed. They cannot meet current speed data transfer for your internet and HD/UHD/4K/8K TV. Even a CAT5 ethernet lan cable is faster than the coaxial cable. Now is CAT6, even faster. Fibre optics is still the current leader, but due to cost, LAN cable is use to connect up the rest of the house. Thanks for that. But my 1 Gb fibre connection gives me 280Mbps at best and 90 Mbps at second best. Why not give customers who don't want any knew trunking around their properties if they don't mind a slower speed which might well be not that much slower than what they now get with the new fibre internet. I know that the previous cable internet speed I got at 30Mbps was actually easily sufficient to do whatever I wanted on the internet. Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 3, 2019 Share January 3, 2019 Thanks for that. But my 1 Gb fibre connection gives me 280Mbps at best and 90 Mbps at second best. Why not give customers who don't want any knew trunking around their properties if they don't mind a slower speed which might well be not that much slower than what they now get with the new fibre internet. I know that the previous cable internet speed I got at 30Mbps was actually easily sufficient to do whatever I wanted on the internet. How did you measure your connection speed? For wifi, no way you can achieve 1Gbps. I only hit 500mbps with MacBook Pro. For ethernet, i consistently hitting 900+. Link to post Share on other sites More sharing options...
Neutrino Supercharged January 3, 2019 Share January 3, 2019 How did you measure your connection speed? For wifi, no way you can achieve 1Gbps. I only hit 500mbps with MacBook Pro. For ethernet, i consistently hitting 900+. I'm not arguing connection speed. I'm saying that there might have been an alternative way to get TV and Internet in every room using existing hidden cabling which might well have given acceptable download speed and no unsightly new cabling for people who don't need high download speed for what they use the internet for. Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged January 24, 2019 Share January 24, 2019 Starhub SMS me say give free toyomi cooker worth $42.90! WTH! 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 25, 2019 Share January 25, 2019 This is because Starhub management didn't do any thinking. If they chose a STB with a wireless adapter like those android boxes then you don't need to put the ugly trunking to your bedroom. Its amazing how dumb people in top management can be. Some people have 2 or 3 set top boxes in their homes can you imagine how much ugly trucking they will have from their living room? Maybe Starhub can try getting smarter people in top management. Starbuh box no Wi-Fi? Damn 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 25, 2019 Share January 25, 2019 Starbuh box no Wi-Fi? Damn They are stuck thinking they are a cable company. And Wi-Fi no use cable. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 25, 2019 Share January 25, 2019 Japan NHK started 8K broadcast in December 2018. Korea KBC, MBS, SBS also already broadcasting in 4K for some years now, 24/7 see their plastic girl dancing on national TV sibei sharp. https://www.youtube.com/watch?v=OvnuxcGkc_o I believe the next range will be 8K TV with 4K TV lelong . 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 25, 2019 Share January 25, 2019 They are stuck thinking they are a cable company. And Wi-Fi no use cable. Even those android box also got Wi-Fi These guys I think they themselves gave up liao 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 25, 2019 Share January 25, 2019 (edited) Even those android box also got Wi-Fi These guys I think they themselves gave up liao They now understand they were a monopoly when they had cable TV. They can charge any price and people had no choice. Sign up with them or no cable TV for you. Now they have a competitor in Singtel TV and Singtel even have the advantage of English football. So they are scrambling to revamp themslves. If they dont have a monopoly the only competitive advantage they can have is a management that is smarter and have a vision. If not they become a me too company. But now got me three, me four, me five. Edited January 25, 2019 by Jamesc 1 Link to post Share on other sites More sharing options...
Alpha78 6th Gear January 25, 2019 Share January 25, 2019 (edited) I'm not arguing connection speed. I'm saying that there might have been an alternative way to get TV and Internet in every room using existing hidden cabling which might well have given acceptable download speed and no unsightly new cabling for people who don't need high download speed for what they use the internet for. https://www.amazon.com/DIRECTV-Broadband-DECA-Ethernet-Adapter/dp/B00ZDUQVFU/ref=sr_1_5?ie=UTF8&qid=1548380602&sr=8-5&keywords=deca I'm using a pair of these to bridge my Mio TV box in the living room, to the router in my study room, reusing the old coaxial cable that links both rooms. Cheap and good. 100Mbps duplex speed. Caveat is, the AC adapters come in 110V and no support for 230V, do not plug them into our power sockets or the power adapter will be fried. Either you buy a DC supply from a local store, or use the USB power supply. BUT the USB power supply must be plugged into something that supports data, you can't use a handphone charger. Mine are plugged into the USB port of the router. Edit: Third gen converters supporting up to 1 Gbps: https://www.amazon.com/DIRECTV-Broadband-DECA-Ethernet-Adapter/dp/B0779GJLPK/ref=pd_day0_hl_147_7?_encoding=UTF8&pd_rd_i=B0779GJLPK&pd_rd_r=a5c3bee3-2042-11e9-b541-d1277253676c&pd_rd_w=6n1Ft&pd_rd_wg=0gVde&pf_rd_p=ad07871c-e646-4161-82c7-5ed0d4c85b07&pf_rd_r=W08EC13093JJTB4KQH7B&psc=1&refRID=W08EC13093JJTB4KQH7B Edited January 25, 2019 by Alpha78 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Talking Point >>> Is your CPF enough for retirement?
Fibre broadband
Fibre broadband
StarHub customers affected by home broadband disruption can register for one-time 20% rebate on monthly fee
Reputable like Lye Design in Amk Auto-point
MyRepublic Vs Whizzcomms
Starhub Free viewing
Issue with starhub simcard
