Weez911 Supersonic June 3, 2020 Share June 3, 2020 8 hours ago, Chongster said: i have not worn my auto watch since March, will spoil not? do you need to wind it up every now and then? What auto watch is that? What movement? ↡ Advertisement Link to post Share on other sites More sharing options...
Spidey10 Supercharged June 3, 2020 Share June 3, 2020 8 hours ago, Chongster said: i have not worn my auto watch since March, will spoil not? do you need to wind it up every now and then? Actually same here. i put them in a watch winder. So the never ending question, should we let the watches stop and completely wind down if we are not wearing or continue to let it run in a watch winder. Which will be better? i like to put them in a watch winder and when i need it, i just take it out and wear them, as i don't have to reset and rewind the watches again and again. {that's me} Link to post Share on other sites More sharing options...
Throttle2 Supersonic June 3, 2020 Share June 3, 2020 9 hours ago, Chongster said: i have not worn my auto watch since March, will spoil not? do you need to wind it up every now and then? Nah, dont worry, watches are not cakes, they wont go bad so quickly. however if you left it since March 2002, the oils within may coagulate. All you need to do is to run it regularly again and it will be fine 2 Link to post Share on other sites More sharing options...
BanCoe Hypersonic June 3, 2020 Share June 3, 2020 21 hours ago, Viceroymenthol said: https://nypost.com/2020/06/01/looters-swipe-2-4m-worth-of-watches-from-soho-rolex-store/amp/ Very misleading if not confusing article which says 2.4million worth of watches and then says no watches stolen except for damage worth 2.4millon 🤦🏽 Link to post Share on other sites More sharing options...
BanCoe Hypersonic June 3, 2020 Share June 3, 2020 On 6/1/2020 at 3:03 PM, Inlinefour said: Actually old one also very nice too but new ones very expensive 😋😋😋 Boss can lend 1 ?? Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 3, 2020 Share June 3, 2020 4 minutes ago, BanCoe said: Boss can lend 1 ?? ok I print one for you 🤣🤣🤣 Link to post Share on other sites More sharing options...
Dp26 5th Gear June 4, 2020 Share June 4, 2020 Come to think of it better take out some watches and wear at home... lol On 6/3/2020 at 12:43 AM, Chongster said: i have not worn my auto watch since March, will spoil not? do you need to wind it up every now and then? 1 Link to post Share on other sites More sharing options...
Viceroymenthol 6th Gear June 4, 2020 Share June 4, 2020 Pang gang loh 3 Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 4, 2020 Share June 4, 2020 On 6/3/2020 at 8:58 AM, Weez911 said: What auto watch is that? What movement? ZF 8HP 2 Link to post Share on other sites More sharing options...
Weez911 Supersonic June 4, 2020 Share June 4, 2020 6 minutes ago, Viceroymenthol said: Pang gang loh You work as Aquaman? 3 Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 4, 2020 Share June 4, 2020 5 minutes ago, Weez911 said: You work as Aquaman? hooyah...the only easy day was yesterday 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 4, 2020 Share June 4, 2020 32 minutes ago, Weez911 said: You work as Aquaman? Which type...? 3 Link to post Share on other sites More sharing options...
Throttle2 Supersonic June 4, 2020 Share June 4, 2020 SinkieMan 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 4, 2020 Share June 4, 2020 29 minutes ago, Throttle2 said: SinkieMan wash watch then wash plates. hahah. 1 Link to post Share on other sites More sharing options...
RH1667 Hypersonic June 4, 2020 Share June 4, 2020 11 minutes ago, kobayashiGT said: wash watch then wash plates. hahah. Because the watch more expensive than the plate mah 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 4, 2020 Share June 4, 2020 1 minute ago, RH1667 said: Because the watch more expensive than the plate mah hahaha. I have been washing plates wrongly throughout my whole life!!! 😵 hahahahaha. 1 Link to post Share on other sites More sharing options...
Throttle2 Supersonic June 4, 2020 Share June 4, 2020 45 minutes ago, kobayashiGT said: wash watch then wash plates. hahah. Yes i hv no maid so i do the dishes 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 4, 2020 Share June 4, 2020 9 minutes ago, Throttle2 said: Yes i hv no maid so i do the dishes Then if you not working from home better like that. . . Only wipe table nia. 😂 ↡ Advertisement Link to post Share on other sites More sharing options...
Movie Critic
Movie Critic
Anyone watch 綜藝玩很大?
Anyone watch 綜藝玩很大?
