Lms822 2nd Gear April 28, 2019 Author Share April 28, 2019 He also want good environment what. Lentor has 9 playgrounds/Parks. Never understood why there is so many but makes the surroundings less built up, nice to jog. Used to have some very nice old trees and the government chopped all of them down after the death of someone due to falling tree a few years back. So sad. ↡ Advertisement Link to post Share on other sites More sharing options...
Wind30 Turbocharged April 28, 2019 Share April 28, 2019 Link to post Share on other sites More sharing options...
Lms822 2nd Gear April 28, 2019 Author Share April 28, 2019 Aiyo... Link to post Share on other sites More sharing options...
therock Supersonic April 28, 2019 Share April 28, 2019 My TOP floor is not really hot... did u have a roof Top terrace? I thought there is lots of insulation and air space in the roof itself. +1 not all top floors are hot.. a high arc design helps unless the owner redid the place and has a flat metal roof with no insulation. Link to post Share on other sites More sharing options...
Mkl22 Twincharged April 28, 2019 Share April 28, 2019 My TOP floor is not really hot... did u have a roof Top terrace? I thought there is lots of insulation and air space in the roof itself.Still hotter than the floor below. Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 28, 2019 Share April 28, 2019 Still hotter than the floor below.This is precisely what I mean. So i leave my top floor empty currently and use only three floor and below. Top floor only for chill out at night when my friends drop by. Day time still not a big issue if I want to use it as I have a dedicated compressor to drive the entire floor. Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 28, 2019 Share April 28, 2019 (edited) Haha. True about the top floor being hot. Why not put those metal vanes to vent the heat from the roof.Not so hot to that extent but I mean it is warmer than the floor below.Actually by installing solar panels may help, reduce heat and yet regenerate energy. Edited April 28, 2019 by Ct3833 Link to post Share on other sites More sharing options...
Mkl22 Twincharged April 28, 2019 Share April 28, 2019 Not so hot to that extent but I mean it is warmer than the floor below.Ya. Same when I was living at my parents. Always wanted to install the industrial ventilators but never got round to it. 2 Link to post Share on other sites More sharing options...
therock Supersonic April 28, 2019 Share April 28, 2019 Some houses get free hot water.. somehow the water is always warm.. no need to use the heater.. is it because the pipes get heated by the sun? Link to post Share on other sites More sharing options...
Volvobrick Supersonic April 28, 2019 Share April 28, 2019 (edited) +1 not all top floors are hot.. a high arc design helps unless the owner redid the place and has a flat metal roof with no insulation. For existing house with this problem, the cheapest solution is to install exhaust/extractor fans either in the ceiling (if pitched roof) or wall (as high as possible) if you don't want to tear up the roof. Should be only a few hundred to install. Just put them to run on timer, will only be a few dollars of electricity a month but the effect is very good. Edited April 28, 2019 by Volvobrick Link to post Share on other sites More sharing options...
therock Supersonic April 28, 2019 Share April 28, 2019 Being monitored is a scary thing.. Prop guru ads have been popping up .. and it’s interesting how many 99 year terraces there are, and it’s amazing that they are asking 2mil or more in rather ulu locations.. Link to post Share on other sites More sharing options...
Wind30 Turbocharged April 28, 2019 Share April 28, 2019 For existing house with this problem, the cheapest solution is to install exhaust/extractor fans either in the ceiling (if pitched roof) or wall (as high as possible) if you don't want to tear up the roof. Should be only a few hundred to install. Just put them to run on timer, will only be a few dollars of electricity a month but the effect is very good. Some roof has a small chimney like thing to let the hot air out, not mechanical though but should be good enough as hot air rises. For me, the hot room is the one with direct afternoon sun, not the highest. Link to post Share on other sites More sharing options...
Mkl22 Twincharged April 28, 2019 Share April 28, 2019 Some houses get free hot water.. somehow the water is always warm.. no need to use the heater.. is it because the pipes get heated by the sun?Yup. Depends on how the pipes have been run. More in the old old 1960-1980 which were never rebuilt. Part of the pipes were exposed or close to the surface on the ground floor. The older designs had the toilets at the back of the building and water and sewage pipes were exposed on the back wall. Link to post Share on other sites More sharing options...
Lms822 2nd Gear April 29, 2019 Author Share April 29, 2019 Hi all What’s the the plan for the current PSA area along west coast highway? Another marine bay project? Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 29, 2019 Share April 29, 2019 Ya. Same when I was living at my parents. Always wanted to install the industrial ventilators but never got round to it.Industrial ventilators might be unsightly and noisy for house. And yes, think of the mess of doing alteration/reno will feel tiring once settled in. Link to post Share on other sites More sharing options...
therock Supersonic April 29, 2019 Share April 29, 2019 Hi all Whatâs the the plan for the current PSA area along west coast highway? Another marine bay project? Google for Greater Southern WaterfrontRemember bro .. you are the one paying millions so make your agent work for you and do your homework Cheers Link to post Share on other sites More sharing options...
Wind30 Turbocharged April 29, 2019 Share April 29, 2019 Hi all What’s the the plan for the current PSA area along west coast highway? Another marine bay project? Looking at the recent articles from the official media, I guess it is a floating city... Link to post Share on other sites More sharing options...
Lms822 2nd Gear April 29, 2019 Author Share April 29, 2019 Google for Greater Southern Waterfront Remember bro .. you are the one paying millions so make your agent work for you and do your homework Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
JB Forest City
JB Forest City
Getting City Gas Into Landed Property
Auto gate repair
Auto gate repair
Is it a good time to buy a landed property to stay now?
Red light camera at X-junction of lentor ave & yishun ave 1
How to search for landed property to buy
