RadX Moderator December 28, 2024 Share December 28, 2024 On 12/28/2024 at 2:08 PM, Dark said: What's market rate nowadays for worm patching? I went to a tyre shop at tpy industrial, got ripped $15... or the price has gone up? $10 ↡ Advertisement Link to post Share on other sites More sharing options...
Dark 5th Gear December 28, 2024 Share December 28, 2024 walao eh! I know where not to go for tyres next time 1 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear December 30, 2024 Share December 30, 2024 On 12/28/2024 at 2:08 PM, Dark said: What's market rate nowadays for worm patching? I went to a tyre shop at tpy industrial, got ripped $15... or the price has gone up? RM10 if the hole is tiny 😁 1 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear June 26, 2025 Share June 26, 2025 Ignorance was bliss.. but today backside itchy went to take a look at my tyre.. saw a screw embedded horizontally and it has been worn down a bit too. I monitor and pump my tyres on the verge of OCD so I know it is not leaking air. Question - can this be patched?? If I ignore it, will the surrounding rubber eventually wear down until the screw itself drops out leaving a gaping hole? 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic June 26, 2025 Share June 26, 2025 On 6/26/2025 at 11:13 AM, boonhat_91 said: Ignorance was bliss.. but today backside itchy went to take a look at my tyre.. saw a screw embedded horizontally and it has been worn down a bit too. I monitor and pump my tyres on the verge of OCD so I know it is not leaking air. Question - can this be patched?? If I ignore it, will the surrounding rubber eventually wear down until the screw itself drops out leaving a gaping hole? Most likely no puncture lah. The screw is embedded in the thickest part of the tyre. Just pull it out. If starts to leak air, let us know! 1 2 Link to post Share on other sites More sharing options...
Beregond Supersonic June 26, 2025 Share June 26, 2025 (edited) On 6/26/2025 at 11:13 AM, boonhat_91 said: Ignorance was bliss.. but today backside itchy went to take a look at my tyre.. saw a screw embedded horizontally and it has been worn down a bit too. I monitor and pump my tyres on the verge of OCD so I know it is not leaking air. Question - can this be patched?? If I ignore it, will the surrounding rubber eventually wear down until the screw itself drops out leaving a gaping hole? Put some soap water on it. Slowly pull it out see of any bubbles. If no bubbles mean u are safe. Contuine to pull the whole screw out. If u see small bubble. Even if a very small bubbles keep coming out. Stop at once. Push the screw back and go to tyre shop to patch AT ONCE. Edited June 26, 2025 by Beregond 4 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 26, 2025 Share June 26, 2025 On 6/26/2025 at 11:29 AM, Beregond said: Put some soap water on it. Slowly pull it out see of any bubbles. If no bubbles mean u are safe. Contuine to pull the whole screw out. If u see small bubble. Even if a very small bubbles keep coming out. Stop at once. Push the screw back and go to tyre shop to patch AT ONCE. Good advice...but I'll add...do that near a tyre shop of choice...just in case cannot push back...at least not so siong to limp or push car...😅 1 1 Link to post Share on other sites More sharing options...
Gnahp Twincharged June 26, 2025 Share June 26, 2025 On 6/26/2025 at 11:13 AM, boonhat_91 said: Ignorance was bliss.. but today backside itchy went to take a look at my tyre.. saw a screw embedded horizontally and it has been worn down a bit too. I monitor and pump my tyres on the verge of OCD so I know it is not leaking air. Question - can this be patched?? If I ignore it, will the surrounding rubber eventually wear down until the screw itself drops out leaving a gaping hole? I encountered this dilemma before you got to make a choice I left it alone, it dropped out after tyre thread worn down as it just embedded in the thread without puncturing but... even it doesn't puncture the tyre now as the thread worn down, if the screw and stars aligned it may get push in further to give you a puncture dilemma, dilemma, dilemma... 😁 1 1 Link to post Share on other sites More sharing options...
Beregond Supersonic June 26, 2025 Share June 26, 2025 On 6/26/2025 at 12:48 PM, mersaylee said: Good advice...but I'll add...do that near a tyre shop of choice...just in case cannot push back...at least not so siong to limp or push car...😅 Ya. Actually the best action is if the tyre is still inflated. Drive straight to a tyre shop ask them pull out the nail for u. But alot of time. And alot of our drivers dun know what to look out for. Even its not leaking. Some black sheep tyre shops will use the scare tactics to pressure driver to change 2 pcs. ( which is why having a fix regular tyre shop is very important) 2 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 26, 2025 Share June 26, 2025 On 6/26/2025 at 12:56 PM, Beregond said: Ya. Actually the best action is if the tyre is still inflated. Drive straight to a tyre shop ask them pull out the nail for u. But alot of time. And alot of our drivers dun know what to look out for. Even its not leaking. Some black sheep tyre shops will use the scare tactics to pressure driver to change 2 pcs. ( which is why having a fix regular tyre shop is very important) I once had a regular tyre shop...until...no go back liao...scared kena another round of "accidently" found screws around my car...nothing is free...even free rotation...😅 1 3 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic June 26, 2025 Share June 26, 2025 On 6/26/2025 at 12:56 PM, Beregond said: Ya. Actually the best action is if the tyre is still inflated. Drive straight to a tyre shop ask them pull out the nail for u. But alot of time. And alot of our drivers dun know what to look out for. Even its not leaking. Some black sheep tyre shops will use the scare tactics to pressure driver to change 2 pcs. ( which is why having a fix regular tyre shop is very important) Some pressure to change car! Or self pressure. 4 Link to post Share on other sites More sharing options...
RadX Moderator June 26, 2025 Share June 26, 2025 On 6/26/2025 at 1:22 PM, Volvobrick said: Some pressure to change car! Or self pressure. 1 Link to post Share on other sites More sharing options...
Gnahp Twincharged June 26, 2025 Share June 26, 2025 On 6/26/2025 at 1:20 PM, mersaylee said: I once had a regular tyre shop...until...no go back liao...scared kena another round of "accidently" found screws around my car...nothing is free...even free rotation...😅 times are bad, competition is strong, got to pay salary and bills lah boss.... 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 26, 2025 Share June 26, 2025 On 6/26/2025 at 1:52 PM, Gnahp said: times are bad, competition is strong, got to pay salary and bills lah boss.... That one is more like appetite too big...😁 1 Link to post Share on other sites More sharing options...
Gnahp Twincharged June 26, 2025 Share June 26, 2025 On 6/26/2025 at 2:44 PM, mersaylee said: That one is more like appetite too big...😁 I left my 20+ years regular one man show tayar shop, after his son in law took over patterns more than badminton 🏸 4 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 26, 2025 Share June 26, 2025 On 6/26/2025 at 2:57 PM, Gnahp said: I left my 20+ years regular one man show tayar shop, after his son in law took over patterns more than badminton 🏸 Hold on...that sil is also a one man show...? My newly found one is also a sole man op...😅 1 Link to post Share on other sites More sharing options...
Gnahp Twincharged June 26, 2025 Share June 26, 2025 On 6/26/2025 at 3:25 PM, mersaylee said: Hold on...that sil is also a one man show...? My newly found one is also a sole man op...😅 young people where got so hardy he employed a clueless foreign worker to help him those type who will tighten your wheel nuts/bolts with their mighty impact wrench until your brake disk warp one.... old father in law can do it alone he young and fit needs helper it is not like their shop has a long queue of cars waiting to change tyres everyday 2 Link to post Share on other sites More sharing options...
Beregond Supersonic June 26, 2025 Share June 26, 2025 Actually if u visit your tyre shop. Sometime u ask them . Boss my tyres ok or not. Need to change? Or boss can patch or not. If every time u get the answer is botah already need to replace. Damage beyond repair. Change 2 pcs. Then u know u need to look for another shop liao. Most puncture can be repair ( it's they want or not only). Most of the honest 1 will patch for u. If really cannot they will show u. Its still leaking etc etc. Those type that dun even try and tell u cannot patch.... U can only go to them if they sell u the cheapest tyre. If driver look at thing another way. It depend on how driver see tyre shop. Is it a service centre? Or is it just another merchandise shop? Where price is the only thing that matter. If they sell u the cheapest tyre around. Then dun expect good after sales and honest after sales service. My tyres shop tyre is 1 of the more expensive around. But I stick with them cos I find them honest. No pressure. Alway show me the problem. Even go out to help me save my tyres. Advice like going to change car. Why waste money on new tyres bababa. 1 man's meat is another poison. 1 shop u like and recommended. Other may complain knife very sharp. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Any recommended tyre shop
Continental CSC 7.
Continental CSC 7.
