Phluvcat 6th Gear September 20, 2020 Share September 20, 2020 Where got reasonably price service to clean and reseal the headlight. Notice some condensation on the inside face of the transparent casing... before my ballast goes kaput. TIA. ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 20, 2020 Share September 20, 2020 Try Carousell many individuals doing headlights cleaning and dismantling. 3 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 21, 2020 Share September 21, 2020 Can try dr glass. https://www.mycarforum.com/marketplace/info-67735/ Link to post Share on other sites More sharing options...
Watwheels Supersonic September 21, 2020 Share September 21, 2020 (edited) Does your headlight casing condensation only occur during rainy days or even on hot humid days? For my previous car condensation occurred only during rainy days. At first I also thought the casing requires re-sealing but I removed one of the headlights for a closer look, it's not really a sealing issue, I also didnt remove the dust covers. It was a merely a case of a warm surface meeting cold air. What I did was I replaced my halogen lights, what I used were Osram Nightbreakers they are brighter thus generates slightly more heat than stock halogen bulbs. I went online and bought LED bulbs, they generate less heat. And the condensation stopped, even on heavy rainy days. How I know hot or not is to touch the casing when I reach home, after driving. The difference in heat generated is significant between the halogen bulbs I was using vs the LED bulbs. They are not blinding if you know how to adjust the alignment. Usually blinding ones are HIDs. Brighter light bulbs(higher lumens) generally produces more heat. Headlight casing I have noticed isnt completely sealed and vacuum. When you remove the dust covers and unplug the connections you will see that it's not sealed around that area. There's air inside the casing. Where there's air there's moisture as well. Like I mentioned it's a warm surface meeting cold air, that's why condensation occurs. It's good to give your headlights a physical check first before deciding what to do. Sometimes it may be cracked or got some tiny hole that you didnt notice, you know. If your ballast is placed inside the casing, try to move it out. The heat coming from the ballast may be the cause of heat build up inside the casing. Edited September 21, 2020 by Watwheels Link to post Share on other sites More sharing options...
Phluvcat 6th Gear September 21, 2020 Author Share September 21, 2020 10 hours ago, Watwheels said: Does your headlight casing condensation only occur during rainy days or even on hot humid days? For my previous car condensation occurred only during rainy days. At first I also thought the casing requires re-sealing but I removed one of the headlights for a closer look, it's not really a sealing issue, I also didnt remove the dust covers. It was a merely a case of a warm surface meeting cold air. What I did was I replaced my halogen lights, what I used were Osram Nightbreakers they are brighter thus generates slightly more heat than stock halogen bulbs. I went online and bought LED bulbs, they generate less heat. And the condensation stopped, even on heavy rainy days. How I know hot or not is to touch the casing when I reach home, after driving. The difference in heat generated is significant between the halogen bulbs I was using vs the LED bulbs. They are not blinding if you know how to adjust the alignment. Usually blinding ones are HIDs. Brighter light bulbs(higher lumens) generally produces more heat. Headlight casing I have noticed isnt completely sealed and vacuum. When you remove the dust covers and unplug the connections you will see that it's not sealed around that area. There's air inside the casing. Where there's air there's moisture as well. Like I mentioned it's a warm surface meeting cold air, that's why condensation occurs. It's good to give your headlights a physical check first before deciding what to do. Sometimes it may be cracked or got some tiny hole that you didnt notice, you know. If your ballast is placed inside the casing, try to move it out. The heat coming from the ballast may be the cause of heat build up inside the casing. Thanks boss for the detailed info. The condensation is still there, the whole day. But I got more irritating issue which still not resolved... my morning stuck rpm which weirdly does not (99% of the time) surface up later in the day. So largely only morning first start of the day or any subsequent cranks which I thought would make it go away. Tomorrow half day leave going SKM second time. Second mech and they are all Honda specialists. And I will be telling him to indent the driver side airbag which just malfunction (airbag sign on). Thank you thank you... need some time to digest. 1 Link to post Share on other sites More sharing options...
Shando 1st Gear October 7, 2020 Share October 7, 2020 On 9/21/2020 at 1:02 AM, Phluvcat said: Where got reasonably price service to clean and reseal the headlight. Notice some condensation on the inside face of the transparent casing... before my ballast goes kaput. TIA. You could open the headlight cap after parking, let it dry. Link to post Share on other sites More sharing options...
Kb27 Supersonic October 7, 2020 Share October 7, 2020 I noticed there's like 2 little rubber u-tube on my previous car headlight. These are supposed to let heat and moisture out, but prevents water from going in, I supposed. Maybe you can have a look to see if anything looks like "missing" ? Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear October 7, 2020 Share October 7, 2020 Ownself Fix best......cheaper.... ya... Common Problem and Easy to Fix. Plenty of Solutions. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear October 9, 2020 Author Share October 9, 2020 On 10/7/2020 at 6:41 PM, Kb27 said: I noticed there's like 2 little rubber u-tube on my previous car headlight. These are supposed to let heat and moisture out, but prevents water from going in, I supposed. Maybe you can have a look to see if anything looks like "missing" ? Thank you boss! Noticed recently there's gap between headlight and bumper, old car saggy liao! 😅 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear October 9, 2020 Author Share October 9, 2020 On 10/7/2020 at 9:38 PM, Apple-Tree said: Ownself Fix best......cheaper.... ya... Common Problem and Easy to Fix. Plenty of Solutions. Thanks for the video! But I no confidence of doing it. The last time it happen to the other one, my mech fixed it but never clean the inside of the lamp, now so dusty looking 😒 1 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear October 9, 2020 Share October 9, 2020 12 hours ago, Phluvcat said: Thanks for the video! But I no confidence of doing it. The last time it happen to the other one, my mech fixed it but never clean the inside of the lamp, now so dusty looking 😒 How much to fix that ? Still remember ? For me, frankly I never have this kind of problem one, either accident help me to fix (even before accident also no problem one) or I only drive the car for 10 years, when COE expires, the car go, or my headlight is 100% stock and I change bulb myself. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear October 14, 2020 Author Share October 14, 2020 On 10/9/2020 at 11:41 PM, Apple-Tree said: How much to fix that ? Still remember ? For me, frankly I never have this kind of problem one, either accident help me to fix (even before accident also no problem one) or I only drive the car for 10 years, when COE expires, the car go, or my headlight is 100% stock and I change bulb myself. Just sealed one of my headlights but not yet receive the bill. Let you know 😁 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic October 14, 2020 Share October 14, 2020 (edited) Some peeps change the problematic headlight housing together with the rests of the car 😁 Edited October 14, 2020 by mersaylee 1 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear October 15, 2020 Author Share October 15, 2020 13 hours ago, mersaylee said: Some peeps change the problematic headlight housing together with the rests of the car 😁 I also wish I can afford to do that, and I would probably change to the exact same model 😂 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear October 18, 2020 Author Share October 18, 2020 Hopefully resolved my sticky rpm issues, now gear change is back to normal and rpm dropping like how it should. Headlights condensation repaired but the inside of the glass tad dirty, nevermind lah. Also did servicing and realign the front bumper. Went inspection and failed exhaust (cracked hahaha). Went back mech, next morning fixed, in fact he changed back stock to stock exhaust system. But now dunno why exhaust quite a bit louder in the cabin. Am I missing something? But very happy the rpm stuff is gone and coasting is not 100% perfect but very smooth, hope it does not come back. Now I can drive like how I want to. Haven't receive my bill. May have to remind my mech sometimes he forgot about it. Both of us busy so I also never asked about the details. 🤭 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear October 22, 2020 Author Share October 22, 2020 On 10/9/2020 at 11:41 PM, Apple-Tree said: How much to fix that ? Still remember ? For me, frankly I never have this kind of problem one, either accident help me to fix (even before accident also no problem one) or I only drive the car for 10 years, when COE expires, the car go, or my headlight is 100% stock and I change bulb myself. Just received bill yesterday but not individually priced though... adjust my saggy bumper and fix one headlight is $100. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
ATP AT-205 Re-Seal
ATP AT-205 Re-Seal
NEW AGE POLISH --> Electric Vehicle Sunroof Protection Film
Both BYD and Tesla will now sell you Cat A versions of their popular Seal and Model 3 saloons
Cyclops Rear Light - Who came up with it first?
Are LED lights subject to brightness checks?
Quad Light Bulb Size
