Simple home DIY repairs
Lala81
On 4/25/2025 at 11:06 AM, Lala81 said:
When i go japan, i see what's the price in yen.
I quite like Muji clothes. Bought 2 pair of pants when i was there. Very comfortable.
Don’t worry I don’t recommend crap. It’s really decent. Wife bought it so long ago that I don’t even recall the price. Hopefully they don’t cut cost with the new batches. 🤭
  • Praise 3
Twincharged
I remember it is made in Taiwan
but that's a long time ago, I could be wrong
On 4/25/2025 at 10:46 AM, Gnahp said:
I have this type in my home for the longest time
usually bought buy my wife or helpers
I use until I pek chek
bought muji after the last one falling apart
This one the failure points will be the white plastic hooks.
then the ring spring can get dislodged from the clip. Or the hinge of the clip will break and everything fly apart…. Follow by mutterings of KNNNNNN!!! 🤭
  • Haha! 2
china now from the shopee (muji singapore shop) from when i searched just now.
Twincharged
I trust Japanese QC
found it, I think I bought two packets
told my wife these plastic pegs always break, I am buying spare parts for future replacement 😅
ended up never use
it says: for aluminium square type hanger use, 20 pieces
Made in Taiwan (my memory still good)
pegs are made from polycarbonate, no wonder so durable
  • Praise 2
On 4/24/2025 at 11:42 AM, Lala81 said:
Just washed my AC in prep of hotter months to come.
Was going to use this garden pressure spray bottle to pre spray coil cleaner diluted solution. I've only used this, at most for the 4th time. But this vacuum syringe like device failed.
After I done with my ac cleaning. I realised it's this syringe O ring seal has some greenish gunk which I tried to clean off. But also have some grease like quality. Most syringes at work just have a rubber stopper bung at the plunger.
This type of spray bottle more than 10 bucks. Quite wasted if can't fix this problem.
Cleaned off the gunk from the o ring area and tried to clean the syringe interior. Should be able to work again. But since it's dry already, not going to bother to try it with water and need to dry it all over again.
Or just put a dab of silicon grease.
On 3/31/2025 at 3:26 PM, Ody_2004 said:
ok just to summaries my few quotes for the installation of Joven 35L storage tank..
MOST Expensive PUB Licensed Installer.. $930 BEFORE GST... Sunday/PH ADD $200...
Mid tier around $615 to $645.. NOT PUB Licensed installer BUT company is PUB Licensed..
Cheapest $530..
I settled for HOE KEE which is prompt and manage to get it install with PUB (Please Use Bangla) installer. From txt in the morning 10.30am and done installation by 3.15pm. All in price $540.
Oh no....
Now just discovered how come my ceiling board has water seepage....
My 707 storage heater is probably 5.5yrs old.. started leaking.....
Can use any of those environment voucher or not?
Think need to get quotes for changing the water heater already....😅
  • Haha! 1
Hypersonic
On 5/3/2025 at 6:11 PM, Atonchia said:
Oh no....
5.5 year old already leaking? Must check if climate voucher can use to buy which storage heater. As storage heater should able to use climate voucher.
Yah... I was looking back earlier replies... Supposedly 707 should be able to last longer....
Maybe this heater was used more often than the other at common bathroom.
It's turn on and off daily throughout.
Maybe the repeated heating and cooling causes minor cracks and leak.
Supersonic
No la. Lousy quality these days. My joven 25L only blew the element after 12years, now 15years later still all good. The other one 15years orig element. But used less.
Edited by Mkl22
  • Praise 2
storage heater proven Jove the longest lasting unless unlucky. Mine 13years while my dad one almost 17 years still working with no leakage
  • Praise 2
Hypersonic
Element can replace. My common toilet one was 9 years (from prev owner) when changed
Supersonic
My room was slippery bcuz of the tiles. I had slipped and fell, and also my toddler.
So I laid some plastic/adhesive sheets from Shopee. But they wear out not long after, breaking into multiple pieces, And then I spend a lot of time clearing up the sticky mess.
The tiles became slippery once again.  I walked as if I have powder under my feet.
Finally, I pull out the tile conditioner by jackie called "Slip No More".  It worked well in the toilet, and now in my room. I bought it years ago from Horme, but they don't sell it anymore. I dunno what those contractors used, but this has worked well.
  • Praise 6
Supersonic
I think the leak is because there's no more sacrificial anode left inside the tank. So it starts eating the bare metal and finally it leaks.
Get a better brand like Rheem and change the anode when it's due.
https://www.rheemsingapore.com/blog/anode-rod-for-storage-tanks-what-is-it/
  • Praise 5
Is this a 2in1 with treatment and neutraliser?
Hypersonic
Using floor tiles always slippery esp when wet. That's why many people use vinyl flooring esp in the bedroom.
Falling down not small case, can lead to serious injure or might even fatal. Have to be careful at all times.
  • Praise 2
Supersonic
It's supposed to be applied over a clean floor. I just use a sponge to apply it and let it dry. Instruction says to scrub it after one hour, but I didn't do that.
It lasted quite a while when applied in the toilet. So maybe if after a while I have to reapply, I'll try to do it again.
It's the cheapest option I can find, besides the expensive way of hacking away the tiles and replacing with non-slip ones.
  • Praise 2
