wlalala 4th Gear August 18, 2021 Share August 18, 2021 Happened at SLE near Mandai Few days I got flashed, was less than 5kph over the limit so thought it was weird. Today just got flashed again at the same location again, but this time I'm going lower than the limit. Cannot be my speedo wrong - it's a <1 yr old car with stock rim and tyres. Waze number (GPS speed) is lower than my speedo even. Anyone encounter before? not speeding but still flash? ↡ Advertisement Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic August 18, 2021 Share August 18, 2021 To lighten up your day 1 9 Link to post Share on other sites More sharing options...
Atrecord Supersonic August 18, 2021 Share August 18, 2021 1 minute ago, Thaiyotakamli said: To lighten up your day you mean brighten up, right? 😄 4 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic August 18, 2021 Share August 18, 2021 1 minute ago, Atrecord said: you mean brighten up, right? 😄 This use light so lighten up🤪 1 Link to post Share on other sites More sharing options...
1fast1 Supersonic August 18, 2021 Share August 18, 2021 27 minutes ago, Thaiyotakamli said: To lighten up your day Gahmen making sure you have a fine day. 😁 5 Link to post Share on other sites More sharing options...
Kb27 Supersonic August 18, 2021 Share August 18, 2021 Don't worry. They are programmed to flash randomly. The one at PIE also same, but sometimes they caused idiots to jam brake and accidents happen. 4 1 2 Link to post Share on other sites More sharing options...
Sosaria Twincharged August 18, 2021 Share August 18, 2021 (edited) 1 hour ago, wlalala said: Happened at SLE near Mandai Few days I got flashed, was less than 5kph over the limit so thought it was weird. Today just got flashed again at the same location again, but this time I'm going lower than the limit. Cannot be my speedo wrong - it's a <1 yr old car with stock rim and tyres. Waze number (GPS speed) is lower than my speedo even. Anyone encounter before? not speeding but still flash? Random flashing either to test the system or scare drivers into behaving. Don't worry about it. I personally encounter before but always pretty sure my speed was just below limit and everything was fine. Thought that another car had triggered it. If you worry about these camera flashes then try to avoid the fast lane (right next to the road divider). Edited August 18, 2021 by Sosaria Link to post Share on other sites More sharing options...
markw12 3rd Gear August 18, 2021 Share August 18, 2021 (edited) 2 hours ago, wlalala said: Happened at SLE near Mandai Few days I got flashed, was less than 5kph over the limit so thought it was weird. Today just got flashed again at the same location again, but this time I'm going lower than the limit. Cannot be my speedo wrong - it's a <1 yr old car with stock rim and tyres. Waze number (GPS speed) is lower than my speedo even. Anyone encounter before? not speeding but still flash? Edited August 18, 2021 by markw12 8 Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 18, 2021 Share August 18, 2021 1 hour ago, Kb27 said: Don't worry. They are programmed to flash randomly. The one at PIE also same, but sometimes they caused idiots to jam brake and accidents happen. To remind motorists that there is a speed camera ? 1 Link to post Share on other sites More sharing options...
Beanoyip Turbocharged August 18, 2021 Share August 18, 2021 So did you get a ticket? Link to post Share on other sites More sharing options...
Beanoyip Turbocharged August 18, 2021 Share August 18, 2021 7 hours ago, Kb27 said: Don't worry. They are programmed to flash randomly. The one at PIE also same, but sometimes they caused idiots to jam brake and accidents happen. To remind motorist to slow down? Good tactic... 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic August 18, 2021 Share August 18, 2021 8 hours ago, Turboflat4 said: Gahmen making sure you have a fine day. 😁 The day will be fine but driving licence will not be! Two times means $400 x 2 = $800, and 12 + 12 points = 24 points = gantong! 1 1 Link to post Share on other sites More sharing options...
Scion Turbocharged August 19, 2021 Share August 19, 2021 7th month... might be something else on the road they have flashed and capture 😏 can check with TP what's inside their photos 2 3 Link to post Share on other sites More sharing options...
Optramagnum 6th Gear August 19, 2021 Share August 19, 2021 If you were seeing the flash before your eyes, that means it was capturing car from the opposite direction. All the traffic cameras are set to capture the rear license plate. Link to post Share on other sites More sharing options...
Kb27 Supersonic August 19, 2021 Share August 19, 2021 3 hours ago, Beanoyip said: To remind motorist to slow down? Good tactic... A motorist may be driving at speed limit, and suddenly got flashed. He thinks whether he has been speeding and will most likely slow down. That could create problems for the cars behind. Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 19, 2021 Share August 19, 2021 It happen to me too! Not once but many times. The camera is faulty. Can you fight in court and if the judge side you and let you off can you tell him I have many tickets also can let me off too? I pass you my bunch of tickets to show him. 11 hours ago, wlalala said: Happened at SLE near Mandai Few days I got flashed, was less than 5kph over the limit so thought it was weird. Today just got flashed again at the same location again, but this time I'm going lower than the limit. Cannot be my speedo wrong - it's a <1 yr old car with stock rim and tyres. Waze number (GPS speed) is lower than my speedo even. Anyone encounter before? not speeding but still flash? Link to post Share on other sites More sharing options...
Beanoyip Turbocharged August 19, 2021 Share August 19, 2021 1 hour ago, Kb27 said: A motorist may be driving at speed limit, and suddenly got flashed. He thinks whether he has been speeding and will most likely slow down. That could create problems for the cars behind. Don't worry, because when the cars behind see the flash, they would naturally slow down as well.. 😁 Link to post Share on other sites More sharing options...
Dafansu Turbocharged August 19, 2021 Share August 19, 2021 this Mandai one will always flash on/off even within speed limit. ↡ Advertisement Link to post Share on other sites More sharing options...
Would this stop offences?
Photography Chat
Photography Chat
Reverse/backup camera with dashcam recording function
Step aside Labubu, and let welcome Kodak
Wifi IP CCTV
Wifi IP CCTV
Huawei Mate 20 Pro / Leica Camera
