Ct3833 Supersonic July 19, 2023 Share July 19, 2023 (edited) Sharing this DIY on how I replaced my W212 left side mirror actuator. The left mirror will tilt down when i reverse my car, but recently it has been making strange noise, I knew one of the micro motors must have gone bad, I could buy a micro motor from taobao to fix it, but upon removing the refector , I realised that the actuator assembly screw is bad, so i decided to replace the entire actuator unit instead. The micro motor should look like this, it should be on a plastic worm gear, not the one as shown. I replaced it on my W211 before and it costed me less than $10 from taobao. These are the simple tools I need. a set of Torx screw drivers and a platic pryer. bought this from Surpass, Mr Lim, jiang zua ji. for $195.00 first, I removed the reflector using the plastic pryer. The reflector is snapped onto the actuator with several snap-on clips , do it gently to avoid damaging the clips. The reflector has two heater wires on it, be careful not to stretch the wires . I did not detach the wires because they did not cause any obstruction to my work. you can see a few of the snap-on clips at the back of thereflector. once the reflector is removed, I could see the three screws that mount the actuator onto the casing, I removed the screws and the actuator came out naturally. there is a cable connected to the actuator, disconnct the cable gently. Reverse the same process, and job is done. Maybe 15 min job? Now i am a happy man, no new car but i have a new actuator, very silence. Edited July 19, 2023 by Ct3833 ↡ Advertisement 11 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator July 19, 2023 Share July 19, 2023 You should use the Tamiya engine. make it faster. 6 Link to post Share on other sites More sharing options...
Inlinefour Twincharged July 19, 2023 Share July 19, 2023 wow impressive Sir 👍👍👍 me only know how to pump air into tyre 🙈🙉🙊 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 19, 2023 Author Share July 19, 2023 On 7/19/2023 at 5:40 PM, kobayashiGT said: You should use the Tamiya engine. make it faster. Make it spoil faster😄😄. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator July 20, 2023 Share July 20, 2023 On 7/19/2023 at 10:18 PM, Ct3833 said: Make it spoil faster😄😄. means you are not expert user. hahahah 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 20, 2023 Author Share July 20, 2023 On 7/19/2023 at 7:12 PM, Inlinefour said: wow impressive Sir 👍👍👍 me only know how to pump air into tyre 🙈🙉🙊 You are not bad, i know of another MCFer , when his tyres punctured, he will change car 😄😄. I hope he does not read my post😱😱😱 1 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 20, 2023 Author Share July 20, 2023 On 7/20/2023 at 9:38 AM, kobayashiGT said: means you are not expert user. hahahah I am a slow old man, i drive 3rd gear all the way from east coast to Jurong. 😪😪 1 Link to post Share on other sites More sharing options...
Inlinefour Twincharged July 20, 2023 Share July 20, 2023 On 7/20/2023 at 1:56 PM, Ct3833 said: You are not bad, i know of another MCFer , when his tyres punctured, he will change car 😄😄. I hope he does not read my post😱😱😱 errr his friend never tell him go tyre shop 😱😱😱 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator July 20, 2023 Share July 20, 2023 On 7/20/2023 at 1:58 PM, Ct3833 said: I am a slow old man, i drive 3rd gear all the way from east coast to Jurong. 😪😪 Not good for the car. You should always engage to the final drive. hahaha. 2 Link to post Share on other sites More sharing options...
Xers007 Supercharged July 21, 2023 Share July 21, 2023 (edited) On 7/19/2023 at 5:40 PM, kobayashiGT said: You should use the Tamiya engine. make it faster. mirror tilt in 1 sec sounds good Edited July 21, 2023 by Xers007 Link to post Share on other sites More sharing options...
Yeshe Turbocharged July 22, 2023 Share July 22, 2023 On 7/19/2023 at 4:03 PM, Ct3833 said: Sharing this DIY on how I replaced my W212 left side mirror actuator. The left mirror will tilt down when i reverse my car, but recently it has been making strange noise, I knew one of the micro motors must have gone bad, I could buy a micro motor from taobao to fix it, but upon removing the refector , I realised that the actuator assembly screw is bad, so i decided to replace the entire actuator unit instead. The micro motor should look like this, it should be on a plastic worm gear, not the one as shown. I replaced it on my W211 before and it costed me less than $10 from taobao. These are the simple tools I need. a set of Torx screw drivers and a platic pryer. bought this from Surpass, Mr Lim, jiang zua ji. for $195.00 first, I removed the reflector using the plastic pryer. The reflector is snapped onto the actuator with several snap-on clips , do it gently to avoid damaging the clips. The reflector has two heater wires on it, be careful not to stretch the wires . I did not detach the wires because they did not cause any obstruction to my work. you can see a few of the snap-on clips at the back of thereflector. once the reflector is removed, I could see the three screws that mount the actuator onto the casing, I removed the screws and the actuator came out naturally. there is a cable connected to the actuator, disconnct the cable gently. Reverse the same process, and job is done. Maybe 15 min job? Now i am a happy man, no new car but i have a new actuator, very silence. U know how to replace aircon fin on w212? 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 22, 2023 Author Share July 22, 2023 On 7/22/2023 at 3:07 PM, Yeshe said: U know how to replace aircon fin on w212? bro,sorry i dont kmow , too chim Link to post Share on other sites More sharing options...
Comage 5th Gear July 25, 2023 Share July 25, 2023 On 7/22/2023 at 3:07 PM, Yeshe said: U know how to replace aircon fin on w212? You mean the aircon vents in the interior? Or the car radiator cooling fins? Link to post Share on other sites More sharing options...
Yeshe Turbocharged July 25, 2023 Share July 25, 2023 On 7/25/2023 at 9:35 PM, Comage said: You mean the aircon vents in the interior? Or the car radiator cooling fins? I think it should be called aircon vent tabs. Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 25, 2023 Author Share July 25, 2023 On 7/25/2023 at 10:12 PM, Yeshe said: I think it should be called aircon vent tabs. If you are referring to the cabin aircon filter, then it is a easy job. Link to post Share on other sites More sharing options...
Comage 5th Gear July 25, 2023 Share July 25, 2023 On 7/25/2023 at 11:41 PM, Ct3833 said: If you are referring to the cabin aircon filter, then it is a easy job. Don't think he means the cabin air filter - it's the air vents that broken after years of usage. Usually those kind - you get the whole unit (knuckle-size vent) - and then remove the dashboard and replace it. Nobody fixes it fin-by-fin - but you may see guides online where guys do such a thing and "repair" the fins using wires and sh|t to hold the broken fins back together - but please FFS DO NOT do that, because you do not want wires in your face in the event of a crash. Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 25, 2023 Author Share July 25, 2023 (edited) On 7/25/2023 at 10:12 PM, Yeshe said: I think it should be called aircon vent tabs. @Comage if he is referring to the air vent, here is the video, looks like snap-on . I should be able to do it 😅😅 Good thing about these common European cars is that i can find many DIY videos in youtube, i dont see that many similar uploads for japanese cars. Edited July 25, 2023 by Ct3833 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 26, 2023 Author Share July 26, 2023 On 7/26/2023 at 12:32 AM, Ct3833 said: @Comage if he is referring to the air vent, here is the video, looks like snap-on . I should be able to do it 😅😅 Good thing about these common European cars is that i can find many DIY videos in youtube, i dont see that many similar uploads for japanese cars. @Yeshe, if this is what you are looking for, it looks easy, just use 2 L shape wires to pull out the vent. ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
2027 Mercedes C-Class
All things W124 :-)
All things W124 :-)
Mercedes AMG GT Gen 2
2016 Mercedes E-class (W213)
