Andrewkb Neutral Newbie July 30, 2003 Author Share July 30, 2003 Can tell us which shop, which level, what brand/model and price ? A pic will be appreciated ↡ Advertisement Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie July 30, 2003 Author Share July 30, 2003 (edited) Check out my new "CAI" My Stream can cross river liao Nope. I mean the headlight. We dun do it for long run, just a short sprint out in the afternoon. Remove headlight, extend piping out of headlight area until the open pod filter is outside the bonnet. You might as well install a proper CAI except mount it the other way around - instead of going down point up, and cut a hole in the bonnet to fit sort of like those really heavy duty 4x4 trucks with snorkels for air intakes so that it can run across rivers. Edited July 30, 2003 by Andrewkb Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 31, 2003 Share July 31, 2003 no problem....come on Friday meetup to claim lah... Is that your bait? Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 31, 2003 Share July 31, 2003 You all who doesn't need to work at night and weekends don't simply say say ah......... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 31, 2003 Share July 31, 2003 (edited) BTW, what kind of exhaust manifold the City VTEC has? Cast iron or equal length tubes? Edited July 31, 2003 by Mikeckchong Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie July 31, 2003 Share July 31, 2003 then change shifts on one of the fridays lah Link to post Share on other sites More sharing options...
Gymnut Neutral Newbie July 31, 2003 Share July 31, 2003 Hi Andrew, I have been plagued by high fuel comsumption all this while with my Sunny 1.5A (3 year old) ride. The CAI system is stock. Would you also recommend the same DIY mod for my car as well? Btw, couple of questions. 1. You got the tube and fasterner from SpeedWorks Auto Sport or SpeedWorks Pte Ltd? 2. Address/contact number? 3. Do they do installation as well? How much? I read that for the Sunny, I will need at least 50cm of the tube. That works out to be approx. $16.40. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie July 31, 2003 Author Share July 31, 2003 Go to the Speedworks at Genting Lane, Mr Loo. Check Yellowpages. Installation DIY lah ... suggest you go Friday nite meetup with the MCF gang and I believe they can help you :-) I would suggest you buy 2ft to 3ft and work from there ... Link to post Share on other sites More sharing options...
Silver_z 1st Gear July 31, 2003 Share July 31, 2003 No. TEC as in a metal plate with 2 wires sticking out. Upon sending current to it, 1 side of the plate becomes extremely cold and other side extremely hot. By removing the heat from the hot side, the cold side gets colder. Just by using air cooling on the hot side, can bring the cold side down to 5 degrees. Bleh! I find the pics then i post for u to see. Link to post Share on other sites More sharing options...
Cool Neutral Newbie July 31, 2003 Share July 31, 2003 (edited) Gymnut.. Do not jump into any crazy idea just because you have your poor consumption probably. Get your Throttle body checked... it could be dirty. Why don't you use KNN air-filter, good spark plugs like Iridium (can get from VTIM) and get your throttle body checked ?? Doing CAI will not solve the problem.. DO you know that the tube running in your Sunny will be too long and the air-suck in is weak ??? THose, you will not have enuff air at idle and your idle RPM will be off reading...inaddition, your entire car will vibrate Moreover, getting the tube will not solve the problem for Sunny, even if you want to fix it.. you need adapators.. and for your sunny intake box, the airfilter is horizontal with the throttle point up works.. you will have a "FLAT SPOT" if your air in-ward pressure is too weak. All Jap cars have this problem (which AndrewKB and i have a discussion before).. Becuase it is too RICH in fuel, the PCV and CAM release Valve released back to your throttle and air-intake will dirty (clock) up your Airintak-passage. WHat I did was pipe out the PCV and CAM release valve to a external device (oil-catch tank) thus do not let dirty fume/oil reburn back in the Throttle chamber. THus, your fuel is dirty and will not combust properly. You can go to Speedworks and get the tube but I tell you this, you will have problem fixing cos you need the adapters to convert from 3" to 2.45". Speedwork is a retailer and not a mechanic shop, you need to fix it yourself. It is up to you to trust me or not... if you like can you reply the following question. 1. What oil and grade you use 2. What is the interval of oil change 3. You pulley belt, is it over tighten ? 4. Did you check the state and health of your throttle body. 5. Are you using high flow air-filter ? 6. What is your currently idling RPM ? Lastly and most unlikely (if you car is not over 100,000km), check your Air-Flow Sensor.. is it dirty or clogged with grims.. clean it. (Caution: HIghly expensive and sensitive.. get a professional to clean for you unless you wannt take risk like I do..) my 2 cents.. ignore if you wish Edited July 31, 2003 by Cool Link to post Share on other sites More sharing options...
Cool Neutral Newbie July 31, 2003 Share July 31, 2003 IF you do the "upwards" air-box, you need to do a "upwards" exhaust. Remember I mentioned to you that i have a quick release breather from air-intake to allow hot air in get into the tube if I encounter flood ??? THIS IS BETTER MAN !!! Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 31, 2003 Share July 31, 2003 then change shifts on one of the fridays lah Actually Friday night is my off night but I think I need to spend more time with my kids..... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie July 31, 2003 Share July 31, 2003 no problems Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 31, 2003 Share July 31, 2003 You forgot..... 7. is your car carrying a lot of unnecessary junk? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie July 31, 2003 Share July 31, 2003 hhhmmmm this one sounds familiar Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 31, 2003 Share July 31, 2003 All too familiar....... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie July 31, 2003 Share July 31, 2003 who who Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie July 31, 2003 Share July 31, 2003 Ai yah.....during tomolo's meetup, just go round and do a boot inspection lor...... Would you believe that there is a difference when I accelerate with and without my woofer box with 2 x 10" Kickers? ↡ Advertisement Link to post Share on other sites More sharing options...
Google Maps latest version
Different version of 3M Clay Bar
Which version of 倚天
Which version of 倚天
Subaru S204 sti version 9 limited edition show piece car
Mitsubishi Colt Version R discussion
Toyota Corona (Big backside version)
Which version of the iPhone 6/7/8/n..would you rather own?
Bill gates invented NEWater
