Vienta Neutral Newbie January 20, 2005 Share January 20, 2005 Sorry, check with you..... You had been using the authentic wax....when you apply the 12 months, did you remove the wax? I think using the 12 months should be sufficient.... Damn smooth feeling! ↡ Advertisement Link to post Share on other sites More sharing options...
Steelblue Neutral Newbie January 20, 2005 Share January 20, 2005 Fusso 12mths is supposed to be put on a clean surface , if put on a wax it may look good (or not) but one thing is for sure, the durability will be compromised. Link to post Share on other sites More sharing options...
Lawsu Neutral Newbie January 20, 2005 Share January 20, 2005 so how to remove all existing wax or sealent?? Link to post Share on other sites More sharing options...
Epsilon 2nd Gear January 20, 2005 Share January 20, 2005 use mama lemon..... Link to post Share on other sites More sharing options...
Lawsu Neutral Newbie January 20, 2005 Share January 20, 2005 sure use mama lemon???........will damage the paint or not??..... I heard of that b4...but dunno true or not....have you use them urself? Link to post Share on other sites More sharing options...
Epsilon 2nd Gear January 20, 2005 Share January 20, 2005 i used it on my old sunny....no problem... Link to post Share on other sites More sharing options...
Steelblue Neutral Newbie January 20, 2005 Share January 20, 2005 Don't think mama lemon will remove the existing sealant...(not sure bout wax) Maybe can try some chemical cleaner like AIO or something from Meguiar Link to post Share on other sites More sharing options...
Ebos Neutral Newbie January 21, 2005 Share January 21, 2005 Yes, washing detergent will remove the wax and sealant.. Has tried before reapplying new coats... Link to post Share on other sites More sharing options...
Vienta Neutral Newbie January 21, 2005 Share January 21, 2005 (edited) ok....will try it! SO using normal car detergent will not get rid of the wax right? Edited January 21, 2005 by Vienta Link to post Share on other sites More sharing options...
Steelblue Neutral Newbie January 21, 2005 Share January 21, 2005 Branded car shampoo is usually ph7 (neutral) and should not strip the existing wax . As for dish washing liquid, "I personally" do not recommend due to it being alkaline, hence not friendly to rubber and plastic components.To each his own I would say Link to post Share on other sites More sharing options...
Leonknapp Clutched January 21, 2005 Author Share January 21, 2005 Sorry, check with you..... You had been using the authentic wax....when you apply the 12 months, did you remove the wax? I think using the 12 months should be sufficient.... Damn smooth feeling! No, Just applied it directly. Yah I think 12 months is good enuf. Link to post Share on other sites More sharing options...
St220 Neutral Newbie January 22, 2005 Share January 22, 2005 1. Kizz ClearWash entire car and remove all water residue. Shake well bottle and take liquid onto sponge. Apply as evenly as possible by small section (EX 50 x 50 cm). Immediately buff off by clean soft dry cloth. Repeat the same course to finish entire car body. haiz.... now then saw this... let the kizz clear dry up.... clean like mad too tired, got to continue tomorrow arm pain pain Link to post Share on other sites More sharing options...
V200 Neutral Newbie January 27, 2005 Share January 27, 2005 1. Kizz Clear Wash entire car and remove all water residue. Shake well bottle and take liquid onto sponge. Apply as evenly as possible by small section (EX 50 x 50 cm). Immediately buff off by clean soft dry cloth. Repeat the same course to finish entire car body. -------------------------------------------------------------------------------- haiz.... now then saw this... let the kizz clear dry up.... clean like mad too tired, got to continue tomorrow arm pain pain When I did soft99 12 months, the car was dry but hot (just came out from hot sun) after washing it was still warm.....then when I applied the 12 months, it streaked! Wah....wipe it arm almost came off! So please wait till your car body is cool then apply the 12 months....and from the look of things, most of Soft products require a cool body. Link to post Share on other sites More sharing options...
Leonknapp Clutched January 27, 2005 Author Share January 27, 2005 Not just soft99. in fact all waxes require a cool body for proper application and removal. The only polymer sealant i know that can be applied in the sun is Mothers Reflections and to some extent zaino. Link to post Share on other sites More sharing options...
Panda Neutral Newbie January 27, 2005 Share January 27, 2005 Dude, just on the Soft99 Authentic wax alone, without sealant or other special care, how long you'd think the beading will last? I've been kinda lazy. 5 weeks since the last wax? Can't feel the wax anymore, but hey, its still beading. Link to post Share on other sites More sharing options...
V200 Neutral Newbie January 27, 2005 Share January 27, 2005 Not just soft99. in fact all waxes require a cool body for proper application and removal. The only polymer sealant i know that can be applied in the sun is Mothers Reflections and to some extent zaino. But even after you wash the car, the temperature is not cool enough? Wah, black car under the hot sun......I think can only wash when my car is parked in the multistory for 1/2 day.... Link to post Share on other sites More sharing options...
Leonknapp Clutched January 27, 2005 Author Share January 27, 2005 actually my cars black too and after a wash the surface is already cool. But I do raise the bonnet after drying the car to air the engine and allow the bonnet to cool. Link to post Share on other sites More sharing options...
Leonknapp Clutched January 27, 2005 Author Share January 27, 2005 If u satisfied with the paint condition go ahead and add another coat of wax! With all waxes the smoothness disappears after the first wash but it is still protecting. Cheers! ↡ Advertisement Link to post Share on other sites More sharing options...
'Queen of rock 'n' roll' Tina Turner dies at 83
Rock music fans, Slash concert in Malaysia
Galapagos rock formation Darwin's Arch has collapsed
Any Ideas for Cafe with Live Jazz/Rock Music
Eddie Van Halen dies
HSA issues alert on 'weight loss' products
Hard Rock, Soft Rock, Metal... who are the greatest 10?
