E-Jazz Neutral Newbie September 23, 2010 Share September 23, 2010 Hi all, Just curious since I am still inexperience in all these. On Singapore roads given that my ride is front and back brake disc, just how often are the brake pads changed. Cause I realized that driving on local road uses the brakes a lot due to constant traffic light stoppages, though I understand that how often it is changed depends on individual driving style, so hope everyone can share your experience with me so i have a rough idea. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear September 23, 2010 Share September 23, 2010 best change when slightly below half thickness Link to post Share on other sites More sharing options...
Woonyang Clutched September 23, 2010 Share September 23, 2010 a lot depends on the driver, not just the road/traffic. also depends on your hardware. Link to post Share on other sites More sharing options...
Porche 5th Gear September 23, 2010 Share September 23, 2010 mine 4.5yrs haven't change once, mechanic says good to go. Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 23, 2010 Author Share September 23, 2010 best change when slightly below half thickness How do we see half thickness sorry for my noob question a lot depends on the driver, not just the road/traffic. also depends on your hardware. Yea, this part I understand. thanks. mine 4.5yrs haven't change once, mechanic says good to go. Wow thats quite a long time. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear September 23, 2010 Share September 23, 2010 1) either eye power and estimate the thickness of your brake pad and change when u see it halfway 2) get the tech specs for your brake system where they list the pad thickness and pad backing plate thickness, then use measurement for accuracy 3) if you service at KM usually they will ask u change at about 1/3 left life either way, make sure the rotor surface is even wear as well Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 23, 2010 Author Share September 23, 2010 1) either eye power and estimate the thickness of your brake pad and change when u see it halfway 2) get the tech specs for your brake system where they list the pad thickness and pad backing plate thickness, then use measurement for accuracy 3) if you service at KM usually they will ask u change at about 1/3 left life either way, make sure the rotor surface is even wear as well Ya, I will be sending to Kah for servicing. Will note the listed points. Thanks Link to post Share on other sites More sharing options...
Dafansu Turbocharged September 23, 2010 Share September 23, 2010 your mechanic should check for you during servicing. Link to post Share on other sites More sharing options...
C-K 2nd Gear September 23, 2010 Share September 23, 2010 if you don't tailgate, drive on expressway most of the time, and don't always tap brake to slow down the car (you can slow down with just releasing the gas pedal), the pads should last you longer than 5 years. Link to post Share on other sites More sharing options...
Kiadaw 6th Gear September 23, 2010 Share September 23, 2010 your mechanic should check for you during servicing. Yes. But just to be safe, ask them specifically to check the pad. As driver, also take note if your pad no long grip as well. To preserve the brake pads, don't tail gate ( as it often result in unnecessary braking...& crushes). If the lights start to turn red in front, start to slow down, instead of drive in front then slam brakes. Slow down when about to turn in at junction & turns Use engine brakes Link to post Share on other sites More sharing options...
Vblues Neutral Newbie September 23, 2010 Share September 23, 2010 Pads are cheap. Change them every 2-3 years. Don't compromise on safety just because you want to save a few dollars. Link to post Share on other sites More sharing options...
Wildaltum 1st Gear September 23, 2010 Share September 23, 2010 Well I have driven abt 67000km and my brake pads are still good as original. It all depends on the waythe driver drives. Link to post Share on other sites More sharing options...
Tasman Neutral Newbie September 23, 2010 Share September 23, 2010 have done 100K still have not change the pad... wore off only approx half Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 23, 2010 Share September 23, 2010 (edited) Hi all, Just curious since I am still inexperience in all these. On Singapore roads given that my ride is front and back brake disc, just how often are the brake pads changed. Cause I realized that driving on local road uses the brakes a lot due to constant traffic light stoppages, though I understand that how often it is changed depends on individual driving style, so hope everyone can share your experience with me so i have a rough idea. Thanks Please do not wait until accident then go for servicing/repairs (an ex-colleague did that) Was told most cars here had replacement brake pads (front) around 40,000km. Not observed if slower acceleration cars can make the brake pads last longer The rear brakes usually last till/beyond COE expiry. Only my previous Kelisa had replacement beyond 60,000km (I believe the car lightweight has to do with it) Edited September 23, 2010 by Good-Carbuyer Link to post Share on other sites More sharing options...
Civic6656 1st Gear September 23, 2010 Share September 23, 2010 Depending on makes and whether u r using aftermarket pads. My brake pads are now 82kkm old and still going strong! Link to post Share on other sites More sharing options...
Blackyv Turbocharged September 23, 2010 Share September 23, 2010 Mine last 50k only, actually one piece was very thin on one end. Uneven wear.. The other piece still good but I change it... Link to post Share on other sites More sharing options...
Yuan 6th Gear September 24, 2010 Share September 24, 2010 Depends on the driver's usage. Link to post Share on other sites More sharing options...
Ichibawa 5th Gear September 24, 2010 Share September 24, 2010 Check your brake pads every servicing. The mechanic will tell you when its due to change. ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Marathons in Singapore
Chicken in a Biskit
Chicken in a Biskit
Perodua Club Singapore
