Suirattigas 1st Gear January 29, 2018 Share January 29, 2018 Hi there, I’m getting my ride next weekend. Currently it is fitted with 18’. Any fellow mini buddies out there fitted with 19’? Can you share your views? Is the ride really very much Firmer? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Felipe 3rd Gear January 29, 2018 Share January 29, 2018 One inch up won’t make a noticeable difference in ride quality. If u were ok with 18 during testing, 19 is fine too. However, spend more on tyres n brakes suspension components wear faster slightly, if tat bothers u Link to post Share on other sites More sharing options...
Watwheels Supersonic January 30, 2018 Share January 30, 2018 18" = 18 inch 18' = 18 foot Just FYI. 1 Link to post Share on other sites More sharing options...
Soya Supersonic January 30, 2018 Share January 30, 2018 Doesn’t mini oredi hv a hard ride? Sat in a fren’s cooper S w 18”. Ride was sibei jiggly n uncomfortable leh Link to post Share on other sites More sharing options...
Suirattigas 1st Gear January 30, 2018 Author Share January 30, 2018 (edited) 18" = 18 inch 18' = 18 foot Just FYI. roger that .... thanks bro :) Edited January 30, 2018 by Suirattigas Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 30, 2018 Share January 30, 2018 Doesn’t mini oredi hv a hard ride? Sat in a fren’s cooper S w 18”. Ride was sibei jiggly n uncomfortable leh That's why Mini can enter or exit expressway around 80 w/o tyre screeching. Only ole man will says it is uncomfortable 1 Link to post Share on other sites More sharing options...
Suirattigas 1st Gear January 30, 2018 Author Share January 30, 2018 will switching out of run- flats help? Link to post Share on other sites More sharing options...
Lava 5th Gear January 30, 2018 Share January 30, 2018 Hi there, I’m getting my ride next weekend. Currently it is fitted with 18’. Any fellow mini buddies out there fitted with 19’? Can you share your views? Is the ride really very much Firmer? just collected my clubman s on last weekend. no intention to change it to 19" rim coz it will reduce it comfort level. I had 18" on my pervious 5 drs coopers s and the ride is definitely harder than the original 17". but again the positioning of hatch back and clubman is totally different. 18" should be the right size for clubman s without reducing your ride comfort. pls take note that the brake may produce some sound when braking at low speed if you put on after market rims, this is what happen to my pervious 5 drs cooper s. 2 Link to post Share on other sites More sharing options...
Lava 5th Gear January 30, 2018 Share January 30, 2018 will switching out of run- flats help? ride comfort will increase. I switched out the run-flat on my pervious ride and replace by pss, ride comfort and handling improved. but need to worry about flat tires when we travel to Malaysia. clubman is still very comfortable and quiet on run-flat. the feel is totally different from hatchback mini. moreover clubman s came in 8 speed gearbox and the engine feel silky smooth. take time to get used to the relatively small rear view window. Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 30, 2018 Share January 30, 2018 ride comfort will increase. I switched out the run-flat on my pervious ride and replace by pss, ride comfort and handling improved. but need to worry about flat tires when we travel to Malaysia. clubman is still very comfortable and quiet on run-flat. the feel is totally different from hatchback mini. moreover clubman s came in 8 speed gearbox and the engine feel silky smooth. take time to get used to the relatively small rear view window. Juz get Slime tyre repair kit. Link to post Share on other sites More sharing options...
Soya Supersonic January 30, 2018 Share January 30, 2018 That's why Mini can enter or exit expressway around 80 w/o tyre screeching. Only ole man will says it is uncomfortable ð Ahemmm....now I understand why u prefer to cycle instead of driving.... Link to post Share on other sites More sharing options...
Suirattigas 1st Gear January 30, 2018 Author Share January 30, 2018 Was offered (attached picture) at a pretty good price for trading in my stock rims... the test drive was good with the 18" but the back passengers may find it a tad too firm.... and with 19" no sure how much firmer the ride will get Link to post Share on other sites More sharing options...
Lava 5th Gear January 30, 2018 Share January 30, 2018 Juz get Slime tyre repair kit. bro, I had one set in my pervious ride. the mini is my wife car and I am very sure that she don't know how to operate that equipment. can you imagine that she asked me what is the 2 ears one with a '+' and the other one what a '-' behind the steering wheel? 1 Link to post Share on other sites More sharing options...
Lava 5th Gear January 30, 2018 Share January 30, 2018 Was offered (attached picture) at a pretty good price for trading in my stock rims... the test drive was good with the 18" but the back passengers may find it a tad too firm.... and with 19" no sure how much firmer the ride will get nice rims but I still prefer comfort than sporty else will defeat the propose of changing my hatchback to clubman. yours new ride is british racing green white top with black interior? clubman seem to have default auto headlight and DRL cannot be switched off. Link to post Share on other sites More sharing options...
Suirattigas 1st Gear January 30, 2018 Author Share January 30, 2018 nice rims but I still prefer comfort than sporty else will defeat the propose of changing my hatchback to clubman. yours new ride is british racing green white top with black interior? clubman seem to have default auto headlight and DRL cannot be switched off. Yes it shall be BR green white top/ strips with black interior as per my avatar. What about yours? Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 30, 2018 Share January 30, 2018 Ahemmm....now I understand why u prefer to cycle instead of driving....Actually I like both. I hates traffic only Link to post Share on other sites More sharing options...
Lava 5th Gear January 30, 2018 Share January 30, 2018 Yes it shall be BR green white top/ strips with black interior as per my avatar. What about yours? Burgundy with blue interior. the car feel very stable but the drive is not as engaging as the hatchback. Link to post Share on other sites More sharing options...
Suirattigas 1st Gear January 30, 2018 Author Share January 30, 2018 Burgundy with blue interior. the car feel very stable but the drive is not as engaging as the hatchback.Nice!! Love the blue interior... well, still more engaging than ctryman haha ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Mini Cooper
Mini Cooper queries
Mini Cooper queries
Does rims change shape/warp over time?
Replacing a 2yrs old tyre?
Renting a Mini bus to go Malaysia
