Qaz20 3rd Gear January 20, 2019 Share January 20, 2019 How much heavier are Run -Flat Tyre compare with Normal Tyre.?Is it more than 1 kg per Tyre.?Should be about 2-3kg heavier per tyre. ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Supersonic January 20, 2019 Share January 20, 2019 Should be about 2-3kg heavier per tyre. That is very heavy. Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic January 20, 2019 Share January 20, 2019 That is very heavy. But peace of mind esp u go malaysia drive 3 Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 20, 2019 Share January 20, 2019 But peace of mind esp u go malaysia drive Heavy, noisy, costly,.....but it is much safer than normal tyre 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 20, 2019 Share January 20, 2019 Heavy, noisy, costly,.....but it is much safer than normal tyre Run flat tire Heavy yes (against total weight of car and Passenger is negligible) Noisy yes (some normal tire has noise issue) Costly yes (if you buy the Correct tire is not as costly as we think) Safer Yes. 100% yes In the Event of Sudden lost of Tire pressure you will know. Your car can continue drive for 80km even your Tire pressure Drop to Zero. 1 Link to post Share on other sites More sharing options...
jonaslim86 1st Gear January 28, 2019 Share January 28, 2019 Run flats are harsher than conventional tyres Link to post Share on other sites More sharing options...
Lava 5th Gear June 28, 2019 Share June 28, 2019 (edited) anyone try this Michelin Pilot Sport A/S Plus ZP ? looking for a high performance 225/45/18 tires in dry and wet condition I am currently on Bridgestone Potenza RFT Edited June 28, 2019 by Lava Link to post Share on other sites More sharing options...
Hubwee Turbocharged June 28, 2019 Share June 28, 2019 (edited) anyone try this Michelin Pilot Sport A/S Plus ZP ? looking for a high performance 225/45/18 tires in dry and wet condition I am currently on Bridgestone Potenza RFT PS4S should be the best summer tire in the market now . There is a huge diff between PS4 and PS4S hor . Edited June 28, 2019 by Hubwee Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged June 28, 2019 Share June 28, 2019 https://www.engadget.com/2019/06/04/gm-and-michelin-airless-tires/ New tyres Link to post Share on other sites More sharing options...
TameDriver Twincharged June 29, 2019 Share June 29, 2019 anyone try this Michelin Pilot Sport A/S Plus ZP ? looking for a high performance 225/45/18 tires in dry and wet condition I am currently on Bridgestone Potenza RFT Try Michelin Primacy 3 RFT. For peace of mind. I'm into my 2nd set now. 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 29, 2019 Share June 29, 2019 anyone try this Michelin Pilot Sport A/S Plus ZP ? looking for a high performance 225/45/18 tires in dry and wet condition I am currently on Bridgestone Potenza RFT Dump that RFT & put on PS4S. Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 29, 2019 Share June 29, 2019 anyone try this Michelin Pilot Sport A/S Plus ZP ? looking for a high performance 225/45/18 tires in dry and wet condition I am currently on Bridgestone Potenza RFT for Seden car , please stay away from this A/S = all season = approoved for Winter season this AS on seden 1 Link to post Share on other sites More sharing options...
Rskc 5th Gear June 29, 2019 Share June 29, 2019 Any bros used both Bridgestone T001 RFT and Pirelli P7 Cinturato RFT before? How do they compare especially on road noise? Both are touring tyre I guess. Please don't ask me to go non-RFT. RFT saved me on couple of occasions. 4 Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 29, 2019 Share June 29, 2019 Any bros used both Bridgestone T001 RFT and Pirelli P7 Cinturato RFT before? How do they compare especially on road noise? Both are touring tyre I guess. Please don't ask me to go non-RFT. RFT saved me on couple of occasions. 1 Link to post Share on other sites More sharing options...
redstuff 4th Gear June 29, 2019 Share June 29, 2019 (edited) Any bros used both Bridgestone T001 RFT and Pirelli P7 Cinturato RFT before? How do they compare especially on road noise? Both are touring tyre I guess. Please don't ask me to go non-RFT. RFT saved me on couple of occasions. Edited June 29, 2019 by redstuff 1 Link to post Share on other sites More sharing options...
Rskc 5th Gear June 29, 2019 Share June 29, 2019 BS 001 on 5er seems not so noisy PC P7 on 4er seems better braking depends on which model you driving also Thanks bro. Am getting X1 F48. Suspect it comes with BS T001. Nvr used T001 before but did not have good experience with previous other BS RFT. Had BS ecopia (i think) RFT stock 16" from PML on F30. It was really crap. Noisy. It even wobbled during just a little hard cornering (ya side wall probably too thick). For aesthetic and drive, I took the plunge to upgrade to 18" with P7 and loved it. Very good in both wet and dry and FC even stayed the same! Noise level went down too. Now contemplating driving straight to tyre shop to trade in the T001 for P7 after getting the X1. But if T001 is good, I may just stay with it and try it out. Just afraid once I used and don't like the tyres, there will be no more trade in value. 1 Link to post Share on other sites More sharing options...
redstuff 4th Gear June 29, 2019 Share June 29, 2019 Any advice welcomed. Link to post Share on other sites More sharing options...
Inlinefour Twincharged June 29, 2019 Share June 29, 2019 Thanks bro. Am getting X1 F48. Suspect it comes with BS T001. Nvr used T001 before but did not have good experience with previous other BS RFT. Had BS ecopia (i think) RFT stock 16" from PML on F30. It was really crap. Noisy. It even wobbled during just a little hard cornering (ya side wall probably too thick). For aesthetic and drive, I took the plunge to upgrade to 18" with P7 and loved it. Very good in both wet and dry and FC even stayed the same! Noise level went down too. Now contemplating driving straight to tyre shop to trade in the T001 for P7 after getting the X1. But if T001 is good, I may just stay with it and try it out. Just afraid once I used and don't like the tyres, there will be no more trade in value. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Petlas Or Giti?
Petlas Or Giti?
Hdb flat renovation
Hdb flat renovation
