Kwanheng 1st Gear September 1, 2012 Share September 1, 2012 Accelerate faster? will try to do that.. I realized my car is also jerking during idling and lots of vibrations. Read up some forum on the internet and they recommend resetting of ECU Has anyone tried to do that before? at your car age, your crank and cam sensor might be gone liao. i got them on hand, do call me if u need them. ↡ Advertisement Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 1, 2012 Share September 1, 2012 (edited) Always pump my tyres to 230kpa (biweekly) did a carburetor cleaning and changed fuel filter the previous servicing Also tried using before STP complete fuel system cleaner, gas treatment, octane booster, fuel injector cleaner.. None of them help stop using all those STP thing, it will destroy your old engine with out helping out. i used a engine flush at 120k engine, 1 week later i got a gasket leak and im leaking engine oil. ( i learn the hard way, if all those can of STP can cure then, theres no need for car workshop to be around liao ) if its FC you want, you need to maintain the car well to get good fc. use 5w 30 engine oil. i just checked, im getting 9.7 per litres for a 2006 optra AT with 155k millage. Edited September 1, 2012 by Kwanheng Link to post Share on other sites More sharing options...
GoodCar 4th Gear September 2, 2012 Author Share September 2, 2012 at your car age, your crank and cam sensor might be gone liao. i got them on hand, do call me if u need them. Yes, now I remember, when I got my car new back in 2005, I had this vibration problem too and it was this sensor which is not install properly and the line touch the hot engine block. It was replaced by the AD then. Make sure the sensor line did not touch the hot engine. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 2, 2012 Share September 2, 2012 Yes, now I remember, when I got my car new back in 2005, I had this vibration problem too and it was this sensor which is not install properly and the line touch the hot engine block. It was replaced by the AD then. Make sure the sensor line did not touch the hot engine. now i got bigger problem, car sometimes feel like stalling, starting is not a problem, only sometimes need to crank longer. a few times car died off in a jam. i have no ideal what is wrong, i suspect its fuel pump. i have changed, filter filter, crank sensor cam sensor evg valve fuel line any advise? Link to post Share on other sites More sharing options...
Oyq1989 1st Gear September 2, 2012 Share September 2, 2012 now i got bigger problem, car sometimes feel like stalling, starting is not a problem, only sometimes need to crank longer. a few times car died off in a jam. i have no ideal what is wrong, i suspect its fuel pump. i have changed, filter filter, crank sensor cam sensor evg valve fuel line any advise? Which workshop do you go to? how much is it to change the cam sensor? Im currently with RDY Autocare Link to post Share on other sites More sharing options...
Oyq1989 1st Gear September 2, 2012 Share September 2, 2012 Where got carburetor? modern car all fuel injection liao Im not sure what is it..haha..some intake valve.. The person said FC will improve after doing the cleaning.. I don't have a lot of knowledge about cars.. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 3, 2012 Share September 3, 2012 Which workshop do you go to? how much is it to change the cam sensor? Im currently with RDY Autocare Cam Sensor $70 with workmanship. RDY quote me $90. and it was done with some big workshop at level 1 of RDY. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 3, 2012 Share September 3, 2012 Im not sure what is it..haha..some intake valve.. The person said FC will improve after doing the cleaning.. I don't have a lot of knowledge about cars.. i believe you kena con liao Link to post Share on other sites More sharing options...
Quantum 5th Gear September 3, 2012 Share September 3, 2012 hello all, I just got 2nd 2008 optra1.6M, few questions need to check with here, a. what is the original optra wheels size? current car is 185/65/R14 b. How many km need to change timing belt? current mileage close to70k c. what is the servicing interval mileage, 10k or 5k? Thanks alot Link to post Share on other sites More sharing options...
GoodCar 4th Gear September 3, 2012 Author Share September 3, 2012 now i got bigger problem, car sometimes feel like stalling, starting is not a problem, only sometimes need to crank longer. a few times car died off in a jam. i have no ideal what is wrong, i suspect its fuel pump. i have changed, filter filter, crank sensor cam sensor evg valve fuel line any advise? Need to hospitalise liao lah :). But frankly. I am only a car enthusiat Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 3, 2012 Share September 3, 2012 hello all, I just got 2nd 2008 optra1.6M, few questions need to check with here, a. what is the original optra wheels size? current car is 185/65/R14 b. How many km need to change timing belt? current mileage close to70k c. what is the servicing interval mileage, 10k or 5k? Thanks alot change timing belt at 60k your 10k over DUE! timing belt, tension, pulley from china is $300 total. Link to post Share on other sites More sharing options...
Oyq1989 1st Gear September 4, 2012 Share September 4, 2012 change timing belt at 60k your 10k over DUE! timing belt, tension, pulley from china is $300 total. Timing belt package from R.D.Y Autocare : 398$ Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 5, 2012 Share September 5, 2012 Timing belt package from R.D.Y Autocare : 398$ cheap yea? Link to post Share on other sites More sharing options...
Kwanheng 1st Gear September 5, 2012 Share September 5, 2012 Need to hospitalise liao lah :). But frankly. I am only a car enthusiat hope ok lor Link to post Share on other sites More sharing options...
Furrynadz 5th Gear September 7, 2012 Share September 7, 2012 Timing belt package from R.D.Y Autocare : 398$ make sure its whole package with the seals at side they cut corner and no include one go the stocklist at veresamy and buy and do elsewhere better Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 23, 2012 Share September 23, 2012 make sure its whole package with the seals at side they cut corner and no include one go the stocklist at veresamy and buy and do elsewhere better True. I get full set of parts incl waterpump ac belt n coolant n get my ws to change. Full peace of mind. Last time i chg at 70k km. Now coming 140k km i inspect all still in very good condition so i wil chg at 150k km. So although handbook say chg 60k km i now drag to 80k km. Hee. Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 23, 2012 Share September 23, 2012 Need Help! My 2005 chevrolet optra5 (A) 1.6L has FC of only about 8.3km/L stock car, 14" rims and driving as light as possible (rpm never more than 2500) Really no idea what's going on... When i bought my optra est auto also 9-10km/lit wh 14" steel rims. Then chg 16"sportrims got 10-12 km/lit. Then did grounding now getting 12-14 km/lit. Very happy wh this so no more mods to do. Hee. Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 23, 2012 Share September 23, 2012 Accelerate faster? will try to do that.. I realized my car is also jerking during idling and lots of vibrations. Read up some forum on the internet and they recommend resetting of ECU Has anyone tried to do that before? Chk yr sparkplugs n wires. Wire might hv crack n insulation damage. If u hv strong spark yr fc is better n smoother n more piwer. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant question
Coolant question
Car repair and maintenance
Chevrolet Orlando
Chevrolet Orlando
