Pisces69 6th Gear October 2, 2013 Share October 2, 2013 go market buy floor mat load thing put the floor mat there load finish put back in boot Ya that sud work. ↡ Advertisement Link to post Share on other sites More sharing options...
Resley1983 Neutral Newbie October 3, 2013 Share October 3, 2013 Car slightly higher or lower on one side might b normal. Sometimes it wil adjust itself when u drive. If yr shocks r worn out, then better to change. Did u chk the shocks r worn? I prefer to buy the shocks myself (much cheaper) n get my ws to fix for me. I buy 1pc abt $80. Ws provide 1pc abt $130. Oh mine is Optra but price sud b close. Remember after u change shocks, very important u need to do the 4 wheel computerised alignment to get all settings back to manufacturers specs. Thanks for your advise. I have checked. No leak or crack but when the vehicle goes over a hump there's ew ew sound on the right wheel. not sure is it the shock problem. Could provide me the address to buy the shock and also the ws? Thanks Link to post Share on other sites More sharing options...
Raceguysg Neutral Newbie October 3, 2013 Share October 3, 2013 ew ew sound might be jst a worn out bushing? Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 3, 2013 Share October 3, 2013 (edited) Thanks for your advise. I have checked. No leak or crack but when the vehicle goes over a hump there's ew ew sound on the right wheel. not sure is it the shock problem. Could provide me the address to buy the shock and also the ws? Thanks Chevy shocks I get from a // importer. Aik Hoe at Race Course Rd. WS I used to go Keng Wah Motor at Yishun Indl Pk A. Boss/mech is Ah Ting. Search here for the full address n tel no. Computerised 4 wheel alignment I do in JB cos all SG shops too damm expensive. Edited October 3, 2013 by Pisces69 Link to post Share on other sites More sharing options...
Resley1983 Neutral Newbie October 9, 2013 Share October 9, 2013 Thanks bro. I will go and take a look. Link to post Share on other sites More sharing options...
Archaic 1st Gear November 27, 2013 Share November 27, 2013 Help needed, please. My Optra air-con compressor need replacement. Called two stockists I'm familiar with and both said no stock. Anyone can help me? Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 27, 2013 Share November 27, 2013 Help needed, please. My Optra air-con compressor need replacement. Called two stockists I'm familiar with and both said no stock. Anyone can help me? U can try Markcool in Woodlands. See Ah Huat the foreman. I changed mine there to an OEM compressor las time. Abt $500. Link to post Share on other sites More sharing options...
Archaic 1st Gear November 28, 2013 Share November 28, 2013 U can try Markcool in Woodlands. See Ah Huat the foreman. I changed mine there to an OEM compressor las time. Abt $500. Thank you. Quoted about the same at a workshop in the West. 1 Link to post Share on other sites More sharing options...
Raysky Neutral Newbie January 9, 2015 Share January 9, 2015 anyone knows any stockist got supply the optra estate's coilover spring? Link to post Share on other sites More sharing options...
TyreShield 1st Gear January 10, 2015 Share January 10, 2015 (edited) I do have a Chevrolet OptraSS 1.6 , have felt vibrations sometimes, no idea where it originates, but mostly solved or greatly reduced by regularly adding engine protector additives such as "Power Up". The sound you are hearing could also be your Air Con Blower Fan . since much of the sound is indoors. You may also want to check the Power Steering Oil level as well. Cheers Edited January 10, 2015 by AneshMuniyandhi Link to post Share on other sites More sharing options...
Watwheels Supersonic January 10, 2015 Share January 10, 2015 anyone knows any stockist got supply the optra estate's coilover spring? Just Google lah. http://www.sgcarmart.com/directory/merchant.php?MID=11765 Link to post Share on other sites More sharing options...
Kklee 6th Gear January 10, 2015 Share January 10, 2015 I do have a Chevrolet OptraSS 1.6 , have felt vibrations sometimes, no idea where it originates, but mostly solved or greatly reduced by regularly adding engine protector additives such as "Power Up". The sound you are hearing could also be your Air Con Blower Fan . since much of the sound is indoors. You may also want to check the Power Steering Oil level as well. Cheers What engine oil are you using ? Link to post Share on other sites More sharing options...
Simonlow76 Neutral Newbie January 12, 2015 Share January 12, 2015 Help needed, please. My Optra air-con compressor need replacement. Called two stockists I'm familiar with and both said no stock. Anyone can help me? Help needed, please. My Optra air-con compressor need replacement. Called two stockists I'm familiar with and both said no stock. Anyone can help me? I've new oem timing belt for sale as a set. Selling at special pricing. Pls sms me at 97599935. Thank you. Link to post Share on other sites More sharing options...
Cbx750p 1st Gear April 26, 2015 Share April 26, 2015 Looking for a brand new Optra fuel pump as a spare ? Look here Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 27, 2015 Share April 27, 2015 Looking for a brand new Optra fuel pump as a spare ? Look here good bargain consider the original price according to seller is 1200 bucks. Link to post Share on other sites More sharing options...
Orangie Neutral Newbie June 3, 2015 Share June 3, 2015 My 2006 optra estate auto recently been stalling. Just got my car towed last week and ws replace fuel pump because cannot start. Maybe unrelated to stalling. Anyway back to stalling issue. Will experience this after parking for long time like 8hrs. Car can crank, start easily and idle just below 1krpm. Put in D and move off ( not stepping the accelator) have no problem. Once I step on the accelator to drive off and release, rpm goes up and dives to 0 and the engine stalls. This usually happens only on starting my journey. like park my car to go watch a football match kind of timing. Any bro got experience in such stall in optra? Thanks Link to post Share on other sites More sharing options...
Kklee 6th Gear June 3, 2015 Share June 3, 2015 (edited) My 2006 optra estate auto recently been stalling. Just got my car towed last week and ws replace fuel pump because cannot start. Maybe unrelated to stalling. Anyway back to stalling issue. Will experience this after parking for long time like 8hrs. Car can crank, start easily and idle just below 1krpm. Put in D and move off ( not stepping the accelator) have no problem. Once I step on the accelator to drive off and release, rpm goes up and dives to 0 and the engine stalls. This usually happens only on starting my journey. like park my car to go watch a football match kind of timing. Any bro got experience in such stall in optra? Thanks Vacuum hose leak? Actually just go to that workshop that a lot of Chevies goes to, should be able to solve. My retired early Optra, IIRC, - 5th year and 9th year alternator kaputz - 9th year fuel pump kaputz - 5th year change valve for AC compressor, 8th year change compressor. - throttle body, no change The most reliable parts are the shock absorbers - front changed at about 150k ( thought got problem ) and rear > 200k km never change. P.S. got towed twice in a month on the 9th year. Edited June 3, 2015 by Kklee Link to post Share on other sites More sharing options...
Orangie Neutral Newbie June 4, 2015 Share June 4, 2015 Thanks for sharing your experience. Was suspecting vacuum hose leak somewhere. Next suspect will be throttle body. One more yr to go... have to tiong, else buy BMW. WS where lots of chevy go to?? RXX? Never have much faith in their young mechanics. Will go look for my ah pek ws to take a look. Another thing I've notice. If the car is about to stall, the gear is not changing up. My gear changes at abt 2.5k rpm. The rpm can be at 3k to 4k rpm and the gear is not going up. Once let go of the accelator, the engine will stall. All this stalling usually happen after the car is parked for certain amount of time. Recently getting worse. It stalls when I'm rolling towards the red light on the right lane.What if I'm rolling at 90 on PIE right lane. This is a scary thought. ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Coolant question
Coolant question
Car repair and maintenance
Chevrolet Orlando
Chevrolet Orlando
