Tbt001 1st Gear March 31, 2020 Share March 31, 2020 On 6/17/2019 at 1:23 PM, richard_crl032 said: Hi Kenomi, Nope .. I had both. 1.2 is quieter when pushed while mazda 6 can be harsh but no doubt mazda 6 is quicker if pushed. The rush of the torque when 1.2l is maxed out gives the feeling of it going fast but it goes flat empty after that. I had the qashqai 1.2 for almost 2 yrs and the mazda 6 since Oct 2018. Btw, heavy footed me get 10-11km/l for the qashqai 1.2l compared to 12-13km/l for the mazda 6 ... even though preferring a high riding SUV, I did not miss the qashqai 1.2 ... hold out for new releases in UK are already 1.3 turbo with dual clutch which I would seriously watch out if ok since new and front renault for petrol ones: https://www.topgear.com/car-reviews/nissan/qashqai-0 Cheers. Richard Test drive the CX-30 and please pressure them to bring in the SkyActiv X engine. ↡ Advertisement Link to post Share on other sites More sharing options...
Tbt001 1st Gear March 31, 2020 Share March 31, 2020 On 8/4/2019 at 7:02 AM, kevinpolk said: As reported by Carlitus about 2020 Mazda6, they said it will setup with SkyActiv-X. What you think? I don't really sure about this. But, I'm sure this vehicle will equip with the latest engine of Mazda. SkyActiv-X is their latest engine: 2.0L. They are planning this tech for other engines as well. But sadly Singapore may not see this engine yet. Please put pressure on the dealer to bring in this engine option soon. Link to post Share on other sites More sharing options...
Tbt001 1st Gear March 31, 2020 Share March 31, 2020 On 9/18/2019 at 3:03 AM, kevinpolk said: Hi, I'm to this forum. I want to verify the news with you guys. What engine will new Mazda6 use? Skyactiv-X or D? I just found an article on Google that next-gen will use Skyactiv-D? Source: - https://www.mazdausa.com/mazda6-signature-skyactivd - https://www.carlitus.net/2020-mazda-6/ Most here are Skyactiv-G. The Skyactiv X is their newest super engine but it is only available in Europe on the CX 30 and Mz3. Go ask TEK when Singapore will catch up with this. Link to post Share on other sites More sharing options...
Tbt001 1st Gear March 31, 2020 Share March 31, 2020 On 12/11/2019 at 10:45 PM, GTO-1 said: If my understanding of oil ratings is correct the rating really determines the viscosity range of the oil at cold ambient temperatures and operating temp. The lower number represents viscosity in winter and the higher number represents viscosity at operating temp. The problems arise when during cold temps (ie winter), the oil isn't thin enough to lubricate the engine parts, so 0w-20 is important because at cold temps it's still thin enough to coat the engine parts. The thing is, the lower winter temperatures are rated at something like -25 degC, which is way below what we get in SG. So theoretically, 5w-40 is actually fine for the engine rated for oil that is 0w-20, because the ambient temperature of Sg means the oil will still be thin enough to operate. Don't get me wrong, you should always follow the manufacturers specifications, but the theory says its fine. Take a look at this diagram to give you an idea. Yes, the ratings indicate the viscosity of the oil. And the lower number is not relevant in Singapore because I cannot remember the last time we had winter. The higher number is relevant to Singapore's climate. The higher the number the more viscous (or thicker) the oil. Hence the 0W-20 oil is thinner, more efficient for the engine (slightly more power and slightly better FC) but being a thinner oil it will breakdown sooner. Hence the need to change more regularly. This is why for 0W-20, you should use a good synthetic oil. The other oil 5W-40 is thicker and hence less energy efficient. But it will last longer. It will not damage the engine. And you can use a longer interval for oil changes. Link to post Share on other sites More sharing options...
Tbt001 1st Gear March 31, 2020 Share March 31, 2020 16 hours ago, Dna_engine said: Really? Wow this will be as short as the Alfa 159 I use to have - 18 months at best. My wife’s NX200T had a battery change at 2.5 years. Any idea why the M6 is that short.? Any harm using a a larger battery in the M6 - my battery shop gave me a slight larger battery? Typically car batteries should last at least 1 year. 18 months is usual but some better brands can last 2 years. It also depends on whether you do lots of short trips, in-car camera running when you are parked, and other factors. The i-Stop feature is only a minor factor. When the engine re-starts from an i-stop it uses only a small fraction of the battery charge when compared to a normal start. The system has a large electrical capacitor which stores the energy harvested from the braking. This energy is not available in a normal start. I drive a 2016 Mazda 6 and I leave my i-stop on all the time. My original battery lasted slightly more than 2 years. TEK wanted too much money for a replacement battery so I went looking around for a 3rd party replacement. Guidelines: 1. Must be a EFB (Q85) or AGM battery. 2. Look for a capacity of at least 65 A=Hr (higher is better) 3. A cold crank current (CCA) of at least 60A. 4. Less than $200. 5. Professional workshop - ask them what they are going to do to prevent your radio settings and clock from being reset. Some workshops leave the engine running while the battery is changed but this is RISKY. 6. Make sure the battery can easily fit into the battery compartment. 7. Check the date of manufacture of the battery. A fresh one will last longer. I ended up buying a Varta Silver Dynamic (make sure it is made in Germany). But there are other good brand available. 2 Link to post Share on other sites More sharing options...
louisbosco 3rd Gear April 1, 2020 Share April 1, 2020 On 3/29/2020 at 12:03 AM, Dna_engine said: Mine lasted 1 year 7 months for the 2.5L wagon - agree with the fact that the stock batteries are not good. Changed to maintenance free type last Oct, let's see how long this one last. do you think battery will last differently depending on climate? my dad's friend in sg asking me about mazda 3 replacement battery. think only last 2 year plus. but my mazda 3 2.5L in australia, have been using the same battery. 5 years going on 6. still 91% health when i last checked. i never use istop since day 1 when i collected my car. only sometimes maybe in a rush forget but that is only a handful of times. whereas my dad friend just runs it normally without turning istop off. so.. technically besides climate, that is the only variable.. Link to post Share on other sites More sharing options...
Dna_engine 3rd Gear April 1, 2020 Share April 1, 2020 1 hour ago, louisbosco said: do you think battery will last differently depending on climate? my dad's friend in sg asking me about mazda 3 replacement battery. think only last 2 year plus. but my mazda 3 2.5L in australia, have been using the same battery. 5 years going on 6. still 91% health when i last checked. i never use istop since day 1 when i collected my car. only sometimes maybe in a rush forget but that is only a handful of times. whereas my dad friend just runs it normally without turning istop off. so.. technically besides climate, that is the only variable.. There is a possibility - my wife use to drive an E200K and the battery is located in the trunk, I only changed 2 batteries until we scrapped the car at 9.5 years. First batter from the factory lasted 4 years and I changed a second one on the 8th year because I was afraid the battery cannot last for another 2 years. Most of our batteries are in the engine compartment that gets very hot - my old Alfa 159's battery last only 13-14 months. Some may say it's due to dark current but I am not an engineer, so I do not have a clue what that means. Link to post Share on other sites More sharing options...
louisbosco 3rd Gear April 1, 2020 Share April 1, 2020 10 hours ago, Dna_engine said: There is a possibility - my wife use to drive an E200K and the battery is located in the trunk, I only changed 2 batteries until we scrapped the car at 9.5 years. First batter from the factory lasted 4 years and I changed a second one on the 8th year because I was afraid the battery cannot last for another 2 years. Most of our batteries are in the engine compartment that gets very hot - my old Alfa 159's battery last only 13-14 months. Some may say it's due to dark current but I am not an engineer, so I do not have a clue what that means. i meant more of climate between australia and singapore. tbh, there's not much differences except for humidity. perth doesn't get as cold as european or america anyway. i feel like it's down to istop. can't remember where i got the info but one of their engineers working on mazda told me that istop tends to drain more from the battery to restart the engine on the go. furthermore, during idle and the engine is cut, the power is draining from the battery. so i put it down to that as to why my battery is still going strong. as a side note, all/most european car battery is in the trunk. not sure if it helps keep out the coldness during winter or that's the way they design to free up space in the engine bay. my old BMW E90 M3 is also in the trunk. Link to post Share on other sites More sharing options...
t0y0ta Supercharged April 2, 2020 Share April 2, 2020 17 hours ago, Dna_engine said: There is a possibility - my wife use to drive an E200K and the battery is located in the trunk, I only changed 2 batteries until we scrapped the car at 9.5 years. First batter from the factory lasted 4 years and I changed a second one on the 8th year because I was afraid the battery cannot last for another 2 years. Most of our batteries are in the engine compartment that gets very hot - my old Alfa 159's battery last only 13-14 months. Some may say it's due to dark current but I am not an engineer, so I do not have a clue what that means. I agree with you that batteries out of the engine compartment probably can last longer, I believe it is the heat from engine causing deterioration. my NX200t batteries all change at 1.5 years. Link to post Share on other sites More sharing options...
teomingern Supercharged April 3, 2020 Share April 3, 2020 On 4/1/2020 at 1:03 PM, louisbosco said: do you think battery will last differently depending on climate? my dad's friend in sg asking me about mazda 3 replacement battery. think only last 2 year plus. but my mazda 3 2.5L in australia, have been using the same battery. 5 years going on 6. still 91% health when i last checked. i never use istop since day 1 when i collected my car. only sometimes maybe in a rush forget but that is only a handful of times. whereas my dad friend just runs it normally without turning istop off. so.. technically besides climate, that is the only variable.. Not sure if it's just the climate or it's more the distance travelled per journey... the longer each journey is, the better for the battery cos it has the time to charge back properly and fully... but our very short trips in Singapore at low speeds depletes the batteries which don't fully charge back properly. That's my take. 1 Link to post Share on other sites More sharing options...
Dna_engine 3rd Gear April 5, 2020 Share April 5, 2020 On 4/2/2020 at 8:39 AM, t0y0ta said: I agree with you that batteries out of the engine compartment probably can last longer, I believe it is the heat from engine causing deterioration. my NX200t batteries all change at 1.5 years. Wow, 1.5 years is quite short. My wife's NX200T was changed at 2.5 years, maybe because she only drives to the office and back - her car is 4 years old now and mileage is 42k. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear April 5, 2020 Share April 5, 2020 (edited) On 3/31/2020 at 9:53 AM, Tbt001 said: Test drive the CX-30 and please pressure them to bring in the SkyActiv X engine. Hi Tbt001, I would only want turbo charged mazda6 if I have my wish ... get full electric or hybrid since petrol engine will meet its evitable end .. skyactive x or y or z isnt too interesting for me. Cheers Richard Edited April 5, 2020 by richard_crl032 Link to post Share on other sites More sharing options...
cckboy 2nd Gear April 7, 2020 Share April 7, 2020 Hi all Mazda6 owners, hope you all doing well in this CB period 🙂 I discovered 2 issues on my car recently, would like to seek advice on anyone who experience these before... 1. My side mirror retract (close) well when I remote lock the car. However it cannot finished expand (open) when I remote unlock. If I apply a little bit of force during it expands, it can expand completely. Motor problem? Heard Mazda 6 got side mirror issue, is that something like this? 2. When I Push Start the engine, there is a 'krrrrrkk" sound from the dash board. The sounds is a little bit like motor/gear jam like that. It only happen during the FIRST engine start after unlock the car. If I off the engine and restart again, there is no such sound. (Attached a video below) Currently Mazda close their service center, have to wait until May for the service check. So would like to first consult the owners here. Thank you! video.mp4 Link to post Share on other sites More sharing options...
ER-3682 Supersonic April 7, 2020 Share April 7, 2020 11 hours ago, cckboy said: Hi all Mazda6 owners, hope you all doing well in this CB period 🙂 I discovered 2 issues on my car recently, would like to seek advice on anyone who experience these before... 1. My side mirror retract (close) well when I remote lock the car. However it cannot finished expand (open) when I remote unlock. If I apply a little bit of force during it expands, it can expand completely. Motor problem? Heard Mazda 6 got side mirror issue, is that something like this? 2. When I Push Start the engine, there is a 'krrrrrkk" sound from the dash board. The sounds is a little bit like motor/gear jam like that. It only happen during the FIRST engine start after unlock the car. If I off the engine and restart again, there is no such sound. (Attached a video below) Currently Mazda close their service center, have to wait until May for the service check. So would like to first consult the owners here. Thank you! video.mp4 Mirror are common problem,as for the Video,seems like it is from Starter....you may send the Video to Agent,& wait for their reply. Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear April 8, 2020 Share April 8, 2020 On 3/31/2020 at 2:02 PM, Tbt001 said: Yes, the ratings indicate the viscosity of the oil. And the lower number is not relevant in Singapore because I cannot remember the last time we had winter. The higher number is relevant to Singapore's climate. The higher the number the more viscous (or thicker) the oil. Hence the 0W-20 oil is thinner, more efficient for the engine (slightly more power and slightly better FC) but being a thinner oil it will breakdown sooner. Hence the need to change more regularly. This is why for 0W-20, you should use a good synthetic oil. The other oil 5W-40 is thicker and hence less energy efficient. But it will last longer. It will not damage the engine. And you can use a longer interval for oil changes. If based on your post, why not use a 5W-50 or 10W-60? Won't it extend the change interval to a longer period? Link to post Share on other sites More sharing options...
cckboy 2nd Gear April 8, 2020 Share April 8, 2020 5 hours ago, ER-3682 said: Mirror are common problem,as for the Video,seems like it is from Starter....you may send the Video to Agent,& wait for their reply. Thanks @ER-3682! The common problem in side mirror is due to the motor/gear? any idea how they gonna fix that? For the weird sound, not sure whether it is due to starter because it happen only on the first engine start after car unlock. there is no such sound on subsequent engine starts as long as you dont lock and unlock your car. I've scheduled a check-up, just have to wait for a while. Not much driving nowadays too. 🙂 Link to post Share on other sites More sharing options...
jessenchan Clutched April 8, 2020 Share April 8, 2020 On 11/19/2010 at 10:19 AM, Voxy28 said: How come this model like no value one? 5k dep nia... Sell that time should be 4k...... jialat. Is it a problematic car? resale value not very good but mazda have so much feature that toyota and honda dont have Link to post Share on other sites More sharing options...
ER-3682 Supersonic April 8, 2020 Share April 8, 2020 6 hours ago, cckboy said: Thanks @ER-3682! The common problem in side mirror is due to the motor/gear? any idea how they gonna fix that? For the weird sound, not sure whether it is due to starter because it happen only on the first engine start after car unlock. there is no such sound on subsequent engine starts as long as you dont lock and unlock your car. I've scheduled a check-up, just have to wait for a while. Not much driving nowadays too. 🙂 Both Motor & Gear...change New one. ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda 6e
2025 Mazda 6e
Honda City 4th Gen
Honda City 4th Gen
2026 8th Generation Lexus ES
