Mkl22 Supersonic April 22, 2023 Share April 22, 2023 On 4/22/2023 at 6:17 AM, ER-3682 said: @Nakazato88 I bought the Mazda 6..2.5 on 2013,1st few Cars for this model & sold it in 2021 Aug after the i-Eloop failed,at 103,000km..hope your Car less than 100,000Km. Wah. You believe in high paper value of the coe! 🤣 ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Supersonic April 22, 2023 Share April 22, 2023 On 4/22/2023 at 3:42 AM, Nakazato88 said: @ER-3682 thank you for the advice. got my car check. it was the stabilizer link spoil. ask them to clean up the throttle body. still monitering the rpm . still a little bit of plunge down when idle . Maybe can try KHY. Link to post Share on other sites More sharing options...
Nakazato88 Neutral Newbie April 23, 2023 Share April 23, 2023 did they told u wat was the issue? Link to post Share on other sites More sharing options...
Nakazato88 Neutral Newbie April 23, 2023 Share April 23, 2023 @ER-3682 hopefully mine can last longer 😅 Link to post Share on other sites More sharing options...
Nakazato88 Neutral Newbie April 23, 2023 Share April 23, 2023 @ER-3682 wat is KHY? ps ar don know wat it mean haha.. Link to post Share on other sites More sharing options...
ER-3682 Supersonic April 23, 2023 Share April 23, 2023 On 4/24/2023 at 1:13 AM, Nakazato88 said: @ER-3682 wat is KHY? ps ar don know wat it mean haha.. KHY is a Honest & Friendly Workshop in Sin Ming,used by alot of Members in the Mazda 6 WhatsApp Chat Group. Link to post Share on other sites More sharing options...
Nakazato88 Neutral Newbie May 18, 2023 Share May 18, 2023 Any bros here using 18 inch wheel? Currently i running on stock 19. Wonder if i down size to 18 izzit ok? Like 245/40/18 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 18, 2023 Share May 18, 2023 On 5/18/2023 at 5:02 PM, Nakazato88 said: Any bros here using 18 inch wheel? Currently i running on stock 19. Wonder if i down size to 18 izzit ok? Like 245/40/18 Use 18'' wheel,fit 225/50 or 245/45 Tyres to maintain the same Diameter. 2 Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear May 19, 2023 Share May 19, 2023 On 5/18/2023 at 5:02 PM, Nakazato88 said: Any bros here using 18 inch wheel? Currently i running on stock 19. Wonder if i down size to 18 izzit ok? Like 245/40/18 225/50 as suggested by ER-3682 would be better than 245 as it is wide enough to give traction and since it is narrower, the fuel efficiency will be higher and the risk of aquaplaning will be lower. Link to post Share on other sites More sharing options...
Nakazato88 Neutral Newbie May 19, 2023 Share May 19, 2023 @andrewyewkc arrr ok ok coz i prefer wider and it can flush nicer. Fc so far no complain for this 2.5. Maybe i will get 18inch 8jj or 8.5jj 1 Link to post Share on other sites More sharing options...
Banz86 5th Gear May 19, 2023 Share May 19, 2023 I'm using 225/50r18 for my ride. 1 Link to post Share on other sites More sharing options...
R32 4th Gear May 19, 2023 Share May 19, 2023 (edited) On 5/18/2023 at 9:26 PM, ER-3682 said: Use 18'' wheel,fit 225/50 or 245/45 Tyres to maintain the same Diameter. Downsized from factory 19 to 18 inch, kept the rim width at 7.5 inches. Tires are 225/50/18. Stock rims were 14.5kg each and these Advans were 8kg each. I did it more for the ride comfort than the weight though. Edited May 19, 2023 by R32 3 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged May 20, 2023 Share May 20, 2023 On 5/18/2023 at 5:02 PM, Nakazato88 said: Any bros here using 18 inch wheel? Currently i running on stock 19. Wonder if i down size to 18 izzit ok? Like 245/40/18 @Nakazato88 Your current tyre and wheel combo is 225/45R19 rim offset +45? Link to post Share on other sites More sharing options...
Nakazato88 Neutral Newbie May 20, 2023 Share May 20, 2023 @R32 nice rims.. Link to post Share on other sites More sharing options...
Nakazato88 Neutral Newbie May 20, 2023 Share May 20, 2023 @DOBIEMKZ currently is stock . Yup that combo Link to post Share on other sites More sharing options...
tanwm 3rd Gear May 26, 2023 Share May 26, 2023 Anyone here install remote start on their Mazda 6? Link to post Share on other sites More sharing options...
MatzudaZoomZoom Neutral Newbie June 22, 2023 Share June 22, 2023 hi is there a way to find out a Mazda 6’s manufactured month and year? I found online that it can be found on the B pillar, on the driver’s door jam side, but i dont have it on mineee, thanks! Link to post Share on other sites More sharing options...
mogoloop Clutched June 25, 2023 Share June 25, 2023 Hi, my start button is blinking amber. Replaced the key fob batteries but no luck. Any ideas how to fix it? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda 6e
2025 Mazda 6e
Honda City 4th Gen
Honda City 4th Gen
2026 8th Generation Lexus ES
