Skywire Neutral Newbie July 18, 2022 Share July 18, 2022 TEK diagnosed the problem to the faulty start/stop cable and have replaced it. I will monitor again. Thanks. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Lhk657 2nd Gear July 28, 2022 Share July 28, 2022 Dear bros, Need some recommendations. 1. Where to find / how to know our vehicle model/code to buy parts and assessories like cabin and engine filter. My M6 is the current model with the chrome brows beneath the front headlights. 2. Any shops to recommend for cabin and engine filter, brake pads? 3. How much for the the above items? Link to post Share on other sites More sharing options...
Koster 4th Gear July 28, 2022 Share July 28, 2022 5 hours ago, Lhk657 said: Dear bros, Need some recommendations. 1. Where to find / how to know our vehicle model/code to buy parts and assessories like cabin and engine filter. My M6 is the current model with the chrome brows beneath the front headlights. 2. Any shops to recommend for cabin and engine filter, brake pads? 3. How much for the the above items? If u want original ones, just give your chassis number to the Mazda stockists and they will know what to do. As for price, best to ask them. Can email if it's not urgent. Link to post Share on other sites More sharing options...
Lhk657 2nd Gear July 31, 2022 Share July 31, 2022 Can recommend mazda stockist? Chasis no. Is found under the bonnet rite? Link to post Share on other sites More sharing options...
R32 4th Gear July 31, 2022 Share July 31, 2022 1 hour ago, Lhk657 said: Can recommend mazda stockist? Chasis no. Is found under the bonnet rite? I think driver side door frame. You can also go on LTA onemotoring to enquire the car as an asset under your name Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 31, 2022 Share July 31, 2022 13 hours ago, Lhk657 said: Can recommend mazda stockist? Chasis no. Is found under the bonnet rite? Lift up the Driver's Carpet,there is a Plastic Cover. Link to post Share on other sites More sharing options...
zenooi Clutched August 22, 2022 Share August 22, 2022 Hi, anyone can intro andriod player for 2017 mazda? Size 10inch and above thanks Link to post Share on other sites More sharing options...
zenooi Clutched October 17, 2022 Share October 17, 2022 Hi guys, my 2017 2.5L mazda 6 has some engine oil issue to check if there is anyone who has experienced the same. 7,000km after servicing - the engine oil check on the stick is below the lowest hole. Had to top up another 1.8L and end up it is above the 2nd hole. No leaking as checked on the floor. Link to post Share on other sites More sharing options...
t0y0ta Supercharged October 17, 2022 Share October 17, 2022 19 minutes ago, zenooi said: Hi guys, my 2017 2.5L mazda 6 has some engine oil issue to check if there is anyone who has experienced the same. 7,000km after servicing - the engine oil check on the stick is below the lowest hole. Had to top up another 1.8L and end up it is above the 2nd hole. No leaking as checked on the floor. Engine oil consumption. Could be jialat liao if it is not due to leaking head gasket etc Link to post Share on other sites More sharing options...
ER-3682 Supersonic October 17, 2022 Share October 17, 2022 8 hours ago, zenooi said: Hi guys, my 2017 2.5L mazda 6 has some engine oil issue to check if there is anyone who has experienced the same. 7,000km after servicing - the engine oil check on the stick is below the lowest hole. Had to top up another 1.8L and end up it is above the 2nd hole. No leaking as checked on the floor. Never Heard of it,my Car used for 120,000Km,8.5 Years never eat Oil. Link to post Share on other sites More sharing options...
L23 6th Gear October 19, 2022 Share October 19, 2022 On 10/17/2022 at 12:51 PM, zenooi said: Hi guys, my 2017 2.5L mazda 6 has some engine oil issue to check if there is anyone who has experienced the same. 7,000km after servicing - the engine oil check on the stick is below the lowest hole. Had to top up another 1.8L and end up it is above the 2nd hole. No leaking as checked on the floor. Some suggestions for you: 1. Time to get a new car. 2. Send it to the AD for a check. 3. It could be an one-off issue. Observe it first. Link to post Share on other sites More sharing options...
zenooi Clutched October 20, 2022 Share October 20, 2022 Thanks guys for the reply. Now at 137,000km sending back AD at 140k. Hope it is a leak that can be fixed. Engine smooth as silk still though. Link to post Share on other sites More sharing options...
sinistral 1st Gear October 21, 2022 Share October 21, 2022 9 hours ago, zenooi said: Thanks guys for the reply. Now at 137,000km sending back AD at 140k. Hope it is a leak that can be fixed. Engine smooth as silk still though. Did you observe any oil stains around the engine itself? At 137k, some gaskets may be failing already. Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear October 21, 2022 Share October 21, 2022 10 hours ago, zenooi said: Thanks guys for the reply. Now at 137,000km sending back AD at 140k. Hope it is a leak that can be fixed. Engine smooth as silk still though. This is quite unusual. I think you should call the AD and ask rather than wait for servicing. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 21, 2022 Share October 21, 2022 On 10/17/2022 at 12:51 PM, zenooi said: Hi guys, my 2017 2.5L mazda 6 has some engine oil issue to check if there is anyone who has experienced the same. 7,000km after servicing - the engine oil check on the stick is below the lowest hole. Had to top up another 1.8L and end up it is above the 2nd hole. No leaking as checked on the floor. How did you check the oil level? Did you let your car sit for at least 30mins before pulling the dipstick? Link to post Share on other sites More sharing options...
zenooi Clutched October 21, 2022 Share October 21, 2022 @Watwheels hi, yes overnight then test in the morning before starting the car Link to post Share on other sites More sharing options...
zenooi Clutched October 21, 2022 Share October 21, 2022 @sinistral ok will check this Link to post Share on other sites More sharing options...
zenooi Clutched October 21, 2022 Share October 21, 2022 @andrewyewkc ok got it ↡ Advertisement Link to post Share on other sites More sharing options...
Honda City 4th Gen
Honda City 4th Gen
2025 Mazda 6e
2025 Mazda 6e
2026 8th Generation Lexus ES
2026 Mazda EZ-60 / CX-6e
Camry, Accord, Teana which is more Luxurious?
