Trex101 3rd Gear May 16, 2012 Share May 16, 2012 Normal maintenance of auto gear box are just fluid change, no need go to specialist unless there is some mechanical fault. As for your Honda, i would suggest you do your auto oil change every 30-40k km, upgrade your auto fluid to honda dw-1 as Z-1 has been superseded since 1yr ago. ↡ Advertisement Link to post Share on other sites More sharing options...
Donut Supercharged May 16, 2012 Share May 16, 2012 Normal maintenance of auto gear box are just fluid change, no need go to specialist unless there is some mechanical fault. As for your Honda, i would suggest you do your auto oil change every 30-40k km, upgrade your auto fluid to honda dw-1 as Z-1 has been superseded since 1yr ago. bro, this one cannot be used for honda CVT gear, right? Link to post Share on other sites More sharing options...
Elviskua Clutched May 16, 2012 Share May 16, 2012 try ellipse auto transmission at sin ming did my repair last yr on vios auto tranny in no time and price quoted is much cheaper than khang auto. For GearBox or Auto Transmission, just go to Ellipse Auto Transmission at sin ming 64560090 will do. Overall results is good and low cost. Link to post Share on other sites More sharing options...
Danieltcs Neutral Newbie May 16, 2012 Share May 16, 2012 If you are a Subaru owner you may wanna chk this out: http://www.bamp.com.sg/dealview/1/4/122/32...aru-at-bks.html Link to post Share on other sites More sharing options...
Trex101 3rd Gear May 16, 2012 Share May 16, 2012 No cannot, for honda CVT fluid you have to use Honda CVTF or HMMF but can also consider Eneos CVT fluid as we have alot of feedback from customers that the "lock-up" from Eneos seem faster, less rubber band effect. Link to post Share on other sites More sharing options...
Donut Supercharged May 16, 2012 Share May 16, 2012 No cannot, for honda CVT fluid you have to use Honda CVTF or HMMF but can also consider Eneos CVT fluid as we have alot of feedback from customers that the "lock-up" from Eneos seem faster, less rubber band effect. Eneos CVT fluid? supposed to be better than Honda CVTF? ok, i have been using Honda CVTF. Will try Eneos next time. got chop guaranteed confirm my gear box won't up lorry or not? Link to post Share on other sites More sharing options...
Babybaby87 Neutral Newbie May 17, 2012 Share May 17, 2012 Can try KATC Autotrans at Tan Chong Toa Payoh also. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear May 17, 2012 Share May 17, 2012 bro, this one cannot be used for honda CVT gear, right? If you are using the Honda CVT...get the Hondamatic CVT oil...one tine swee swee for one gearbox. You can get at Tanly Auto or from Kah Motor...price not that diff. Link to post Share on other sites More sharing options...
Jflcorp Neutral Newbie May 17, 2012 Share May 17, 2012 Eneos CVT fluid? supposed to be better than Honda CVTF? ok, i have been using Honda CVTF. Will try Eneos next time. got chop guaranteed confirm my gear box won't up lorry or not? Honda fluids are just rebranded. The manufacturer is Idemitsu if I am correct.... Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 17, 2012 Share May 17, 2012 Honda fluids are just rebranded. The manufacturer is Idemitsu if I am correct.... all Honda or car manufacturers' parts are rebranded or made by OEM. They design and assemble vehicles. Link to post Share on other sites More sharing options...
Trex101 3rd Gear May 17, 2012 Share May 17, 2012 Look like this, suitable for Honda Multimatic CVT. Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 17, 2012 Share May 17, 2012 Look like this, suitable for Honda Multimatic CVT. look like been under the sun for too long............ Link to post Share on other sites More sharing options...
Trex101 3rd Gear May 17, 2012 Share May 17, 2012 (edited) Under the Sun good leh, i always bring lots of hard to find stuffs in, even the hard to find GC i also manage to find it after some many years. Got to bring one box home for my next oil change. Edited May 17, 2012 by Trex101 Link to post Share on other sites More sharing options...
Donut Supercharged May 17, 2012 Share May 17, 2012 Look like this, suitable for Honda Multimatic CVT. Thanks. Will try this next time It's true Honda consumables are rebranded OEM Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 17, 2012 Share May 17, 2012 but price plays a part too. OEM fluids at times are even more ex than original one....... Link to post Share on other sites More sharing options...
5936 1st Gear June 23, 2012 Share June 23, 2012 During the first 40k, I paid for ATF fluid replacement. Not sure if it was done at all or used the correct fluid. as there is no dipstick to check, only filling and drain plugs. Now for the 100k km, I decided to buy ATF fluid and get mechanics to change it. Using Toyota ATF WS as specified in manu at RM $105 per 4L tin. When oil ATF fluid from both transmission and rear GB were drained out,to my surprise it was still fresh red and clean. Link to post Share on other sites More sharing options...
KaKiLang 4th Gear June 23, 2012 Share June 23, 2012 Do a full flush, drain and topup not thorough, the diff is almost a litre of fluid remain inside the gb. Link to post Share on other sites More sharing options...
5936 1st Gear June 23, 2012 Share June 23, 2012 Do we need to replace ATF fluid if WS spec fluid is used? I have this worry too, and thus the recent replacement, but the old ATF drained out, revealed, similar colour as new ATF Especially those drained from rear axle, 4 yrs. ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Coolant question
Coolant question
Car repair and maintenance
