Celicar Turbocharged February 26, 2014 Share February 26, 2014 I see. Ya, I refer to when use gear stick to shift that time, not the internal gear shifts. Maybe cos my previous auto trans car not so noisy, so now I a bit disturbed. If you shift from D to P or R the sound is quite normal. But if the sound is from 1st to 2nd to 3rd etc when driving, worth to do a check of the GB. ↡ Advertisement Link to post Share on other sites More sharing options...
Simpleonly 5th Gear February 27, 2014 Share February 27, 2014 The Lucasoil mentioned is not for oil leaks. Although its a very old n reputable brand, maybe u can check if ty hv something for Autobox oil leaks? There r many products out there. Some do nothing. Some work but some wil destroy yr autobox in a short time. Since yr leak is small n only 2 years to scrap, u can try some reputable products that stop the seal from leaking till u scrap. I also have very little confidence in the workmanship at the agents. I trust the information I get in here more. Just to update on the Lucas oil, got 1 via Amazon and use it during my atf change ard 2 month bk. It didn't help on the leak, but can feel gear change is much smoother. So for now, I will just top up a bit atf when required.. Anyway my car left 20 months... Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 27, 2014 Share February 27, 2014 (edited) I feel that Honda cars auto tranny should be fail proof for the first 10 years In general now most cars, Jap/Korean the autobox all very reliable. Unfortunately sometimes an ignorant mechanic try to do something but end up he put either wrong ATF inside or fill too much or too little n cause damage to the autobox. Of course when yr autobox spoil, he not going to come foreward n say he is responsible. Thats why some autobox r sealed so to prevent any untrained mech from doing something to it n spoil it. Thats also why I wil tell the ws what I want to change n when n I wil buy my own fluids/parts n hand to them n I stand there n supervise ty use the correct fluids n do it properly. Thats the only way to ensure an untrained mech dun screw up yr car. Edited February 27, 2014 by Pisces69 Link to post Share on other sites More sharing options...
zhane Neutral Newbie March 7, 2014 Share March 7, 2014 my car when shift from gear 1 to 2 will jerk forward abit but normal for every other shifts... any idea what could be e prob? Link to post Share on other sites More sharing options...
Matoonia 6th Gear March 7, 2014 Share March 7, 2014 my car when shift from gear 1 to 2 will jerk forward abit but normal for every other shifts... any idea what could be e prob? what car are u driving ? Wat's the mileage? if u nvr change atf before, try and see if it helps Link to post Share on other sites More sharing options...
zhane Neutral Newbie March 7, 2014 Share March 7, 2014 what car are u driving ? Wat's the mileage? if u nvr change atf before, try and see if it helps a mazda 3 just got it like a while ago from a seller... duno whether change b4.. but juz after buying, a workshop check for me say the fluid ok mileage >150k liao change atf will help ah? Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 7, 2014 Share March 7, 2014 a mazda 3 just got it like a while ago from a seller... duno whether change b4.. but juz after buying, a workshop check for me say the fluid ok mileage >150k liao change atf will help ah? try changing using amsoil and it may work but after some time, it revert back. mazda 3 autotrans is not exactly that lasting. Link to post Share on other sites More sharing options...
zhane Neutral Newbie March 7, 2014 Share March 7, 2014 try changing using amsoil and it may work but after some time, it revert back. mazda 3 autotrans is not exactly that lasting. revert back to mazda's atf? Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 7, 2014 Share March 7, 2014 revert back to mazda's atf? revert back to jerkiness after 3 months. worn autotrans is irreversible. No harm giving it a try. Link to post Share on other sites More sharing options...
zhane Neutral Newbie March 7, 2014 Share March 7, 2014 revert back to jerkiness after 3 months. worn autotrans is irreversible. No harm giving it a try. it feels like suddenly move forward the moment it hit 2nd gear wonder if such prolong jerkiness will spoil the gearbox Link to post Share on other sites More sharing options...
Friendstar Supercharged March 7, 2014 Share March 7, 2014 Jerkiness is certainly a sign of problem to come. Prolonged jerkiness will not cause a problem. but is a symptom of a problem itself Link to post Share on other sites More sharing options...
zhane Neutral Newbie March 7, 2014 Share March 7, 2014 Jerkiness is certainly a sign of problem to come. Prolonged jerkiness will not cause a problem. but is a symptom of a problem itself tml going workshop to check... hopefully they can tell me whats wrong Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 7, 2014 Share March 7, 2014 tml going workshop to check... hopefully they can tell me whats wrong almost guarantee you that they will advice for an overhaul. what you describe is a symptom of autotrans that needs an overhaul. Link to post Share on other sites More sharing options...
Matoonia 6th Gear March 7, 2014 Share March 7, 2014 Anyway just to check how old is your car. If left less than 2 years then dun waste money overhaul. If still got some life in it, might be worth to do an overhaul Link to post Share on other sites More sharing options...
zhane Neutral Newbie March 7, 2014 Share March 7, 2014 almost guarantee you that they will advice for an overhaul. what you describe is a symptom of autotrans that needs an overhaul. Anyway just to check how old is your car. If left less than 2 years then dun waste money overhaul. If still got some life in it, might be worth to do an overhaul left 1yr nia whats the worst that can happen if leave alone? Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 8, 2014 Share March 8, 2014 left 1yr nia whats the worst that can happen if leave alone? autotrans will slip to a point where it wont engage anymore and of course, get stranded and dont move. suggest you try the amsoil atf + lucas transmission addictive for short term relieve. It worked for my car and yes, drive sedately for now to reduce further wear. Link to post Share on other sites More sharing options...
zhane Neutral Newbie March 8, 2014 Share March 8, 2014 autotrans will slip to a point where it wont engage anymore and of course, get stranded and dont move. suggest you try the amsoil atf + lucas transmission addictive for short term relieve. It worked for my car and yes, drive sedately for now to reduce further wear. i went workshop today... but the problem didnt appear when I was there they used some machine to check my gearbox, but there wasnt any error code it seems that after a little driving, the jerk will disappear... cause the jerk came back after i left the workshop, went elsewhere and parked for a while. Link to post Share on other sites More sharing options...
Matoonia 6th Gear March 10, 2014 Share March 10, 2014 i went workshop today... but the problem didnt appear when I was there they used some machine to check my gearbox, but there wasnt any error code it seems that after a little driving, the jerk will disappear... cause the jerk came back after i left the workshop, went elsewhere and parked for a while. Your car left one year only. Just leave it alone. At most change ATF. Don't spend unnecessarily, save $ for your next ride ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Coolant question
Coolant question
Car repair and maintenance
