KARTer 2nd Gear April 6, 2012 Share April 6, 2012 You guys may have between 1-30 years of driving experience, or more. If you take the test again today, what chances you think you will pass, 80%, or less? Or 100% sure pass? If your answer is not 100% or 110%, what mistakes you think will likely fail you? My chances are 50/50, due to:- A. Failure to give signals B. Failure to make full stop coming out from side road C. Failure to keep eyes on the road full time (this one really can't be help, too many XMM around D. 90% of the other items on the tester's Checklist ↡ Advertisement Link to post Share on other sites More sharing options...
So_nice 6th Gear April 6, 2012 Share April 6, 2012 based on the checklist might fail too. parking is the 1st one! hahaha Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic April 6, 2012 Share April 6, 2012 You guys may have between 1-30 years of driving experience, or more. If you take the test again today, what chances you think you will pass, 80%, or less? Or 100% sure pass? If your answer is not 100% or 110%, what mistakes you think will likely fail you? My chances are 50/50, due to:- A. Failure to give signals B. Failure to make full stop coming out from side road C. Failure to keep eyes on the road full time (this one really can't be help, too many XMM around D. 90% of the other items on the tester's Checklist Too many to list down, that will cause me to fail Link to post Share on other sites More sharing options...
Sunlight 1st Gear April 6, 2012 Share April 6, 2012 i confirm will fail both practical and theory. Link to post Share on other sites More sharing options...
KARTer 2nd Gear April 6, 2012 Author Share April 6, 2012 based on the checklist might fail too. parking is the 1st one! hahaha Eh, how come? Dont think so lah, i always thought we may fail other items but not parking..... Or at least only fail parallel one? You driving container truck? Link to post Share on other sites More sharing options...
Poker Neutral Newbie April 6, 2012 Share April 6, 2012 I'll fail for sure:) coz will try to wayang that i can drive like a 'good' driver, then most prob make stupid mistakes that i wont make in everyday driving happened when i did my auto to manual conversion.. failed for driving too slowly (due to wayang) Link to post Share on other sites More sharing options...
1fast1 Supersonic April 6, 2012 Share April 6, 2012 Neither because I think I can make the tester die of a heart attack before the test is over. Link to post Share on other sites More sharing options...
KARTer 2nd Gear April 6, 2012 Author Share April 6, 2012 I'll fail for sure:) coz will try to wayang that i can drive like a 'good' driver, then most prob make stupid mistakes that i wont make in everyday driving happened when i did my auto to manual conversion.. failed for driving too slowly (due to wayang) Moral of the story:- drive naturally, no wayanging? Link to post Share on other sites More sharing options...
KARTer 2nd Gear April 6, 2012 Author Share April 6, 2012 Neither because I think I can make the tester die of a heart attack before the test is over. Come to think of it, such re-tests will create new job opportunities:- half the current team of testers will have to be replaced due to "early retirement", mass burial is very likely to follow. Link to post Share on other sites More sharing options...
Jp66 5th Gear April 6, 2012 Share April 6, 2012 One item sure fail is 'speeding' Link to post Share on other sites More sharing options...
Passion 5th Gear April 6, 2012 Share April 6, 2012 My first failure mistake will be stop over stop line. Normally I cannot see I'll stop after the line to see. I find it quite stupid to stop before the stop line then inch forward. For fu*k? Just go to the point you think is ok and not causing inconvenience for others will be ok what. Link to post Share on other sites More sharing options...
Throttle2 Supersonic April 6, 2012 Share April 6, 2012 confirm will pass Link to post Share on other sites More sharing options...
Jp66 5th Gear April 6, 2012 Share April 6, 2012 confirm will pass zun bo? Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched April 6, 2012 Share April 6, 2012 i think i will also pass Link to post Share on other sites More sharing options...
Old-driver 5th Gear April 6, 2012 Share April 6, 2012 After so many years of driving, i hv no doubt I will pass Link to post Share on other sites More sharing options...
Neutralsg 5th Gear April 7, 2012 Share April 7, 2012 You guys may have between 1-30 years of driving experience, or more. If you take the test again today, what chances you think you will pass, 80%, or less? Or 100% sure pass? If your answer is not 100% or 110%, what mistakes you think will likely fail you? My chances are 50/50, due to:- A. Failure to give signals B. Failure to make full stop coming out from side road C. Failure to keep eyes on the road full time (this one really can't be help, too many XMM around D. 90% of the other items on the tester's Checklist Many drivers who bring along their 'bad habits' after obtaining their 1st driving licence will inadvertently fail for the following reasons: 1) overconfident 2) missed using the signal lights 3) failing to stop completely before a stop sign, check left, right before proceeding 4) failure to check or improper checking of blind spot (this is one common mistake which adds on to the demerit points) 5) ignoring speed limit 6) improper stopping procedure i.e., failure to put gear in neutral / parking / pull hand brake 7) having only a single hand on the steering wheel while waiting to proceed etc.. etc... Had gone through this route moons ago and can confirm that the retest was virtually faultless to the extent the tester asked why I had to go for a retest. Hence, the repentance. Have a nice weekend! Link to post Share on other sites More sharing options...
Qpik Supercharged April 7, 2012 Share April 7, 2012 Confirmed will pass provided tester stays awake. Link to post Share on other sites More sharing options...
Rncw 5th Gear April 7, 2012 Share April 7, 2012 yes...failure to check blind spot is the killer ↡ Advertisement Link to post Share on other sites More sharing options...
hello
hello
hello
hello
Boomers on the road should take mandatory tests
PSA: Driving in Malaysia and How To Handle Accidents and Theft
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Another Kungfu actor/master pass away
Any good private driving instructor to recommend?
Class 4 Driving License
