Changing battery experience sharing
Mikelcy1963
Hypersonic
Start / run the engine and start changing battery is the correct method as:-
- prevent ECU lost of memory and out of tune of engine tuning setting
- prevent hassle of re-setting your radio & cabin clock
Fyi, once car start (Engine running) alternator will take over the battery to provide current to your ride and that's correct operational way and if battery been disconnect & engine die off means alternator is not charging your ride already & it's time to be caution of alternator defective got to send in for WS check !!
Please stop feeding the wrong info to people here. Changing the battery with the engine running is NOT the correct method. The ECU might be damaged this way.
There are ways to prevent those things you mentioned. A simple device plugged into the cigarette socket will do the job.
Edited by Fcw75
They wanted to remove the battery from my Alfa with engine running too but I stopped the worker in time. I went to talk to the boss in case he didn't know what his worker was doing, but he just gave me a WTF look and said that they have changed batteries for much more expensive cars like BMW that way, so what was the problem. [knife] Sucky attitude.
I insisted that they use jumper cables to connect a spare battery instead and they did so unhappily. Anyway I have banned this shop permanently in my books after that.
which shop?
I think you don't know how to change bty lah ! Idiot you !
I been changing for years and what ECU will damage ? ECU no current flow will memory will be gone 1st not damage ? Are you mechanic ?? Don't know shut-up lah !
Hypersonic
You are a joke. Waste my time. [rolleyes]
Brush up your english first dude.
actually, i did come across several established battery shops did the same thing right in front of my eyes as what trafficwatch said.
Hypersonic
Nothing happened everybody happy. When something happened, you see what the workshop will do. What those mechanic do at those established battery shop may not necessary be the right or recommended method. It may damaged the ECU and other sensitive items in the car. For those who want to continue letting workshop change battery this way, by all means. It's not my car anyway.
The correct method is simply to plug a device into the cigarette socket to power the car while the battery is changed. I go Leong Seng and they do that everytime.
Edited by Fcw75
When problem come they practice tai-ji! [mad]
Twincharged
you fixed at the supplier place? if not, what do you do with the old battery?
nope ... fixed at my carpark ... then the old battery sell to karanguni ... used to be $5/pc ... now drop until $3/pc only !!
without battery and running the car using the altenator directly is risky. The current produced by alternator fluctuates very much and battery is acting as a "stabiliser", although most electronic device designed for cars are suppose to accomodate with fluctuation in the power suppply, without battery, the risk of sensetive electronic device getting fried is higher.
Edited by Tigershark1976
This Automotive handy starter charging tester with row of idiots lights is much much easier to use than yr standard digital multi meter.It's just a simple go and no-go gauge - no need to remember all the mini and max voltage readings .
Edited by Yeobh
I cannot tahan when I read this kinda posts. Hey dumbo, when someone is trying to teach you something, at least be appreciative.
Changinging the batteries with engines running? You must be kidding me. It so wrong on so many aspects.
I'll just bring up one. SAFETY!!!!
As much as you possibly can aviod, you dont put you limbs into an engine bay with the engines running. Understand?
I hope nobody gets hurt or burn their pockets following your advices [laugh]
Hypersonic
I posted in another thread telling you the same thing. I repost:
Don't bother with this guy. Tell him his technique not the right method, I still kenna scolded. Screw him man! [furious]
Aiyo, how can you ask him to put his limbs into the engine bay while the engine is running?
He is already putting his whole head into the engine bay oready la. [laugh] That's why he talk no sense. Hope no one here believe what he typed.
It's good he kenna a yellow card liao...orbi good!
Edited by Fcw75
Its ok with sarcastic and funny advise given out by forumers here. [:)]
But when I read something that is dangerous and plain evil, I cannot help but think that someone might just get hurt following it. [hur]
He is putting stuff which is completely idiotically dangerous, else I just won't give a f--k.
Just a heads up.
Those who changing battery at LS, please make sure the chinaman don't change the battery with the engine running. I almost kenna, lucky I was around and told him to connect another battery as backup.
They used to plug something into the cigarette socket to power the car but they don't do so now.
I changed my battery at arrow tyres recently. The guy asked me to start my engine before he disconnect and change the old battery. I knew this was not correct and challenged him which he replied its the norm. I didn't pursued and let him do it. Understand the risk is possible shorting of wires during changing may harm the electronics. Are ther other issues?
Many shops like to do that, start the engine and change the battery.
Nothing happened everybody happy. When something happened, you see what the workshop will do. Taichi time! [rolleyes]
Anyone knows of any shop that confirm will use another battery as backup, instead of starting the engine? I will patronize the shop next time.
Anybody kena anything with the engine running before?
I also change battery at shop with engine running, at least my settings still retain...
But i didnt know can fry stuff, now read liao next time will be careful.
