Jacklim82 Neutral Newbie November 2, 2013 Share November 2, 2013 For the pass 3 week, i try to pump my tyre every 3/4 days coz i felt something wrong rite. i found out my right rear tyre will lose ard 30 to 40 psi compare to the other 3 tyre ard 20psi. Anyone have any idea what is the issue? ↡ Advertisement Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged November 2, 2013 Share November 2, 2013 Tyre valve rubber dried and cracked (the one where u pump air with the screw cap) Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 2, 2013 Share November 2, 2013 Did you check your tyre for any screw, etc? Link to post Share on other sites More sharing options...
Jacklim82 Neutral Newbie November 3, 2013 Author Share November 3, 2013 Try looking ard the tyr.. no screw If I go to tyre shop and ask them check.. will they charge me? Link to post Share on other sites More sharing options...
Yeshe Turbocharged November 3, 2013 Share November 3, 2013 For the pass 3 week, i try to pump my tyre every 3/4 days coz i felt something wrong rite. i found out my right rear tyre will lose ard 30 to 40 psi compare to the other 3 tyre ard 20psi. Anyone have any idea what is the issue? how old are the tyres already? you might not be able to find the puncture if there is one, so go to a tyre shop to get it checked even if it cost some $$$ Link to post Share on other sites More sharing options...
Evillusion Supersonic November 3, 2013 Share November 3, 2013 if no screw or nail usually is the tyre valve...my previous tyre valve was changed foc at stamford as i bought the tyres from them. I think its oni 5 bucks per valve...go check it out. My current tyre kana nail and was patched by Arrow tyres foc too as i got the tyres from them. Link to post Share on other sites More sharing options...
Jacklim82 Neutral Newbie November 3, 2013 Author Share November 3, 2013 Bought my tyre at AL tyre. Think go back to them and check Link to post Share on other sites More sharing options...
Evillusion Supersonic November 3, 2013 Share November 3, 2013 Bought my tyre at AL tyre. Think go back to them and checkbring your ori receipt just in case....some shops offer foc if oni you can produce the receipt. Never bought tyres from them before...but i bought my rims from them. Tyre became flat a day after changing rims and had to go back to them for checks foc. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 3, 2013 Share November 3, 2013 Bought my tyre at AL tyre. Think go back to them and check did they replace the valve when changing tyre most cheapo shops dont, or give u "new" valves which are actually just taken out from the prev guy before u Link to post Share on other sites More sharing options...
TVT Supercharged November 3, 2013 Share November 3, 2013 This happen to me a few months ago. One tyre needs to pump more air than the other 3....but I checked the tyre and found nothing. So went to a tyre shop and they checked carefully and found a very very small nail in it. Patch it up and now all OK. There is surely some leak somewhere, and only a expert mechanic (from the tyre shop) can detect it. If really no punture found then the next possible culprit is the air valve. Both patching or a new tyre valve is inexpensive to replace. So please go to a tyre shop and check it out. Link to post Share on other sites More sharing options...
Jacklim82 Neutral Newbie November 3, 2013 Author Share November 3, 2013 Thanks for thw advice but can only go there on weekend. I bought both rim and tyre from them so maybe can ask them replace for foc Link to post Share on other sites More sharing options...
Jacklim82 Neutral Newbie November 5, 2013 Author Share November 5, 2013 Finally find time to go AL tyre, that guy checked by submerge the wheel into a pool of water and check for bubbles... Found the culprit, is a nail. Weirdest part is why nail puncture in never leak alot?? Also did my rotation and balancing there @ $16. Link to post Share on other sites More sharing options...
TVT Supercharged November 5, 2013 Share November 5, 2013 Finally find time to go AL tyre, that guy checked by submerge the wheel into a pool of water and check for bubbles... Found the culprit, is a nail. Weirdest part is why nail puncture in never leak alot?? Also did my rotation and balancing there @ $16. Becos that nail just nice occupy almost all the space (maybe 98%) in the punture. But the reminder "2%" the nail can't cover, so the air leak from there, but not leak alot... Btw, how much they charge you for the patch? Link to post Share on other sites More sharing options...
Knoobie Supercharged November 5, 2013 Share November 5, 2013 Finally find time to go AL tyre, that guy checked by submerge the wheel into a pool of water and check for bubbles... Found the culprit, is a nail. Weirdest part is why nail puncture in never leak alot?? Also did my rotation and balancing there @ $16. coz the nail is still there prevennting many many air come out. Link to post Share on other sites More sharing options...
Jman888 Moderator November 5, 2013 Share November 5, 2013 Found the culprit, is a nail. Weirdest part is why nail puncture in never leak alot?? you can try taking it out next time Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 5, 2013 Share November 5, 2013 Try looking ard the tyr.. no screw If I go to tyre shop and ask them check.. will they charge me? No matter how, your tire has a problem n u need to get it fixed. Just let them check n solve it. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 6, 2013 Share November 6, 2013 No matter how, your tire has a problem n u need to get it fixed. Just let them check n solve it. Alamak bro, he already solved the problem. Finally find time to go AL tyre, that guy checked by submerge the wheel into a pool of water and check for bubbles... Found the culprit, is a nail. Weirdest part is why nail puncture in never leak alot?? Also did my rotation and balancing there @ $16. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 6, 2013 Share November 6, 2013 Alamak bro, he already solved the problem. Finally find time to go AL tyre, that guy checked by submerge the wheel into a pool of water and check for bubbles... Found the culprit, is a nail. Weirdest part is why nail puncture in never leak alot?? Also did my rotation and balancing there @ $16. Ya I didnt see till after I replied. Hahaha. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
