Gitanic 6th Gear June 28, 2014 Share June 28, 2014 Any hints for good fortune ? 4-D izzit ? 9235 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic June 28, 2014 Author Share June 28, 2014 Re this case, we all love cheap china products. Things you get from taoboa, aliexpress and dx. But do be careful, that cheap usually means lots of cost cutting. Especially any electrical, electronic items, that's where the danger lies. If it's plastic toys, non-consequential item if failed, it may not be as critical. I ever bought $1 cheap radio cords from Sim Lim Tower, For some reason, it found its way into a sensitive commercial area and trip a whole rack of equipment. Not that I wanted to buy that cheap cord, but there was no better one. Everyone is selling the cheapies, bcuz they think the better quality ones can't sell. So how do they cut cost on electrical items ? By using really thin copper wires, which is weak physically, and carries high resistance. Similar to those $20 jump start cables you get at petrol station. The result is that it's prone to heating up the insulation, starting a fire or getting someone electrocuted. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 28, 2014 Share June 28, 2014 SS original phone charger wire also very thin. Is it ok? Link to post Share on other sites More sharing options...
Mustank Hypersonic June 28, 2014 Share June 28, 2014 (edited) My friend tell me the copper prices rose a lot So buy extension wire better be careful Better buy those got brand one I bought 3 powerpac entension wire with built in USB charger from NTUC nex Edited June 28, 2014 by Mustank 5 Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 28, 2014 Share June 28, 2014 (edited) The pinoy chio bu don't look like pinoy. Quite Swee and it's pity. I'm expecting Jamesc to comment first but you caught me in surprise , Jamesc is ageing ? His movement is very slow now, remember to collected the $300,000.00 before he forgets took this loan from you Edited June 28, 2014 by Fongmy Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 28, 2014 Share June 28, 2014 9235 Any links with above predictions ? I thought never die means 5454 Link to post Share on other sites More sharing options...
Tigerwoods Turbocharged June 28, 2014 Share June 28, 2014 Any links with above predictions ? I thought never die means 5454 Sum up 9235 = 19 in Cantonese sounds like Sure Longevity. 1 Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 28, 2014 Share June 28, 2014 Sum up 9235 = 19 in Cantonese sounds like Sure Longevity. 19 in cantonese is "Sup-Kow" sound very indecent leh Link to post Share on other sites More sharing options...
TVT Supercharged June 28, 2014 Share June 28, 2014 The pinoy chio bu don't look like pinoy. Quite Swee and it's pity. Agreed. Just like we see many chio ones go into AV....many are swee and big (.)(.), its a pity !! 1 Link to post Share on other sites More sharing options...
Gitanic 6th Gear June 28, 2014 Share June 28, 2014 Any links with above predictions ? I thought never die means 5454 USB C : Underwear Si Bei Cheap 9 2 3 5 Link to post Share on other sites More sharing options...
Tigerwoods Turbocharged June 28, 2014 Share June 28, 2014 19 in cantonese is "Sup-Kow" sound very indecent leh Wah Lao eh... Wet ....something hahahahahaaaaYou tottemo sukebe desu Link to post Share on other sites More sharing options...
Little_prince Supersonic June 28, 2014 Share June 28, 2014 The pinoy chio bu don't look like pinoy. Quite Swee and it's pity. this type of quality can earn alot at duxton Link to post Share on other sites More sharing options...
Little_prince Supersonic June 28, 2014 Share June 28, 2014 Alot of ang mo wife also not so pretty. Many I saw the ang mo handsome but the pinoy wife look more like maid than mdm. easy score mah. for the pinoy, it's their chance for salvation, for the ang moh it's just another free fark before they go back. win-win for all. lol Link to post Share on other sites More sharing options...
Bystander50 5th Gear June 28, 2014 Share June 28, 2014 Bad QC. Afterall aftermarket products mostly are okay, but then there are some which have bad QC and we would never know. So ya, count yourself blessing. Even original products if bad QC will also suffer the same fate, just that the chances of it happening is a lot lower as those original item went through stringent check and QC, although there maybe just a tiny % that is still not check properly ( possible ) and whoever have that item, well.. count themselves bad luck.. Nowadays everything want slim and compact, the step down of voltage from 220v to 5v (USB rating) is via capacitors instead of solid transformers in the past. In the mid 90s, there were already reports of faulty capicators being manufacturered, causing many electronics stuffs and PC motherboards to fail prematurely. Even if the circuit is designed correctly, premature wearing of the capicators are enough to cause circuit failure. In the case of the news article, most likely it is not grounded properly. The laptop/PC should have it's own grounding to prevent all these. I encountered in our test lab an explosion caused by a test equipment. After investigations, the power cable similiar to ur PC cable was the culrpit. Within this cable is 3 other cables (E, N and L). Somehow the insulation between N and L degraded and caused contact between the 2 wires. The test equipment did not blow up, but there is a big bang with while sparks flying around on the cable and it was all charred. In summary, you can buy top of the range and branded devices, all it takes is something down the supply chain to be defective to cause all these problems. Link to post Share on other sites More sharing options...
Bystander50 5th Gear June 28, 2014 Share June 28, 2014 SS original phone charger wire also very thin. Is it ok? USB standard is 5V, 500mA, which is very small wattage and should be ok. Besides it is not used 24 x 7. If you leave it connected to the plug all the time without switching off, it is the plug that is bearing the full blunt of stepping down the voltage. Some bigger smartphones and tablets draw higher milli-amp from 750 to 1000. 1 Link to post Share on other sites More sharing options...
Yewheng Twincharged June 28, 2014 Share June 28, 2014 USB standard is 5V, 500mA, which is very small wattage and should be ok. Besides it is not used 24 x 7. If you leave it connected to the plug all the time without switching off, it is the plug that is bearing the full blunt of stepping down the voltage. Some bigger smartphones and tablets draw higher milli-amp from 750 to 1000. Even battery pack can catch fire lao, what is those faulty usb cable that is plugged to power plug, pc or laptop man... Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 28, 2014 Share June 28, 2014 I'm expecting Jamesc to comment first but you caught me in surprise , Jamesc is ageing ? His movement is very slow now, remember to collected the $300,000.00 before he forgets took this loan from you Haha yes Jamesc is getting old and forgetful. I have $300,000.00 loan? I must remember to pay back bro Camrytron. Now I must try to remember where I kept the money. 2 Link to post Share on other sites More sharing options...
2BDriver Hypersonic June 28, 2014 Share June 28, 2014 (edited) Haha yes Jamesc is getting old and forgetful. I have $300,000.00 loan? I must remember to pay back bro Camrytron. Now I must try to remember where I kept the money. You did posted in MCF about the $300,000.00 being safe kept with a white uniform pretty girl that serve you drinks and food everyday Edited June 28, 2014 by Fongmy ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Petrol Discounts in Singapore
Low Engine Oil Warning
Cheapest Road Tax for sub 5 second 0-100
Dirt cheap storage space.. recommendations?
Car of Politician
Car of Politician
