Philipkee Twincharged May 8, 2018 Share May 8, 2018 (edited) Mine is disabled from factory.... oh... you mean my car? It is programmed into my customized drive mode profile. I still have to toggle it to my preferred drive mode each time I start the car after 4hrs. - Sports engine/transmission - Sports steering - ASS OFF - Aircon Comfort Now is second nature... Wah piang. Your sentence"Mine is disabled from factory " Followed by "Oh.... you mean my car?" Errr obviously your car la. What else can be disabled from factory.... I try to imagine then I imagined and I say "never mind". Every time I come mcf I learn something new. Like the start stop function is like the pee system. Edited May 8, 2018 by Philipkee ↡ Advertisement Link to post Share on other sites More sharing options...
Vratenza Supersonic May 8, 2018 Share May 8, 2018 Yeah ...anything with a permanent ASS off is good..... Probably can be coded off but there is a reason why i buy from the AD instead of PI Thanks. Then my car better. Got memory function. Havent touched the button eversince I switched the ASS off. Nah.... how the pee - shiver reflex works...all part of the neural reflex system. Wah piang. Your sentence"Mine is disabled from factory "Followed by"Oh.... you mean my car?"Errr obviously your car la. What else can be disabled from factory.... I try to imagine then I imagined and I say "never mind".Every time I come mcf I learn something new.Like the start stop function is like the pee system. 1 Link to post Share on other sites More sharing options...
Mason016 Supersonic May 8, 2018 Share May 8, 2018 Mine is disabled from factory.... oh... you mean my car? It is programmed into my customized drive mode profile. I still have to toggle it to my preferred drive mode each time I start the car after 4hrs. - Sports engine/transmission - Sports steering - ASS OFF - Aircon Comfort Now is second nature... I almost read that as ABS OFF and wondered if you like to live dangerously. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 8, 2018 Share May 8, 2018 I think the authorise agent is able to off the system permanantly using their OBD diagnostic system. Those cheap OBD diagnostic tool that you can buy online probably cannot do it. Clear error codes still can do but to go further into the controls probably need the factory OBD diagnostic system. Link to post Share on other sites More sharing options...
Penknife 5th Gear May 8, 2018 Share May 8, 2018 if the ASS system is a pain in the ASS, i'd recommend u to get honda cars. only a few have the ASS system such as the HRV and jade. the rest got no ASS system, perfect for you guys here. 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 8, 2018 Share May 8, 2018 I think the authorise agent is able to off the system permanantly using their OBD diagnostic system. Those cheap OBD diagnostic tool that you can buy online probably cannot do it. Clear error codes still can do but to go further into the controls probably need the factory OBD diagnostic system. I did enquire for Mz6, apparently they are unable to turn it off at all. So its out of my list. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 8, 2018 Share May 8, 2018 (edited) I did enquire for Mz6, apparently they are unable to turn it off at all. So its out of my list. I'm not sure but I came across it on you tube. Can be off whenever driver off the switch but will reactivate when car's ignition is off and on again. https://www.youtube.com/watch?v=fMesRvQymmo To me if there's a switch to toggle it off means deep in the OBD setting it can be off permanantly. It really depends on who you talk to and whether he/she trust you for not bao tohing the individual if anything happens. Edited May 8, 2018 by Watwheels Link to post Share on other sites More sharing options...
Solar Turbocharged May 8, 2018 Share May 8, 2018 If the engine shivers so much... Would that wear out the mountings earlier? 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 8, 2018 Share May 8, 2018 If the engine shivers so much... Would that wear out the mountings earlier? Yes for my car. I'm not sure but I came across it on you tube. Can be off whenever driver off the switch but will reactivate when car's ignition is off and on again. https://www.youtube.com/watch?v=fMesRvQymmo To me if there's a switch to toggle it off means deep in the OBD setting it can be off permanantly. It really depends on who you talk to and whether he/she trust you for not bao tohing the individual if anything happens. I spoke to the SE. During test-drive, he said only way is to keep the a/c at 19 degreesC. The i-stop will not cut in. Link to post Share on other sites More sharing options...
Solar Turbocharged May 8, 2018 Share May 8, 2018 My car has this behavior.. The ASS will be disabled when the battery voltage is low Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 10, 2018 Share May 10, 2018 Mine is disabled from factory.... oh... you mean my car? It is programmed into my customized drive mode profile. I still have to toggle it to my preferred drive mode each time I start the car after 4hrs. - Sports engine/transmission - Sports steering - ASS OFF - Aircon Comfort Now is second nature... VAG cars need to VCDS it to remember the setting. The usual ones that need to do programming, for VAG cars for sharing 1. Aircon recirulating mode to off + adding menu setting 2. DRL on / off at the Menu setting 3. Hazard light on at less then 120kmh on jam brakes situation 4. tail lights on when DRL is on 1 Link to post Share on other sites More sharing options...
RadX Moderator May 10, 2018 Share May 10, 2018 My car has this behavior.. The ASS will be disabled when the battery voltage is low all ASS systems are liddat. It is able to detect the efficiency of the battery and know when to kick in Link to post Share on other sites More sharing options...
mersaylee Hypersonic May 10, 2018 Share May 10, 2018 all ASS systems are liddat. It is able to detect the efficiency of the battery and know when to kick in Kick ASS system I see... Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 10, 2018 Share May 10, 2018 My car has this behavior.. The ASS will be disabled when the battery voltage is low For Mazda,means a new Battery is needed. Link to post Share on other sites More sharing options...
Madtari 2nd Gear May 10, 2018 Share May 10, 2018 my battery management system started to give a warning on 1st Jan this year... I waited until today then go and change battery... some more I recently just came back from a long holiday, 19 days never start engine... thankfully it still can start. lol For Mazda,means a new Battery is needed. Link to post Share on other sites More sharing options...
BlueSoap 1st Gear May 10, 2018 Share May 10, 2018 IMO, start stop systems are still unrefined. Like someone here has mentioned, dealers do it just to reduce emissions. Link to post Share on other sites More sharing options...
Solar Turbocharged May 11, 2018 Share May 11, 2018 IMO, start stop systems are still unrefined. Like someone here has mentioned, dealers do it just to reduce emissions.Just like our PC when it hibernate or sleep and wakes up when u need it Link to post Share on other sites More sharing options...
Vratenza Supersonic May 11, 2018 Share May 11, 2018 But our PC don't give us a jolt in the seat of our pants when it wakes up.... Just like our PC when it hibernate or sleep and wakes up when u need it ↡ Advertisement Link to post Share on other sites More sharing options...
Discriminatory practices towards the aged
The 2017 Alfa Romeo Giulia
Man who removed bus stop bench to check its dimensions for f
To be Happy, start thinking about Death!
Stop False Accusation
Why cant i start a new tread in the General discussions?
