Eviltrap 2nd Gear November 15, 2015 Share November 15, 2015 Hi guys, just want to ask a question.I recently changed my tyres.Ordered and installed the wrong tyre profile.Supposed to be 225/45/R18But installed 225/40/R18Will there be any detrimental effects on the car, tyres, or other things? ↡ Advertisement Link to post Share on other sites More sharing options...
Yewheng Twincharged November 15, 2015 Share November 15, 2015 (edited) Hi guys, just want to ask a question. I recently changed my tyres. Ordered and installed the wrong tyre profile. Supposed to be 225/45/R18 But installed 225/40/R18 Will there be any detrimental effects on the car, tyres, or other things? There will be a speed difference, you can go Google search and there are a lot of calculator to calculate it. http://www.tyresizecalculator.com/tyre-wheel-calculators/speedo-error-calculator For worst case scenario, breaking and handling will be affected. But then most of it should be okay. On how much the changes that will affect breaking and handling, I don't know. Can also assume that changes in tyre profile, tyre pressure may need to change to accommodate it. I.e if change from higher to lower profile tyre, there is a need to pump higher pressure then what one will normally do for higher profile type. But for your case, it is just a slight difference, so don't worry too much and just take note that there is a slight error in speedo reading that's all. So when you want to speed at least you know where is the limit after factoring the speed error. Edited November 15, 2015 by Yewheng 1 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 15, 2015 Share November 15, 2015 actual veh mileage will be higher than odo means do your servicing early than 10k Link to post Share on other sites More sharing options...
Simpleonly 5th Gear November 15, 2015 Share November 15, 2015 Hi TS since taking in profile , can I tag along on this for wheel off set matching too? My current rim offset is et42. Can a rim of offset et55 fit to my car too? Pcd is the same.. thanks in advance. Link to post Share on other sites More sharing options...
Jiex 2nd Gear November 15, 2015 Share November 15, 2015 Hi TS since taking in profile , can I tag along on this for wheel off set matching too? My current rim offset is et42. Can a rim of offset et55 fit to my car too? Pcd is the same.. thanks in advance. Depends on what car. ET55 means less space between your brake calipers and the rims 1 Link to post Share on other sites More sharing options...
Simpleonly 5th Gear November 15, 2015 Share November 15, 2015 Depends on what car. ET55 means less space between your brake calipers and the rims O.. so the higher the ET, the rim will move inward? Hmm .. it this case will those wheel spacer help? Thanks! :-) Link to post Share on other sites More sharing options...
Sturtles 6th Gear November 15, 2015 Share November 15, 2015 (edited) O.. so the higher the ET, the rim will move inward? Hmm .. it this case will those wheel spacer help? Thanks! :-) For Singapore's context, where most cars are Japanese and front wheel drive, yes. To complete the real picture, you need to consider also the rim width. Edited November 15, 2015 by Sturtles Link to post Share on other sites More sharing options...
Watwheels Supersonic November 16, 2015 Share November 16, 2015 (edited) 40 vs 45 means the tire wall height is 5mm less. The overall diameter of the wheel will be 10mm smaller. The effects will be a feel of faster acceleration as the wheel is smaller. Slower if the traveling on the same speed(speedo). What is the actual factory wheel size? Ppl like to "upgrade" the rim size until they themselves get confused. If the overall diameter is +/- less dan 5% from the stock wheel size the effects are negligible. But for me personally I do not like low profile tires as they are stiff and make the ride uncomfortable, not to mention noisy. Tire walls are also stiff which compromises grip levels believe it or not as the stiff wall prevents the tires from flexing. That's why insurance companies void the claim if the car is found to be on bigger rims. But still ppl care more of aesthetics dan safety, looking good is more important. Edited November 16, 2015 by Watwheels Link to post Share on other sites More sharing options...
t0y0ta Supercharged November 16, 2015 Share November 16, 2015 40 vs 45 means the tire wall height is 5mm less. The overall diameter of the wheel will be 10mm smaller. Bro, a small correction, the "40" or "45" means the sidewall height is 40 or 45% of the tyre width, not absolute numbers in mm. Link to post Share on other sites More sharing options...
Watwheels Supersonic November 16, 2015 Share November 16, 2015 Bro, a small correction, the "40" or "45" means the sidewall height is 40 or 45% of the tyre width, not absolute numbers in mm. Thanks. The tire wall height calculation in this case is 225 x 45% vs 225 x 40% = ______ mm Link to post Share on other sites More sharing options...
Simpleonly 5th Gear November 16, 2015 Share November 16, 2015 Ok noted bro. The rim width will be the same for the new rim. Only offset different. Hmm may be just stick to old rim lol. Dun wan to get the wrong rim. Thanks again. For Singapore's context, where most cars are Japanese and front wheel drive, yes. To complete the real picture, you need to consider also the rim width. Link to post Share on other sites More sharing options...
Mason016 Supersonic November 16, 2015 Share November 16, 2015 Hi guys, just want to ask a question. I recently changed my tyres. Ordered and installed the wrong tyre profile. Supposed to be 225/45/R18 But installed 225/40/R18 Will there be any detrimental effects on the car, tyres, or other things? Your speedo will be slightly off. Ride might get harsher since you have lost some sidewall. I hope your tyres are not runflats. Link to post Share on other sites More sharing options...
Eviltrap 2nd Gear November 16, 2015 Author Share November 16, 2015 There will be a speed difference, you can go Google search and there are a lot of calculator to calculate it. http://www.tyresizecalculator.com/tyre-wheel-calculators/speedo-error-calculator For worst case scenario, breaking and handling will be affected. But then most of it should be okay. On how much the changes that will affect breaking and handling, I don't know. Screenshot_2015-11-15-20-36-40.png Can also assume that changes in tyre profile, tyre pressure may need to change to accommodate it. I.e if change from higher to lower profile tyre, there is a need to pump higher pressure then what one will normally do for higher profile type. But for your case, it is just a slight difference, so don't worry too much and just take note that there is a slight error in speedo reading that's all. So when you want to speed at least you know where is the limit after factoring the speed error. Thanks for the detailed explanation and the link! I used the link and calculated. My speed will be -3% of what the speedometer is displayed. From the day I replaced the tyres with the wrong profile, I felt nauseous when I drive. Suspecting my tyres to be overinflated, I went to check. I think it was at least 260-270! So I lowered it down to 230. Now no nauseous feeling. But is it too low now? Or should I increase it to 240? Your speedo will be slightly off. Ride might get harsher since you have lost some sidewall. I hope your tyres are not runflats. Fortunately they are not runflats. But what will happen if they are indeed runflats? I changed to Michelin PS3. Can only blame myself and trusting the internet rather than get off my lazy arse and go down to the car park to check the side of the door before ordering the tyres. Then it was only known to me when the mechanic installing the rim protectors told me the profile was wrong. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 16, 2015 Share November 16, 2015 Hi TS since taking in profile , can I tag along on this for wheel off set matching too? My current rim offset is et42. Can a rim of offset et55 fit to my car too? Pcd is the same.. thanks in advance. impossible to even go in way too much diff sure buah calliper 1 Link to post Share on other sites More sharing options...
Yewheng Twincharged November 16, 2015 Share November 16, 2015 Thanks for the detailed explanation and the link! I used the link and calculated. My speed will be -3% of what the speedometer is displayed. From the day I replaced the tyres with the wrong profile, I felt nauseous when I drive. Suspecting my tyres to be overinflated, I went to check. I think it was at least 260-270! So I lowered it down to 230. Now no nauseous feeling. But is it too low now? Or should I increase it to 240? Fortunately they are not runflats. But what will happen if they are indeed runflats? I changed to Michelin PS3. Can only blame myself and trusting the internet rather than get off my lazy arse and go down to the car park to check the side of the door before ordering the tyres. Then it was only known to me when the mechanic installing the rim protectors told me the profile was wrong. Don't worry too much, yours just a slight change. Pump tyre pressure per normal as you normally do. There are a lot of drivers also change tyre to different profile and drive as per normal and nothing happen. Link to post Share on other sites More sharing options...
nazerath Turbocharged November 16, 2015 Share November 16, 2015 Indeed your difference is really small compared to what some are doing. I would not worry bout it. 7 Link to post Share on other sites More sharing options...
Mason016 Supersonic November 16, 2015 Share November 16, 2015 Thanks for the detailed explanation and the link! I used the link and calculated. My speed will be -3% of what the speedometer is displayed. From the day I replaced the tyres with the wrong profile, I felt nauseous when I drive. Suspecting my tyres to be overinflated, I went to check. I think it was at least 260-270! So I lowered it down to 230. Now no nauseous feeling. But is it too low now? Or should I increase it to 240? Fortunately they are not runflats. But what will happen if they are indeed runflats? I changed to Michelin PS3. Can only blame myself and trusting the internet rather than get off my lazy arse and go down to the car park to check the side of the door before ordering the tyres. Then it was only known to me when the mechanic installing the rim protectors told me the profile was wrong. Runflats to me make for very uncomfortable driving. Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 16, 2015 Share November 16, 2015 Dear Eviltrap , may be you can share what car are you driving? otherwise the comment are just about effect between 40 vs 45 profile, seriously speaking there is 1 important some have overlook is the Load index (which tells you how heavy load this tyre can withstand) this particularly important on car like MPV / SUV commercial van. sourcing item over the e commercial is always carry risk like what you had experience. Get the right people do the right job you wont go wrong. regarding another issue about rim offset 42mm to 55mm I think you have to show both rim and car than you know can or not ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre puncture
Tyre puncture
Cooking Hob Query
Cooking Hob Query
Any recommended tyre shop
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
