inlinesix Hypersonic May 2, 2016 Share May 2, 2016 Golden rules on tyres: 1. Check and maintain air pressure every 15 days 2. Rotate wheels every 10k to have even wear and tear. If Front wheel drive, FL to RL, FR to RR, RL to FR and RR to FL. All wheel drive and Rear Wheel drive, FL to RR, FR to RL, RL to FL and RR to FR. 3. Change all tyres together - same brand, same profile unless you opt for staggered when any one of them with surface getting close to the wear indicator button. Safe tyres, safe roads! 1) not true bro, it depends on the drive you have How much lost before you pump air? For my car, it takes 1 month to lost 5 PSI. ↡ Advertisement Link to post Share on other sites More sharing options...
Steptronic Supercharged May 2, 2016 Share May 2, 2016 I fill up petrol almost every week. If no one, I just check my air every other time! Every 15 days too xiong... I usually check once a month together with pumping petrol, and also a few days after the car is washed so not so much brake dust Once in a month you fill up Petrol ah? wow, good mileage for you. 3 to 5 PSI every fortnight. How much lost before you pump air? For my car, it takes 1 month to lost 5 PSI. You drive through the nails kept for coffins ah? Too many sidewall punctures everytime Last mon I had a sidewall puncture . Immed changed both rear. Same type!Tyres barely 10k. Mine is rwd so more wear tear thereIf people willing to stinge on such things drive by all means but if you die, do so alone and not drag others on the road with youNuff said Link to post Share on other sites More sharing options...
Arch1984 4th Gear May 2, 2016 Share May 2, 2016 I lose 5 PSI every 3-4 months. So i pump like once every 3-4 months. Think my mileage is low and the car is light. Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 2, 2016 Share May 2, 2016 I fill up petrol almost every week. If no one, I just check my air every other time! Once in a month you fill up Petrol ah? wow, good mileage for you. 3 to 5 PSI every fortnight. You drive through the nails kept for coffins ah? Too many sidewall punctures everytime Your tyre lost air very fast le Link to post Share on other sites More sharing options...
flashbang Turbocharged May 3, 2016 Share May 3, 2016 I fill up petrol almost every week. If no one, I just check my air every other time! Once in a month you fill up Petrol ah? wow, good mileage for you. 3 to 5 PSI every fortnight. You drive through the nails kept for coffins ah? Too many sidewall punctures everytime No lah...every week fill up, but don't want to check tyres each time... plus sometimes haven't wash car then the rims very dirty haha 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 3, 2016 Share May 3, 2016 just share Michelin had tested,put 2 new one infront is Safer if your the other 2 old one is not very new. Because should you lost front grip you can easily take control of front should your back tyres lost grip , most driver will panic. anyway you own and drive your car , you always has the final say/ BUt do remember , is just advice from Tyre Company your car is in your hand , you control it and responsible for it PIRELLI : Power is nothing without control Link to post Share on other sites More sharing options...
Baal Supersonic May 3, 2016 Share May 3, 2016 So for FWD, when rear loses grip, whats to correct thing to do to manage over-steer? Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged May 3, 2016 Share May 3, 2016 So for FWD, when rear loses grip, whats to correct thing to do to manage over-steer? Never ever brake. I would just step a bit on accelerator and tad countersteer to bring it back. 6 Link to post Share on other sites More sharing options...
Baal Supersonic May 3, 2016 Share May 3, 2016 Never ever brake. I would just step a bit on accelerator and tad countersteer to bring it back. Thanks. Sounds like FWD seldom oversteer, but when it happens, its like blind feeling to realign it. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic May 3, 2016 Share May 3, 2016 Never ever brake. I would just step a bit on accelerator and tad countersteer to bring it back. Pro. 1 Link to post Share on other sites More sharing options...
Shibadog Turbocharged May 3, 2016 Share May 3, 2016 just share Michelin had tested,put 2 new one infront is Safer if your the other 2 old one is not very new. Because should you lost front grip you can easily take control of front should your back tyres lost grip , most driver will panic. anyway you own and drive your car , you always has the final say/ BUt do remember , is just advice from Tyre Company your car is in your hand , you control it and responsible for it PIRELLI : Power is nothing without control I can't understand the logic behind the recommendation; If the rear tyres are the older ones, it makes it more likely for one to lose the rear rather than the front. how did Michelin do the test? can share the link? but yeah. understeer is much easier to recover from than oversteer. Personal experience. Link to post Share on other sites More sharing options...
Mz3SP0907 3rd Gear May 3, 2016 Share May 3, 2016 Maybe Michelin don't support drifting I can't understand the logic behind the recommendation; If the rear tyres are the older ones, it makes it more likely for one to lose the rear rather than the front. how did Michelin do the test? can share the link? but yeah. understeer is much easier to recover from than oversteer. Personal experience. 1 Link to post Share on other sites More sharing options...
Baal Supersonic May 3, 2016 Share May 3, 2016 I can't understand the logic behind the recommendation; If the rear tyres are the older ones, it makes it more likely for one to lose the rear rather than the front. how did Michelin do the test? can share the link? but yeah. understeer is much easier to recover from than oversteer. Personal experience. could that be a very specific condition. Front tyres very new & rear tyres 'still new' Which is different from the more commonly seen front 'OK', rear left half life or 'time to change' marker. 1 Link to post Share on other sites More sharing options...
Shibadog Turbocharged May 3, 2016 Share May 3, 2016 could that be a very specific condition. Front tyres very new & rear tyres 'still new' Which is different from the more commonly seen front 'OK', rear left half life or 'time to change' marker. yeah I was wondering abt that, but the text says "not very new". So dunno how "new" is "not very new" LOL 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 3, 2016 Share May 3, 2016 I can't understand the logic behind the recommendation; If the rear tyres are the older ones, it makes it more likely for one to lose the rear rather than the front. how did Michelin do the test? can share the link? but yeah. understeer is much easier to recover from than oversteer. Personal experience. It make sense provided the car is FWD. Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 5, 2016 Share May 5, 2016 sorry every body for your doubt It was my stupid mistake the correct arrangement should 2 new place at Rear and 2 old one infront (may be anything less than 50%) you can easily find the video clip from youtube about the above 10000000 sorry Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic May 5, 2016 Share May 5, 2016 Yah normally new tyre at rear. Replace two min at once. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota bZ4X
2022 Toyota bZ4X
New Age Polish --> Toyota Portfolio
Michelin Primacy 5 Energy
Toyota Land Cruiser Mini
