markw12 3rd Gear May 1, 2016 Author Share May 1, 2016 i am going to change the tyres soon. since i've a pair of new bridgestones ep200, its reco to stick w the same right? so now, on your front driven axle u have one used tyre and one bald tyre? apart from the uneven grip levels, the different rolling circumferences will also play havoc with the front differential. the uneven grip (between left n right) will be especially evident when driving on wet roads, and good luck if u go over a puddle with the bald tyre. pls change asap ↡ Advertisement Link to post Share on other sites More sharing options...
Eyke Supercharged May 1, 2016 Share May 1, 2016 1. New tyres always at the back 2. Tyres on same axle always same kind, ie. front both same kind, rear both same kind 5 Link to post Share on other sites More sharing options...
Shibadog Turbocharged May 1, 2016 Share May 1, 2016 i am going to change the tyres soon. since i've a pair of new bridgestones ep200, its reco to stick w the same right? two new ep200 on the rear. what will u have in the front? the used Firestone + Nexen? Still not ideal. Link to post Share on other sites More sharing options...
Steptronic Supercharged May 1, 2016 Share May 1, 2016 Golden rules on tyres: 1. Check and maintain air pressure every 15 days 2. Rotate wheels every 10k to have even wear and tear. If Front wheel drive, FL to RL, FR to RR, RL to FR and RR to FL. All wheel drive and Rear Wheel drive, FL to RR, FR to RL, RL to FL and RR to FR. 3. Change all tyres together - same brand, same profile unless you opt for staggered when any one of them with surface getting close to the wear indicator button. Safe tyres, safe roads! 1) not true bro, it depends on the drive you have 1. New tyres always at the back2. Tyres on same axle always same kind, ie. front both same kind, rear both same kind Link to post Share on other sites More sharing options...
markw12 3rd Gear May 1, 2016 Author Share May 1, 2016 noted, thanks. i'll change all the tyres to same brand & profile asap peace. Golden rules on tyres: 1. Check and maintain air pressure every 15 days 2. Rotate wheels every 10k to have even wear and tear. If Front wheel drive, FL to RL, FR to RR, RL to FR and RR to FL. All wheel drive and Rear Wheel drive, FL to RR, FR to RL, RL to FL and RR to FR. 3. Change all tyres together - same brand, same profile unless you opt for staggered when any one of them with surface getting close to the wear indicator button. Safe tyres, safe roads! 1) not true bro, it depends on the drive you have 3 Link to post Share on other sites More sharing options...
Watwheels Supersonic May 1, 2016 Share May 1, 2016 (edited) I thought tire dealers usually have a couple of sets of used tires that are not badly worn of course. some are actually quite new and are evenly worn as a set. It's cheaper dan a new set and would last you a year. I LoL when I see that you have a mix of new and bald tires. WTF man? I dunno what you are thinking but good luck to you and if you can try not drive on the roads as you endanger other road users too. Edited May 1, 2016 by Watwheels 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged May 1, 2016 Share May 1, 2016 Front or rear wheel drive irregardless... front tyres always get worn first. This is from 1st hand experience. For TS case most of the traction and braking is provided by front wheels and will almost certainly be last change since 1 year left. Die die should be new tyres in the FRONT! 1 Link to post Share on other sites More sharing options...
Steptronic Supercharged May 1, 2016 Share May 1, 2016 Oops you are right on 1 too when changing only 2, which I am not big fan of. Apologies, I was carried away with the rotation. 1. New tyres always at the back2. Tyres on same axle always same kind, ie. front both same kind, rear both same kind First para is true. Front tyres go faster always. But with tyre rotation you can even out the wear and tear. For any reason only 2 tyres are changed, put the new ones at rear always! Front or rear wheel drive irregardless... front tyres always get worn first. This is from 1st hand experience.For TS case most of the traction and braking is provided by front wheels and will almost certainly be last change since 1 year left. Die die should be new tyres in the FRONT! 1 Link to post Share on other sites More sharing options...
Arch1984 4th Gear May 1, 2016 Share May 1, 2016 How come co-own ah? Anyway can just change the front tyres. Get 2nd hand if you want cheaper. First hand nt alot more ex also. Tyres very important and raining recently le. Drive safe. Link to post Share on other sites More sharing options...
Fitvip Supersonic May 1, 2016 Share May 1, 2016 1. New tyres always at the back 2. Tyres on same axle always same kind, ie. front both same kind, rear both same kind Agree with these two points! Link to post Share on other sites More sharing options...
RadX Moderator May 1, 2016 Share May 1, 2016 Last mon I had a sidewall puncture . Immed changed both rear. Same type! Tyres barely 10k. Mine is rwd so more wear tear there If people willing to stinge on such things drive by all means but if you die, do so alone and not drag others on the road with you Nuff said 2 Link to post Share on other sites More sharing options...
Kerwen 6th Gear May 1, 2016 Share May 1, 2016 friend if u tied on budget and car left little shelf life, just get used tyre. axio should be 15in tyre maybe u can get around 45 bucks / tyre Link to post Share on other sites More sharing options...
Eyke Supercharged May 1, 2016 Share May 1, 2016 For TS case most of the traction and braking is provided by front wheels and will almost certainly be last change since 1 year left. Die die should be new tyres in the FRONT! go do some research first b4 giving this kind of advice that might really cause pple to die Link to post Share on other sites More sharing options...
Furrynadz 5th Gear May 2, 2016 Share May 2, 2016 can post ur num plate here so we can siam far? or take 4K uhd vid when u skid n kiss something? 1 Link to post Share on other sites More sharing options...
Mz3SP0907 3rd Gear May 2, 2016 Share May 2, 2016 (edited) Bro, you were misinformed or your experience??? Front or rear wheel drive irregardless... front tyres always get worn first. This is from 1st hand experience.For TS case most of the traction and braking is provided by front wheels and will almost certainly be last change since 1 year left. Die die should be new tyres in the FRONT! Edited May 2, 2016 by Mz3SP0907 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic May 2, 2016 Share May 2, 2016 To TS To save money, u can request the tyre shop to sketch again the tyre so u can get to see the tread again. It provides good traction and as good as new. Better than staying bald. At most tyre explode but wont skid la. Ok jk, get second hnd tyre with 70-80% tread left. Nexen or goodyear or westlake is cheap. Maybe cost half as compared to $90 per piece Last mon I had a sidewall puncture . Immed changed both rear. Same type! Tyres barely 10k. Mine is rwd so more wear tear there If people willing to stinge on such things drive by all means but if you die, do so alone and not drag others on the road with you Nuff said I last month has a crack in sidewall. Then i replace all 4 tyres and rim lol Because the rim also got crack abit but i wont risk. Moreover mine on low profile 20", so replacing two tyres is akin of getting 4 new 17" tyre Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 2, 2016 Share May 2, 2016 Front or rear wheel drive irregardless... front tyres always get worn first. This is from 1st hand experience. For TS case most of the traction and braking is provided by front wheels and will almost certainly be last change since 1 year left. Die die should be new tyres in the FRONT! like many have pointed out, your assumption is wrong. my car wear faster at the rear and it is safer to have newer tyre behind too. Link to post Share on other sites More sharing options...
flashbang Turbocharged May 2, 2016 Share May 2, 2016 Golden rules on tyres: 1. Check and maintain air pressure every 15 days 2. Rotate wheels every 10k to have even wear and tear. If Front wheel drive, FL to RL, FR to RR, RL to FR and RR to FL. All wheel drive and Rear Wheel drive, FL to RR, FR to RL, RL to FL and RR to FR. 3. Change all tyres together - same brand, same profile unless you opt for staggered when any one of them with surface getting close to the wear indicator button. Safe tyres, safe roads! 1) not true bro, it depends on the drive you have Every 15 days too xiong... I usually check once a month together with pumping petrol, and also a few days after the car is washed so not so much brake dust ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota bZ4X (2026) Part 2
2022 Toyota bZ4X
2022 Toyota bZ4X
