Arogab Turbocharged May 12, 2021 Share May 12, 2021 22 hours ago, Spidey10 said: guys, is it true that normal watch shops now dun accept certain watches if we want to change batt? My tag, had it for the last 20 over years and batt is out, took it to a watch shop but they told me need to take it back to Tag AD to have the batt change.... if true, how much is a batt change at the AD? hope is not going to cost me an arm and leg... Actually really depending on what you have and what you want, button battery may cost $2 - 10 (common ones are just around $5 also depending the brands) from distributors direct to the shop. It is very very hard to find the expensive battery unless your watch use one of it which maybe extra slim or small type or uncommon size. But you really need to pay the someone who changes the battery for your watch to get some profits. Thus I believe paying 10 to 15 to the guy changing it is reasonable and depending on your relationship with the shop. Going to AD is different, first of all, they have a bigger overhead to maintain and gross margin target, they may have the options to change your rubber seal as necessary. (Ordinary shop also have seals but they may not have the right size unless they keep stocks of many different sizes imagining the market of watches). Another thing is AD does have a small chamber to test the watch on water proofing which most of the shops will not have. There is also seal at the crown as well to consider. That's why the market there for all to choose I suppose. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Spidey10 Supercharged May 12, 2021 Share May 12, 2021 2 hours ago, Arogab said: Actually really depending on what you have and what you want, button battery may cost $2 - 10 (common ones are just around $5 also depending the brands) from distributors direct to the shop. It is very very hard to find the expensive battery unless your watch use one of it which maybe extra slim or small type or uncommon size. But you really need to pay the someone who changes the battery for your watch to get some profits. Thus I believe paying 10 to 15 to the guy changing it is reasonable and depending on your relationship with the shop. Going to AD is different, first of all, they have a bigger overhead to maintain and gross margin target, they may have the options to change your rubber seal as necessary. (Ordinary shop also have seals but they may not have the right size unless they keep stocks of many different sizes imagining the market of watches). Another thing is AD does have a small chamber to test the watch on water proofing which most of the shops will not have. There is also seal at the crown as well to consider. That's why the market there for all to choose I suppose. thanks for the guidance....understood, pple have shop/overheads to pay and put meals on the table.. just that my watch have been with me for more than 20 yrs now...and it was my most expensive purchase at that time...so wanna keep it going, and the last i changed the batt was on 2015 i think and the shops says is pretty neat and clean inside, no need to do servicing at that time.... I'll try the shops around the mall 1st and if that does not work out, then will go to the AD and see if they can do anything about it....this weekend should be a good time..... just afraid going to the AD will result not just changing the batt.. Link to post Share on other sites More sharing options...
mersaylee Hypersonic May 12, 2021 Share May 12, 2021 52 minutes ago, Spidey10 said: thanks for the guidance....understood, pple have shop/overheads to pay and put meals on the table.. just that my watch have been with me for more than 20 yrs now...and it was my most expensive purchase at that time...so wanna keep it going, and the last i changed the batt was on 2015 i think and the shops says is pretty neat and clean inside, no need to do servicing at that time.... I'll try the shops around the mall 1st and if that does not work out, then will go to the AD and see if they can do anything about it....this weekend should be a good time..... just afraid going to the AD will result not just changing the batt.. Yah, the one and only time I went there for battery change they also charged me on this and that module they claimed they also looked at 😅 The reason I went there after many years of ownership was to actually get a replacement band...no more stock available for that model...then was taught to use an eraser...😁 Link to post Share on other sites More sharing options...
Spidey10 Supercharged May 12, 2021 Share May 12, 2021 19 minutes ago, mersaylee said: Yah, the one and only time I went there for battery change they also charged me on this and that module they claimed they also looked at 😅 The reason I went there after many years of ownership was to actually get a replacement band...no more stock available for that model...then was taught to use an eraser...😁 you are right on the band, changed mine as well after some years....now not original band ler….after market band now ...cannot find ori ler... anyway, just wan to keep it going for a while and have the option to wear it once a while... 1 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 12, 2021 Share May 12, 2021 Hi guys, I'm looking at Steinhart watches and thinking of getting one for myself. Any opinions that you may want to share? I have been reading up but cannot decide. Thank you. Link to post Share on other sites More sharing options...
Spidey10 Supercharged May 12, 2021 Share May 12, 2021 8 minutes ago, Count-Bracula said: Hi guys, I'm looking at Steinhart watches and thinking of getting one for myself. Any opinions that you may want to share? I have been reading up but cannot decide. Thank you. i read and saw their design are close to rolex….seems nice and stylish...but no experience on this brand and have not touch or feel how good it is ....better to go down and have a feel of it and let us know....maybe we will want to look see look see as well... like me, cannot get rolex GMT, went for tudor GMT.... 1 Link to post Share on other sites More sharing options...
209752648026519 3rd Gear May 12, 2021 Share May 12, 2021 On 5/11/2021 at 1:56 PM, Throttle2 said: Renata is the standard Swiss batt for most quartz watches including Tag Heuer, Omega etc. Etc... a good watch shop will charge $10-15 max for a batt replacement which takes only 5mins. 1. Open caseback,, 2. remove old battery 3. clean contact points 4. install new battery 5. test power 6. Close caseback. KNN, was charged $28 for changing battery for my Tag some 3 weeks ago at a watch shop in Tampines N2 Shopping Street! 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic May 12, 2021 Share May 12, 2021 I have a quartz tag bought 13 yrs ago. My first swiss watch. 5-6 yrs ago replaced the batt at tag cost ard $50 or $100 if i remember correctly now thinking to wear again. I did check some shops cant do batt replacement for tag. Anyone got shop recommendation preferably in jurong or clementi area Link to post Share on other sites More sharing options...
Spidey10 Supercharged May 12, 2021 Share May 12, 2021 3 minutes ago, Thaiyotakamli said: I have a quartz tag bought 13 yrs ago. My first swiss watch. 5-6 yrs ago replaced the batt at tag cost ard $50 or $100 if i remember correctly now thinking to wear again. I did check some shops cant do batt replacement for tag. Anyone got shop recommendation preferably in jurong or clementi area that's what i heard as well, one of the shops that i visited say must take it back to the AD.....and i lan lan went home, but didn't try other shops....i'll try a couple more and see during the long break... 1 Link to post Share on other sites More sharing options...
Spidey10 Supercharged May 12, 2021 Share May 12, 2021 20 minutes ago, 209752648026519 said: KNN, was charged $28 for changing battery for my Tag some 3 weeks ago at a watch shop in Tampines N2 Shopping Street! that's reasonable i guess....if you take it to those shops in the mall, probably will touch 40-50 bucks...and back to AD, maybe 70-80..my guess Link to post Share on other sites More sharing options...
Stratovarius Turbocharged May 12, 2021 Share May 12, 2021 1 hour ago, Count-Bracula said: Hi guys, I'm looking at Steinhart watches and thinking of getting one for myself. Any opinions that you may want to share? I have been reading up but cannot decide. Thank you. i introduce you to my fave watch guy in YT: Depends if you are into homages. They are not really fake but also not original designs. i personally would not go for any rolex homages as they are too distinctive but i think their flieger watches are not too bad. It's really up to you but there are many choices now (both big and micro) brands. For micro, Straton caught my eye for their retro style chrono. https://www.stratonwc.com/products/speciale-automatic-or-quartz-watch?variant=1589781069833 1 Link to post Share on other sites More sharing options...
Throttle2 Supersonic May 12, 2021 Share May 12, 2021 5 hours ago, Arogab said: Actually really depending on what you have and what you want, button battery may cost $2 - 10 (common ones are just around $5 also depending the brands) from distributors direct to the shop. It is very very hard to find the expensive battery unless your watch use one of it which maybe extra slim or small type or uncommon size. But you really need to pay the someone who changes the battery for your watch to get some profits. Thus I believe paying 10 to 15 to the guy changing it is reasonable and depending on your relationship with the shop. Going to AD is different, first of all, they have a bigger overhead to maintain and gross margin target, they may have the options to change your rubber seal as necessary. (Ordinary shop also have seals but they may not have the right size unless they keep stocks of many different sizes imagining the market of watches). Another thing is AD does have a small chamber to test the watch on water proofing which most of the shops will not have. There is also seal at the crown as well to consider. That's why the market there for all to choose I suppose. Stuttgart also say that when i brought my 911 there. but after a while anyone will know that they are no better. Just official thats all. muayhahaha you kena brainwash well..... 😆😄🤣 Link to post Share on other sites More sharing options...
Arogab Turbocharged May 12, 2021 Share May 12, 2021 8 minutes ago, Throttle2 said: Stuttgart also say that when i brought my 911 there. but after a while anyone will know that they are no better. Just official thats all. muayhahaha you kena brainwash well..... 😆😄🤣 Haha, Not me kena brainwash. I mentioned depends on what you want. So unless I need to check waterproof, I go to them use the chamber, they have to warranty it after that. Other than that. I got my Khatheena guy Mr Wong for my watches and a outside workshop for my car. Kekeke, be knowledgeable is better. Nevertheless I also learn a lot here Link to post Share on other sites More sharing options...
Throttle2 Supersonic May 12, 2021 Share May 12, 2021 52 minutes ago, 209752648026519 said: KNN, was charged $28 for changing battery for my Tag some 3 weeks ago at a watch shop in Tampines N2 Shopping Street! Ooops carrotted.....muayhahaha. nevermind pay some tuition fees Link to post Share on other sites More sharing options...
Arogab Turbocharged May 12, 2021 Share May 12, 2021 3 hours ago, Spidey10 said: thanks for the guidance....understood, pple have shop/overheads to pay and put meals on the table.. just that my watch have been with me for more than 20 yrs now...and it was my most expensive purchase at that time...so wanna keep it going, and the last i changed the batt was on 2015 i think and the shops says is pretty neat and clean inside, no need to do servicing at that time.... I'll try the shops around the mall 1st and if that does not work out, then will go to the AD and see if they can do anything about it....this weekend should be a good time..... just afraid going to the AD will result not just changing the batt.. Anyway this is something you wanna keep and make sure it is working and going, just like my very first watch when I first fell in love with the design till date. even for mechanical watch, it has to be serviced time and again. Maybe to far for you to go to Lavender which I always go as a friend. Get one knowledgeable shop to become your friend so you have a choice. Just also to share my first Tudor Sub from 1994, I still send in every 5 years or so for servicing even if it is working properly. Of cos I don't send to RSC as I don't wear it for swimming at all 4 Link to post Share on other sites More sharing options...
Throttle2 Supersonic May 12, 2021 Share May 12, 2021 (edited) 45 minutes ago, Arogab said: Anyway this is something you wanna keep and make sure it is working and going, just like my very first watch when I first fell in love with the design till date. even for mechanical watch, it has to be serviced time and again. Maybe to far for you to go to Lavender which I always go as a friend. Get one knowledgeable shop to become your friend so you have a choice. Just also to share my first Tudor Sub from 1994, I still send in every 5 years or so for servicing even if it is working properly. Of cos I don't send to RSC as I don't wear it for swimming at all Looks like the 36mm 75090..... Was very cheap in the past like $1k Cool watch Edited May 12, 2021 by Throttle2 Link to post Share on other sites More sharing options...
Maskedrider 4th Gear May 12, 2021 Share May 12, 2021 1 hour ago, Spidey10 said: that's reasonable i guess....if you take it to those shops in the mall, probably will touch 40-50 bucks...and back to AD, maybe 70-80..my guess you may call Mr Goh for a price before heading now, very popular watch maker https://m.facebook.com/K2-Watch-Co-182964558422077/photos/ 1 Link to post Share on other sites More sharing options...
Throttle2 Supersonic May 12, 2021 Share May 12, 2021 K2 very crowded nowadays. back when i was playing Seiko vintage more than 15 yrs ago, he was already quite popular. his sengli must be booming..... ↡ Advertisement Link to post Share on other sites More sharing options...
Movie Critic
Movie Critic
Anyone watch 綜藝玩很大?
Anyone watch 綜藝玩很大?
