Ct3833 Supersonic December 19, 2019 Share December 19, 2019 Due to continuous rain, my rolling gate finally decided to stop working on me this morning, I suspect it was water sippage through a small hole into the motor housing but I have no time to open it up this morning. Called my regular maintenance guy but he has no gate lobang, Any bro have reliable lobang to have the gate motor checked would be appreciated, while i will open up the box later to see what is wrong first. Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic December 19, 2019 Share December 19, 2019 (edited) Rolling gate? Or do you mean auto sliding gate? Did you go thru a series of steps to physically check before coming to a conclusion? For such system the cover is usually designed "upside down" such that no water will be able to seep through by gravity to so called water proof it against the elements. I suggest you do a series of physical checks before coming to a conclusion. Eg. circuit breaker(did it trip), condition of remote control batteries, any "clicking" sound from the box when you press the remote button, any debris on the rack and pinion. Or maybe you see the pinion spinning but there's no contact with the rack. These are simple checks just by using your sight and senses. Edited December 19, 2019 by Watwheels 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 19, 2019 Author Share December 19, 2019 (edited) 26 minutes ago, Watwheels said: Rolling gate? Or do you mean auto sliding gate? Did you go thru a series of steps to physically check before coming to a conclusion? For such system the cover is usually designed "upside down" such that no water will be able to seep through by gravity to so called water proof it against the elements. I suggest you do a series of physical checks before coming to a conclusion. Eg. circuit breaker(did it trip), condition of remote control batteries, any "clicking" sound from the box when you press the remote button, any debris on the rack and pinion. Or maybe you see the pinion spinning but there's no contact with the rack. These are simple checks just by using your sight and senses. Thanks for pointing that out, yes it is sliding metal gate. Breaker of the gate tripped this morning, i switched it on again this morning, no more trip but the gate stopped working. You are correct that the motor housing is upside down but there is a logo plate on top went missing, it came loosed before and I glued it back, but now the plate is nowhere found, leaving behind two little small holes there allowing water to go into the housing. Four remote controls and wired button in my house all could not get it working. I will have to open up the box and check but have no time to do it yet. No power to the pinion, nothing stuck, I unlocked the motor and was able to use hand to roll the gate this morning. Thanks again for your inputs. Edited December 19, 2019 by Ct3833 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 19, 2019 Author Share December 19, 2019 (edited) My son opened up the motor housing, there is input power at 250v, but LEDs no lights. Looks like pcb kong out, anyone has lobang? Or anyone bought from any Malaysia shops before ? Thanks. Edited December 19, 2019 by Ct3833 Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 19, 2019 Author Share December 19, 2019 Looks like the fuse on the PCB is blown. 250v 5 A. Need to hunt for it tomorrow. 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 20, 2019 Share December 20, 2019 11 hours ago, Ct3833 said: Looks like the fuse on the PCB is blown. 250v 5 A. Need to hunt for it tomorrow. super cheap fix then. had you called someone it would have been a $5 fuse and $80-$100, transport plus landed tax. 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 20, 2019 Author Share December 20, 2019 @Watwheels, @Mkl22 and @therock , thanks for your help, finally the gate is back to working condition after replacing this 50 cents fuse 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 20, 2019 Share December 20, 2019 (edited) 5 minutes ago, Ct3833 said: @Watwheels, @Mkl22 and @therock , thanks for your help, finally the gate is back to working condition after replacing this 50 cents fuse good! remember to seal up the holes. else trip again. use all weather construction silicone. i used Dow Corning 791https://www.horme.com.sg/product.aspx?id=633&gclid=EAIaIQobChMIt8Sn-9rD5gIVToePCh1mHgXHEAQYASABEgKiR_D_BwE for my mum roof. lasted 15years so far. hahaha Edited December 20, 2019 by Mkl22 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic December 20, 2019 Author Share December 20, 2019 (edited) 6 hours ago, Mkl22 said: good! remember to seal up the holes. else trip again. use all weather construction silicone. i used Dow Corning 791https://www.horme.com.sg/product.aspx?id=633&gclid=EAIaIQobChMIt8Sn-9rD5gIVToePCh1mHgXHEAQYASABEgKiR_D_BwE for my mum roof. lasted 15years so far. hahaha Thanks. Actually I do have the applicator(like an assault riffle) but the silicon tube should have been dried up by now, will go look for it. Edited December 20, 2019 by Ct3833 Link to post Share on other sites More sharing options...
Montevideo Neutral Newbie November 11, 2020 Share November 11, 2020 Bros I saw this thread and was so happy when I finally got my gate working after I replaced the blown 2.5A fuse. Then after a few tries the new 2.5A fuse blew. 😫 Is it because I should have used a 5A fuse or that there's something wrong with the PCB? Any comments will be much appreciated, thanks! 🙏 Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 11, 2020 Author Share November 11, 2020 1 hour ago, Montevideo said: Bros I saw this thread and was so happy when I finally got my gate working after I replaced the blown 2.5A fuse. Then after a few tries the new 2.5A fuse blew. 😫 Is it because I should have used a 5A fuse or that there's something wrong with the PCB? Any comments will be much appreciated, thanks! 🙏 Mine is 5A, so far has been working. To be certain, you can check the rating of your old fuse. 2.5A sounds too low, when the motor starts to move , the initial current shoud be quite high. Link to post Share on other sites More sharing options...
Montevideo Neutral Newbie November 11, 2020 Share November 11, 2020 35 minutes ago, Ct3833 said: Mine is 5A, so far has been working. To be certain, you can check the rating of your old fuse. 2.5A sounds too low, when the motor starts to move , the initial current shoud be quite high. 35 minutes ago, Ct3833 said: Mine is 5A, so far has been working. To be certain, you can check the rating of your old fuse. 2.5A sounds too low, when the motor starts to move , the initial current shoud be quite high. I put in 2.5A because the old (blown) fuse was also 2.5A.. Any way to find out if I can afford to use a fuse with a higher rating? Link to post Share on other sites More sharing options...
Twister 5th Gear November 11, 2020 Share November 11, 2020 (edited) 5 hours ago, Montevideo said: I put in 2.5A because the old (blown) fuse was also 2.5A.. Any way to find out if I can afford to use a fuse with a higher rating? You should not just upsize your fuse to higher rating just because the current rating is blown. Else it will defeat the purpose of the fuse to protect high current flow when there is a short circuit. If it is due to high initial high motor current, you may use "Slow Blow Fuse", but still using the same rating. Your old fuse may be a slow blow fuse, that is why it does not blow, but when you replaced with normal standard fuse it will blow after a few cycle of using. The filament of the Slow Blow Fuse is different, it is "thicker" at the middle. Edited November 11, 2020 by Twister 5 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic November 12, 2020 Share November 12, 2020 Learned something new today! Slow blow. Fuse! 2 Link to post Share on other sites More sharing options...
cmdsea 3rd Gear November 12, 2020 Share November 12, 2020 Agree with Twister. The fuse is there for a reason and you shouldn't just just upsize it as a fix, something on the board is failing and causing an overload. Ask yourself why 2.5A has been OK all along until now. Worst case is you risk causing a fire if you overload it. The PCB in your photo looks familiar. Is it labelled as "AC motor sliding gate controller G10".? If so you can buy it on Shopee for $67.99 and much better just to replace the whole thing... 2 Link to post Share on other sites More sharing options...
Throttle2 Supersonic November 13, 2020 Share November 13, 2020 (edited) Relate a story of recent my auto gate remote misplaced so i went to HDB hardware store to buy replacement. KNN, shop wanted $25 for a stupid plastic remote with basic circuitry. seller also proudly say he sold many already. Although this is not my technical specialty, i found it really fishy and refuse to be carroted. that evening i surfed shopee and bought same remote for $3.75 . Received within a few days and took 3 mins to calibrate the signal to match. so my friends, dont be cheated by these hardware shops. They will skin you bare and rip your throat the moment your guard is down 😅 Edited November 13, 2020 by Throttle2 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic November 13, 2020 Share November 13, 2020 8 minutes ago, Throttle2 said: Relate a story of recent my auto gate remote misplaced so i went to HDB hardware store to buy replacement. KNN, shop wanted $25 for a stupid plastic remote with basic circuitry. seller also proudly say he sold many already. Although this is not my technical specialty, i found it really fishy and refuse to be carroted. that evening i surfed shopee and bought same remote for $3.75 . Received within a few days and took 3 mins to calibrate the signal to match. so my friends, dont be cheated by these hardware shops. They will skin you bare and rip your throat the moment your guard is down 😅 This is no different from paying 1.40 for a can of soft drink at a coffee shop vs about 30 cents from value shop, or AD repair costs vs outside workshops. For those ignorant/lazy ones, they can only blame themselves to be carroted. Auto gate remote systems are the same as those in the old type car alarms. One small plastic box (with output wires to trigger the opening and closing) and a few remotes. Link to post Share on other sites More sharing options...
Throttle2 Supersonic November 13, 2020 Share November 13, 2020 26 minutes ago, Volvobrick said: This is no different from paying 1.40 for a can of soft drink at a coffee shop vs about 30 cents from value shop, or AD repair costs vs outside workshops. For those ignorant/lazy ones, they can only blame themselves to be carroted. Auto gate remote systems are the same as those in the old type car alarms. One small plastic box (with output wires to trigger the opening and closing) and a few remotes. It’s different actually. $1.40 a can of soft drink becos the coffee shop expects you to sit down and occupy space. Value shop basically just buy and go. And the monetary difference is also very great. $3.75 vs $25 almost 7x . Really cut throat man. Do honest business, cannot like that lah. If that DIY shop is very atas one located in CBD, and the staff all got solid technical knowledge, wearing uniform, can advise many things, maybe can charge $20 per remote. This is some bloody dirty diy shop located in some old hdb estate, storeman talk like ah beng, he didnt even check which mhz frequency i wanted. Cannot like this lah. No standard. no wonder Singapore lang lose out to foreigners, we got no pride in our profession. Just wanna cheat a sale here and there. Really shakehead ↡ Advertisement 1 Link to post Share on other sites More sharing options...
JB Forest City
JB Forest City
Airline starts weighing passengers at the gate
Getting City Gas Into Landed Property
Bill Gates divorced
Bill Gates divorced
Landed terrace btw Cashew and Lentor
Is it a good time to buy a landed property to stay now?
