Lala81 Hypersonic June 3, 2021 Share June 3, 2021 (edited) 13 hours ago, Mkl22 said: In truth chokes in residential units are not difficult to resolve. There is just the U bend to trap debris. Easiest way is to use a wet and dry vacuum and suck out the water in the gulley hole. Then the blockage can be seen. Or one can use the bore scope to check it out. then all is needed is dig out the debris. I have stuck my arm into the gulley hole to dig before and lucky the u bend was not too deep and managed to remove clumps of hair and solidified hair conditioner. the other way is to use those router snake and fit it to a drill if the u bend is too deep to reach his one maybe cement/sand debris leftover from renovation. That one is not easy to remove with the above. But i agree that most chokes can be removed if u know how. High pressure washer is the closest to commercial usage. Edited June 3, 2021 by Lala81 ↡ Advertisement Link to post Share on other sites More sharing options...
therock Supersonic June 3, 2021 Share June 3, 2021 Come on bros we spend 10-20 bucks on a car wash 100 bucks on car detailing or more.. pay the plumber for his days work 👍 Bro Disco is it fixed ? Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 3, 2021 Share June 3, 2021 30 minutes ago, Lala81 said: his one maybe cement/sand debris leftover from renovation. That one is not easy to remove with the above. But i agree that most chokes can be removed if u know how. High pressure washer is the closest to commercial usage. mine had some cement inside the gully hole after my reno. i sucked out the water and showed my contractor. and he hired a plumber to chisel it off bit by bit. so everyone take note to please check the gully hole after the renovation. make sure you can see the bottom of the U bend. then after that will be choke free. of course you still need to flush it time to time especially for the kitchen and not throw any oil into the sink. 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 3, 2021 Share June 3, 2021 29 minutes ago, therock said: Come on bros we spend 10-20 bucks on a car wash 100 bucks on car detailing or more.. pay the plumber for his days work 👍 Bro Disco is it fixed ? yes , but not $450! 1 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 3, 2021 Share June 3, 2021 Everything is relative I guess. When you are a high income earner, $450 is nothing. As long as you don’t get your hands dirty. For normal folks, if can DIY why not? The satisfaction is there. 7 Link to post Share on other sites More sharing options...
therock Supersonic June 3, 2021 Share June 3, 2021 👍 DIY especially when done well is great but spend when you need. Don’t begrudge the man his due when you do ask for help 2 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 3, 2021 Share June 3, 2021 18 minutes ago, Fcw75 said: Everything is relative I guess. When you are a high income earner, $450 is nothing. As long as you don’t get your hands dirty. For normal folks, if can DIY why not? The satisfaction is there. 80-200 at parlour...free at home Sextisfaction sama sama...Mustank and Angcheek say one 😁 3 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 3, 2021 Share June 3, 2021 10 hours ago, Volvobrick said: This is quite risky - someone got his arm stuck and needed SCDF to hack up the floor/pipe to free him! And you could get scratches and expose the wounds to the sai water. Proper tools are invented for a reason. I once tried to clear the choked floor trap after staying for over a decade. Couldn't clear no matter what method I knew of last time. Fed up and dipped my whole arm into the hole till almost to my bicep area...yes, I have slim arms... guess what? Grey and white cement blocks...plus other gunk...the bad smell reminded me of the BMT area cleaning day in a sewage drain just before post out. Some scratches on the fingers and arm...luckily no infection... Then fast forward another decade...had to do it again because of slow flow...used plastic glove and inserted the snake tube as far down as possible got the job done. 3 Link to post Share on other sites More sharing options...
Othello Supersonic June 3, 2021 Share June 3, 2021 Look through the charges to get an indicative pricing in order not to be ketoked. Source - East Coast Town Council https://ectc.org.sg/about-us/handyman-services/ These are the so called "perks" of staying in a HDB flat, so cannot apply to private property hor. HAHA. And also, dun take the pricing and go ask other people why cannot be the same ?? Pricing is arranged by respective TC for their constituents. Please call your own TC or go to their websites. For eg. ----> Supply and fix in replacement 6 to 32 Amp MCB (single pole) - $17.00. I can tell you, cost of MCB is $3. Means labour + transport = $10, it is impossible to get this type of pricing if one RANDOMLY calls up an electrician. Smelly smelly will be $50 up. But is $50 too much ? Not really IMO. Less than that, nobody will want to do. haha. But however, there are some freelancers out there who might be able to charge lower. But whether they can be trusted is another issue? ha. 6 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 3, 2021 Share June 3, 2021 6 minutes ago, Othello said: Look through the charges to get an indicative pricing in order not to be ketoked. Source - East Coast Town Council https://ectc.org.sg/about-us/handyman-services/ These are the so called "perks" of staying in a HDB flat, so cannot apply to private property hor. HAHA. And also, dun take the pricing and go ask other people why cannot be the same ?? Pricing is arranged by respective TC for their constituents. Please call your own TC or go to their websites. For eg. ----> Supply and fix in replacement 6 to 32 Amp MCB (single pole) - $17.00. I can tell you, cost of MCB is $3. Means labour + transport = $10, it is impossible to get this type of pricing if one RANDOMLY calls up an electrician. Smelly smelly will be $50 up. But is $50 too much ? Not really IMO. Less than that, nobody will want to do. haha. But however, there are some freelancers out there who might be able to charge lower. But whether they can be trusted is another issue? ha. some of the works are cheap enough to not bother to DIY. 😊 4 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 3, 2021 Share June 3, 2021 I rather DIY water stuff than electrical stuff. Anything wrong and one can die from electric shock. Water the most get soak wet and turn off water mains can liao. After that, call for help. 😁 1 3 Link to post Share on other sites More sharing options...
Wind30 Turbocharged June 3, 2021 Share June 3, 2021 (edited) 1 hour ago, Mkl22 said: yes , but not $450! I also think $450 is expensive… my wife say bopian and that is the plumber contact we got from my sis. Like I said, I was actually thinking of asking for recommendations here but scared kenna asked to google… If the fix last for over a year, I will recommend him here. He is not the first or second plumber we had over the years trying to fix this choke… Edited June 3, 2021 by Wind30 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 3, 2021 Share June 3, 2021 6 minutes ago, Wind30 said: I also think $450 is expensive… my wife say bopian and that is the plumber contact we got from my sis. Like I said, I was actually thinking of asking for recommendations here but scared kenna asked to google… If the fix last for over a year, I will recommend him here. He is not the first or second plumber we had over the years trying to fix this choke… if its was $450 and it fixed it, then ok. as you said previous plumbers never figured it out. but you did pay him another $450 to clear what should have been cleared the first time he came around. Link to post Share on other sites More sharing options...
13177 Hypersonic June 3, 2021 Share June 3, 2021 23 minutes ago, Fcw75 said: I rather DIY water stuff than electrical stuff. Anything wrong and one can die from electric shock. Water the most get soak wet and turn off water mains can liao. After that, call for help. 😁 At the most your house got ponding la. Lol. 1 Link to post Share on other sites More sharing options...
therock Supersonic June 3, 2021 Share June 3, 2021 A suggestion if you do want to DIY: Don't choose a weekend or Friday. Because help can be more than three days away... then you'll really be ponding.. 2 1 Link to post Share on other sites More sharing options...
Kxbc Turbocharged June 3, 2021 Share June 3, 2021 2 hours ago, Fcw75 said: Everything is relative I guess. When you are a high income earner, $450 is nothing. As long as you don’t get your hands dirty. For normal folks, if can DIY why not? The satisfaction is there. and most of the time, a lot cheaper. Choked pipes can always use wire hanger try first, or use plunger or use clear pipe choke detergent ($2 for daiso only) or use all 3. If try and really cannot, then get professional help. My DIY is more to save money, not satisfaction.😂 I never dare to DIY electrical stuff because I am those fail secondary school physics type. Sure get electrocuted if diy. 😁 Can only change light bulb and reset master fuse box only. 1 1 Link to post Share on other sites More sharing options...
therock Supersonic June 3, 2021 Share June 3, 2021 Actually I do a lot of preventive work I pour the chemical once every half year and boiling water every now and then womens hair can really jam up 1 Link to post Share on other sites More sharing options...
Jellandross Supersonic June 3, 2021 Share June 3, 2021 I needed home maintainance help and contacted this company recently. Simple inquiry on WhatsApp and they provide estimated quote based on job required. Not sure expensive or cheap but they fixed my problem first time with no fuss which is all that matters to me. Actual payment was lesser than intial quote. https://www.everyworks.com/ ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Citroen C4 1.2 Sensor & Display
Recommendation for Spectacles
Recommendation for gynaecologist
