SGCM928 4th Gear May 29, 2023 Share May 29, 2023 The upcoming national car of Singapore, brought to you by Grab, Gojek, Ryde, Tada, GetGo, Tribecar, etc. 🙃 Toyota’s prototype for the upcoming new C-HR has been spied testing ahead of an expected launch in late 2023 https://www.autodaily.com.au/2024-toyota-c-hr-spied-for-the-first-time/ Due on sale by 2024, the Mk2 C-HR will be a close sibling to the new Toyota Prius, underpinned by the same TNGA platform and offered with the same mix of parallel-hybrid and plug-in hybrid powertrains. The latter will be a variation of the Prius’s PHEV set-up, pairing a 110kW 2.0-litre four-cylinder petrol engine with a 118kW electric motor on the front axle for a combined 165kW. That’s a 30kW boost over the current (2.0-litre parallel-hybrid) C-HR. Should the C-HR also borrow the Prius’s 13.6kWh battery (a likelihood to exploit economies of scale and cut costs), an 80km electric-only range may be within reach. Alongside the technical reinvention, the C-HR will be restyled with a focus on the new-look ‘Hammerhead’ front-end design being rolled out across the line-up to give Toyota cars a common identity. Camouflage hides just how closely related to the concept the production car will be, but clearly the distinctive C-shaped headlights and wraparound rear light bar will make it through to showrooms. The C-HR may also gain a battery-electric variant, placing it directly in competition with the triple-powertrain Niro. Spy photographer claimed this test car is a pure-EV proposition, suggesting Toyota’s Small SU EV concept from 2021 – itself almost identical to the more recent C-HR concept – is nearing fruition. Toyota hasn’t confirmed whether an electric C-HR is in the works and wasn’t available to comment on these latest images, but the fundamental similarities between the C-HR’s TNGA platform and the EV-only E-TNGA architecture mean it would no doubt be a technical feasibility. An electric version of the C-HR would be positioned below a larger electric coupé-SUV, known at concept stage as the bZ Compact Crossover concept, which will itself sit underneath today’s bZ4X in an expanded Toyota SUV line-up. ↡ Advertisement 3 4 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator May 29, 2023 Share May 29, 2023 wrap until like that I stare too long i get dizzy leh. hahaha 6 Link to post Share on other sites More sharing options...
Soya Supersonic May 29, 2023 Share May 29, 2023 Can't dethrone the King PHV Slave of all time, Prius  1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 10:36 AM, kobayashiGT said: wrap until like that I stare too long i get dizzy leh. hahaha This is done intentionally to hide the contour line of the car until the actual day of release. 7 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 11:36 AM, Soya said: Can't dethrone the King PHV Slave of all time, Prius  As a 4 seaters, this car is too small with limited head and leg room. 1 Link to post Share on other sites More sharing options...
Soya Supersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 2:18 PM, Ct3833 said: As a 4 seaters, this car is too small with limited head and leg room. Sat in a PHV CH-R once Luckily onli once....  5 Link to post Share on other sites More sharing options...
Freeder Hypersonic May 29, 2023 Share May 29, 2023 (edited) Sat once .. like sitting a coffin..😅 Luckily never on those chanting music😰 Edited May 29, 2023 by Freeder 9 Link to post Share on other sites More sharing options...
Kopites Supersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 6:32 PM, yishunite said: Agreed, I thought I was sitting inside submarine... Claustrophobic feeling you meant? Link to post Share on other sites More sharing options...
Inlinefour Twincharged May 29, 2023 Share May 29, 2023 dun play play wor  many URUS chr in SG  Body kit swee swee one 🙈🙉🙊 1 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 29, 2023 Share May 29, 2023 Only sat in a chr once to the airport. I kpkb as the stupid design meant that the luggage couldn’t really fit without having the rear seat back unlatched and put in the vertical position. 1 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 7:11 PM, Mkl22 said: Only sat in a chr once to the airport. I kpkb as the stupid design meant that the luggage couldn’t really fit without having the rear seat back unlatched and put in the vertical position. The car is too small to serve real life practical usage, it is not selling for at least this reason. 4 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 7:30 PM, Ct3833 said: The car is too small to serve real life practical usage, it is not selling for at least this reason. If this is too small, jazz/swift is tiny?😂ðŸ¤ðŸ˜‚ðŸ¤ðŸ˜‚ Link to post Share on other sites More sharing options...
Carbon82 Moderator May 29, 2023 Share May 29, 2023 Clearer spy shots in the ring. Look like a crossbreed between Aqua and Yaris Cross, and wearing a pair of high heels. 9 Link to post Share on other sites More sharing options...
Brass 6th Gear May 29, 2023 Share May 29, 2023 (edited) On 5/29/2023 at 8:40 PM, Carbon82 said: Clearer spy shots in the ring. Look like a crossbreed between Aqua and Yaris Cross, and wearing a pair of high heels. Still claustrophobic rear windows but still improved over the current one. Reminds me of the side profile of the Agyo X. On 5/29/2023 at 2:54 PM, Freeder said: Sat once .. like sitting a coffin..😅 Luckily never on those chanting music😰 Maybe next time I should do PHV with a C-HR and invite @Jamesc MIL for the ride with chanting music wafting in the car. Edited May 29, 2023 by Brass On hindsight, stuff the mil into the boot 5 Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 8:45 PM, Brass said: Still claustrophobic rear windows but still improved over the current one. Reminds me of the side profile of the Agyo X. Maybe next time I should do PHV with a C-HR and invite @Jamesc MIL for the ride with chanting music wafting in the car. These cars are not for OLE ppl la Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 29, 2023 Share May 29, 2023 On 5/29/2023 at 8:45 PM, Brass said: Maybe next time I should do PHV with a C-HR and invite @Jamesc MIL for the ride with chanting music wafting in the car. Funeral chanting music please. 3 Link to post Share on other sites More sharing options...
Freeder Hypersonic May 30, 2023 Share May 30, 2023 On 5/29/2023 at 8:36 PM, inlinesix said: If this is too small, jazz/swift is tiny?😂ðŸ¤ðŸ˜‚ðŸ¤ðŸ˜‚ Bro.. pls check out Jazz/Fit .. u will be surprised… 3 1 Link to post Share on other sites More sharing options...
Heartlander Turbocharged May 30, 2023 Share May 30, 2023 On 5/29/2023 at 8:40 PM, Carbon82 said: Clearer spy shots in the ring. Look like a crossbreed between Aqua and Yaris Cross, and wearing a pair of high heels. Coming with a normal rear door! ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
BYD Sealion 6 DM-i
BYD Sealion 6 DM-i
Any recommended workshop with reasonable labour charges?
