Ct3833 Supersonic April 29, 2024 Share April 29, 2024 (edited) LTA seeks ideas to remove burnt electric buses from multi-storey bus depots https://www.straitstimes.com/singapore/transport/lta-seeks-ideas-to-remove-burnt-electric-buses-from-multi-storey-bus-depots LTA is looking for ways to quickly remove a burnt one from a multi-storey depot and submerge it into a water tank to prevent a fire from reigniting. .....Lithium-ion, which is the most prevalent battery technology used to power electric vehicles (EVs), burns at around 2,760 deg C – hot enough to melt steel and concrete..... . Edited April 29, 2024 by Ct3833 ↡ Advertisement 1 1 2 Link to post Share on other sites More sharing options...
Beanoyip Turbocharged April 29, 2024 Share April 29, 2024 Let it burn, convert heat energy to charge other buses. Then take a dyson and clean it up afterwards. 6 Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 29, 2024 Share April 29, 2024 ASS for advice wor...😂 So good hor...paid handsome no need to tink one...if I try that at work...sure kena left right centre top down cris cross diagonal strikes until orh mak kark blue black all over...😅 2 Link to post Share on other sites More sharing options...
Windwaver Turbocharged April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:09 AM, Ct3833 said: LTA seeks ideas to remove burnt electric buses from multi-storey bus depots https://www.straitstimes.com/singapore/transport/lta-seeks-ideas-to-remove-burnt-electric-buses-from-multi-storey-bus-depots LTA is looking for ways to quickly remove a burnt one from a multi-storey depot and submerge it into a water tank to prevent a fire from reigniting. .....Lithium-ion, which is the most prevalent battery technology used to power electric vehicles (EVs), burns at around 2,760 deg C – hot enough to melt steel and concrete..... . “Even when the e-bus fire is extinguished, there remains a possibility of reignition, which could be a result of sparks created by parts of the burnt bus being in contact with the ground or depot structures during the removal process,” the LTA said on its Land Transport Innovation Portal, describing the challenge. Aiya, ask SCDF to shit shift the bus for them la 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 29, 2024 Author Share April 29, 2024 On 4/29/2024 at 8:22 AM, Beanoyip said: Let it burn, convert heat energy to charge other buses. Then take a dyson and clean it up afterwards. The concern is the high burning temperature may cause damage to a building or even cause it to collapse. .....Lithium-ion, which is the most prevalent battery technology used to power electric vehicles (EVs), burns at around 2,760 deg C – hot enough to melt steel and concrete 1 Link to post Share on other sites More sharing options...
Beregond Supersonic April 29, 2024 Share April 29, 2024 At least they are now looking for solutions before the problem come. 2 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:22 AM, Beanoyip said: Let it burn, convert heat energy to charge other buses. Then take a dyson and clean it up afterwards. Then the dieson catches fire...😅 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:42 AM, Beregond said: At least they are now looking for solutions before the problem come. Problem exists...how to remove...😂 Link to post Share on other sites More sharing options...
Beregond Supersonic April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:43 AM, mersaylee said: Problem exists...how to remove...😂 No la. I mean if now suddenly 1 bus burn and it spread to the whole roll. They gonna get wack jialat jialat. At least now they thinking ahead. See what they come out with Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 29, 2024 Share April 29, 2024 Why is model Y battery so much cheaper than a model 3? I know it's older but got so much difference? 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:45 AM, Beregond said: No la. I mean if now suddenly 1 bus burn and it spread to the whole roll. They gonna get wack jialat jialat. At least now they thinking ahead. See what they come out with The secret in the secret ingredient soup is.........nothing 😁 Link to post Share on other sites More sharing options...
Kxbc Turbocharged April 29, 2024 Share April 29, 2024 errrr......they already knew long ago that they will have electric buses in their fleet. but they proceeded with the multi storey depot build without a safety plan in place or at least start the process??? Now then ask for ideas when the depot structures are built and unlikely to be able to change? hmmmmm.......like that also can. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:52 AM, Kxbc said: errrr......they already knew long ago that they will have electric buses in their fleet. but they proceeded with the multi storey depot build without a safety plan in place or at least start the process??? Now then ask for ideas when the depot structures are built and unlikely to be able to change? hmmmmm.......like that also can. SG can don't have multi storey meh. Lol no luxury of not having multi storey. 1 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:50 AM, Lala81 said: Why is model Y battery so much cheaper than a model 3? I know it's older but got so much difference? Most of Tesla 3 & Y built outside of USA could be using CATL battery Link to post Share on other sites More sharing options...
Ct3833 Supersonic April 29, 2024 Author Share April 29, 2024 (edited) Private EV is not a concrern because their batteries are smaller ? Why would only bus have this problem ? Edited April 29, 2024 by Ct3833 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator April 29, 2024 Share April 29, 2024 My suggestion is to build a fire station near a bus depot. Multi storey depot and battery fire where it can melt concrete doesn't sound very promising leh. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic April 29, 2024 Share April 29, 2024 On 4/29/2024 at 8:50 AM, mersaylee said: The secret in the secret ingredient soup is.........nothing 😁 Got la. I seen some similar towing on video before. Just need some customise. Can picture a tow truck pulling a low level floor lift. That got 4 extension on 4 corner. Push in under the bus. The extension come out and lift up. And the tow truck immediately pull to a safe area. With training can be done very fast. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged April 29, 2024 Share April 29, 2024 On 4/29/2024 at 9:47 AM, Beregond said: Got la. I seen some similar towing on video before. Just need some customise. Can picture a tow truck pulling a low level floor lift. That got 4 extension on 4 corner. Push in under the bus. The extension come out and lift up. And the tow truck immediately pull to a safe area. With training can be done very fast. Lithium ion battery fire comes very fast and spontaneous. Even like 30secs the fire can easily spread to neighbouring buses unless they are parked far away from one another. But this doesn't work for depot. The same exact problem will apply to private ev in mscp. This is why I don't agree on the current ev technology to be rolled out to the masses. ↡ Advertisement Link to post Share on other sites More sharing options...
China bans uncertified power banks on domestic flights starting Jun 28 (2025) over fire risk
LTA - how to improve roads ah?
Tuk-tuks at Lim Chu Kang cemetery: LTA says vehicles seized for investigation
1 child dead, 18 injured after fire breaks out at River Valley Road shophouse
3 years lock in period for vehicles registered from Feb 19 as business-owned private-hire cars, says LTA
LTA buys electric buses from China
