Phluvcat 6th Gear November 8, 2014 Share November 8, 2014 Anyone got good reliable mechanic to recommend please PM me thanks. Ever since my radiator burst few months back, been having all sorts of problems. I have since done the following: top overhaul changed TPS few times (error few times point to that), coolant temp sensor, map sensor, dunno what other sensor change clutch pad change starter change fuel pump knock convertor change distributor etc, etc... Generally is the lack of power, the choking feeling when you wanna load the engine. Past weeks experience erratic throttle response, step a bit no response step harder suddenly snap back, this continues until check light comes on. Numerous times check light come on and high fuel consumption (and generally still lack power) Down to past few days, still lack power, temp gauge stay almost at C. Went to mech this morning, now temp gauge shows normal reading but lack of power especially and throttling not equivalent to speed change especially under load such as uphill. Step harder speed barely increase. Engine sounds really muted but when free clutch throttle sound ok. In between all these went mech a lot of times to troubleshoot. Now just wanna second opinion or I just scrap the bloody car, no longer a joy driving, its not even moving people A to B, its like I am moving the car from A to B instead, like everyday nursing an old man and dunno when he will die. Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Kezg1 5th Gear November 8, 2014 Share November 8, 2014 Anyone got good reliable mechanic to recommend please PM me thanks. Ever since my radiator burst few months back, been having all sorts of problems. I have since done the following: top overhaul changed TPS few times (error few times point to that), coolant temp sensor, map sensor, dunno what other sensor change clutch pad change starter change fuel pump knock convertor change distributor etc, etc... Generally is the lack of power, the choking feeling when you wanna load the engine. Past weeks experience erratic throttle response, step a bit no response step harder suddenly snap back, this continues until check light comes on. Numerous times check light come on and high fuel consumption (and generally still lack power) Down to past few days, still lack power, temp gauge stay almost at C. Went to mech this morning, now temp gauge shows normal reading but lack of power especially and throttling not equivalent to speed change especially under load such as uphill. Step harder speed barely increase. Engine sounds really muted but when free clutch throttle sound ok. In between all these went mech a lot of times to troubleshoot. Now just wanna second opinion or I just scrap the bloody car, no longer a joy driving, its not even moving people A to B, its like I am moving the car from A to B instead, like everyday nursing an old man and dunno when he will die. Thanks in advance. ...Hmm..change car..imo Link to post Share on other sites More sharing options...
Phluvcat 6th Gear November 8, 2014 Author Share November 8, 2014 ...Hmm..change car..imo first...got gum zeng with the car...not easy to let go...served me well all these years. second...actually intended to renew COE, until all these issues suddenly just cropped up, wanna save it if possible. finally, if scrap I will probably use BMW (bus, MRT, walk). at the moment, the likelihood will be BMW...hahaha Link to post Share on other sites More sharing options...
Fuelsaver Supercharged November 12, 2014 Share November 12, 2014 Sry to hear that, but u Mind if I ask, how did radiator burst? No previous signs of leakage, mild overheating before coming to this? I've no very fantastic mech to rec though. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged November 12, 2014 Share November 12, 2014 Btw, I suspect ur ride is in limp mode, hence no power when accel. Ecu need reprogram? Link to post Share on other sites More sharing options...
Bairen 1st Gear November 12, 2014 Share November 12, 2014 i think my usual place i go to is good. rapid auto.. at ubi there... only bad thing i can think of is my working hours dont match his... Link to post Share on other sites More sharing options...
TameDriver Twincharged November 12, 2014 Share November 12, 2014 Did your mechanic check the Tensioner Belt? I no expert but had mine changed recently as advised by mechanic. Link to post Share on other sites More sharing options...
GLZT 6th Gear November 12, 2014 Share November 12, 2014 Sry to hear that, but u Mind if I ask, how did radiator burst? No previous signs of leakage, mild overheating before coming to this? I've no very fantastic mech to rec though. Yeah, how radiator burst? The water pump too strong then cause over pressure? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged November 12, 2014 Share November 12, 2014 http://www.ehow.com/how-does_4586360_what-causes-radiator-burst.html Head gasket can be suspect also if engine loses power - http://www.ehow.com/how_4495762_tell-blown-head-gasket.html Link to post Share on other sites More sharing options...
Fuelsaver Supercharged November 12, 2014 Share November 12, 2014 Did your mechanic check the Tensioner Belt? I no expert but had mine changed recently as advised by mechanic.Possible also - http://www.ehow.com/how_4809431_tell-timing-belt-tensioner-bad.htmlPerhaps u can refer to those links n check the symptoms accordingly to zoom in to the issue. Link to post Share on other sites More sharing options...
Windkel20 3rd Gear November 13, 2014 Share November 13, 2014 Eh bro if you stay in the east can try Kaizen Autowerkz at Bartley biz center, kaki bukit there...very experienced and professional crew...so far the best I've encountered, even better than AD...hope that helps....car got issue very disturbing one....cannot slp well at night...for me lah...lol Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 13, 2014 Share November 13, 2014 I would suggest BMW. That would help ease congestion for the rest of us. Link to post Share on other sites More sharing options...
Little_prince Supersonic November 13, 2014 Share November 13, 2014 Anyone got good reliable mechanic to recommend please PM me thanks. Ever since my radiator burst few months back, been having all sorts of problems. I have since done the following: top overhaul changed TPS few times (error few times point to that), coolant temp sensor, map sensor, dunno what other sensor change clutch pad change starter change fuel pump knock convertor change distributor etc, etc... Generally is the lack of power, the choking feeling when you wanna load the engine. Past weeks experience erratic throttle response, step a bit no response step harder suddenly snap back, this continues until check light comes on. Numerous times check light come on and high fuel consumption (and generally still lack power) Down to past few days, still lack power, temp gauge stay almost at C. Went to mech this morning, now temp gauge shows normal reading but lack of power especially and throttling not equivalent to speed change especially under load such as uphill. Step harder speed barely increase. Engine sounds really muted but when free clutch throttle sound ok. In between all these went mech a lot of times to troubleshoot. Now just wanna second opinion or I just scrap the bloody car, no longer a joy driving, its not even moving people A to B, its like I am moving the car from A to B instead, like everyday nursing an old man and dunno when he will die. Thanks in advance. what brand? conti or jap? maybe you need to find a specalist workshop? Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 13, 2014 Share November 13, 2014 And I almost forgot one less bidder for COE can only help bring the price down for the rest of us. All bros and sis that think TS should BWM please let him or her know. Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 13, 2014 Share November 13, 2014 If TS really wants to repair I can PM him my WS. My mechanic promised to charge him extra and pass me the difference. Link to post Share on other sites More sharing options...
Othello Supersonic November 13, 2014 Share November 13, 2014 go back to your AD, ask them to diagnose and quote. Then do outside. When it comes to diagnosis, most ADs are generally very competent. Link to post Share on other sites More sharing options...
Meanmachine 6th Gear November 13, 2014 Share November 13, 2014 There is NO such thing as good or bad mechanic, only cheap & reasonable one, those who charge cheap and reasonable hardly sustain business flow, those who charge ex are only optimising their overhead and labour, Go Johore, I know one Old mechanic runs with his Son, only labour so cheap tt I faint, ( Unbelievably RM20.00/ ) for EO & filter change. Hahaha !! Link to post Share on other sites More sharing options...
Jamesc Hypersonic November 13, 2014 Share November 13, 2014 There is NO such thing as good or bad mechanic, only cheap & reasonable one, those who charge cheap and reasonable hardly sustain business flow, those who charge ex are only optimising their overhead and labour, Go Johore, I know one Old mechanic runs with his Son, only labour so cheap tt I faint, ( Unbelievably RM20.00/ ) for EO & filter change. Hahaha !! RM20 for EO and fliter change? Thats expensive, I only pay RM13 and thats high to me cos I used to only pay RM10. ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
