Vinceng Turbocharged March 25, 2020 Share March 25, 2020 (edited) 21 minutes ago, Fcw75 said: Yep I saw API SL. But my car is 12.5 years old...hahaha. But I don’t think it’s manufactured in 2018. From the right hand bottom at the back, the DOM seems to be 011219. I stand corrected though. The date of manufacturer is at the base of the bottle - 0518 Edited March 25, 2020 by Vinceng ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 25, 2020 Share March 25, 2020 1 hour ago, Vinceng said: The date of manufacturer is at the base of the bottle - 0518 Did you have the same thing? The base of the bottle that I bought don’t have leh? Link to post Share on other sites More sharing options...
boonhat_91 6th Gear March 26, 2020 Share March 26, 2020 lazada bday sale ongoing, not sure if any good deals. Previously always let AD change my engine oil, last servicing I noticed they charged $23.50/L, so here I am venturing into cheaper engine oils.. a few noob qns: 1) recommended is 5w30 but can I use 0w30 or 10w30? Singapore has no winter so I imagine the W-rating means next to nothing in Sg context. 2) my ride is 1.2NA note, so it's as b&b as it gets. Quite heavy footed and mileage is 16-17k km/yr. Should I be too concerned about what brand of engine oil I use? Or even say Mobil 1 5w30 got a few different 'flavours' to choose from? Link to post Share on other sites More sharing options...
Adrianli Hypersonic March 27, 2020 Share March 27, 2020 (edited) 1 hour ago, boonhat_91 said: lazada bday sale ongoing, not sure if any good deals. Previously always let AD change my engine oil, last servicing I noticed they charged $23.50/L, so here I am venturing into cheaper engine oils.. a few noob qns: 1) recommended is 5w30 but can I use 0w30 or 10w30? Singapore has no winter so I imagine the W-rating means next to nothing in Sg context. 2) my ride is 1.2NA note, so it's as b&b as it gets. Quite heavy footed and mileage is 16-17k km/yr. Should I be too concerned about what brand of engine oil I use? Or even say Mobil 1 5w30 got a few different 'flavours' to choose from? Should not be a problem at all whichever mix you use as long as w30. Brand of engine oil is more about the various additives in the oil but for budget conscious, any brand as long as cheap and reputable, it is ok. Edited March 27, 2020 by Adrianli 4 Link to post Share on other sites More sharing options...
inlinesix Hypersonic March 27, 2020 Share March 27, 2020 4 hours ago, boonhat_91 said: lazada bday sale ongoing, not sure if any good deals. Previously always let AD change my engine oil, last servicing I noticed they charged $23.50/L, so here I am venturing into cheaper engine oils.. a few noob qns: 1) recommended is 5w30 but can I use 0w30 or 10w30? Singapore has no winter so I imagine the W-rating means next to nothing in Sg context. 2) my ride is 1.2NA note, so it's as b&b as it gets. Quite heavy footed and mileage is 16-17k km/yr. Should I be too concerned about what brand of engine oil I use? Or even say Mobil 1 5w30 got a few different 'flavours' to choose from? I would recommend you to use 5-20wt. That's what likely what is recommended in owner manual. Link to post Share on other sites More sharing options...
boonhat_91 6th Gear March 27, 2020 Share March 27, 2020 1 hour ago, inlinesix said: I would recommend you to use 5-20wt. That's what likely what is recommended in owner manual. You are right, Found a copy of the manual online.. Wonder why AD used 5w30 then? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 27, 2020 Share March 27, 2020 Many workshop don’t use 20 weight oil, even 30 weight oil also rare. They like to use 40 weight oil which to me is too thick. 2 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear March 30, 2020 Share March 30, 2020 Ended up buying a few Mobil 1 for a little under 15 bucks/qt. Not the best deal I guess but I hope to do better next time. How to see what's the mfg date? Is it 02/2017? Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear March 31, 2020 Share March 31, 2020 I think we need to create a new thread called "Come on in if you are into atas engine oils..." Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged March 31, 2020 Share March 31, 2020 11 hours ago, boonhat_91 said: Ended up buying a few Mobil 1 for a little under 15 bucks/qt. Not the best deal I guess but I hope to do better next time. How to see what's the mfg date? Is it 02/2017? How much from where Link to post Share on other sites More sharing options...
boonhat_91 6th Gear March 31, 2020 Share March 31, 2020 35 minutes ago, Wildfaye29 said: How much from where From lazada, the shop is call Provec listed at $14.21 per quart, for me about $14.77 per quart after factor in delivery charges. Link to post Share on other sites More sharing options...
Vinceng Turbocharged March 31, 2020 Share March 31, 2020 Engine oil with '40' viscosity is recommended for Singapore's hot weather. Offers better protection against wear and tear. https://www.quora.com/If-I-replace-10W30-engine-oil-to-10W40-is-it-safe-for-the-engine Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 31, 2020 Share March 31, 2020 The temperature only 34 degrees. The engine already more than 34 degrees. So what does hot weather have anything to do with engine oil viscosity? Buy according to engine oil specifications not the weather in Singapore. 3 Link to post Share on other sites More sharing options...
CatBoy Neutral Newbie April 3, 2020 Share April 3, 2020 Missed the $24.90 SHU at Giant... Link to post Share on other sites More sharing options...
justahumanbeing Neutral Newbie April 9, 2020 Share April 9, 2020 On 3/15/2020 at 3:00 PM, Albeniz said: If you buy the engine oil cheap at Giant, which workshop do you visit to do the change? Looking for workshops in Bukit Batok area who is happy to do the job. Labour now rages between $20 to $30 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 9, 2020 Share April 9, 2020 $20? Where to find? Intro please. 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 10, 2020 Share April 10, 2020 15 hours ago, Fcw75 said: $20? Where to find? Intro please. her referring labour charge in jb la after conversion is $20.😂 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 10, 2020 Share April 10, 2020 Just now, StreamRSZ said: her referring labour charge in jb la after conversion is $20.😂 Can’t even go in till god know when. ↡ Advertisement Link to post Share on other sites More sharing options...
Petrol Discounts in Singapore
Car of Politician
Car of Politician
Aquatic Plants - Anyone into it as well?
