Kurty Supercharged October 18, 2010 Share October 18, 2010 hi, would like to share my last saturday encounter with this plug. item bought at August at autoba%#. driving along jalan besar, the wiring beginning to burn. lucky i quick pulled it out and run out of car in the middle of the road only using it to connect my car recorder during the incident... more details will be shared tomorrow. (i actually wrote to autoba%$ complaining about their product and services) ↡ Advertisement Link to post Share on other sites More sharing options...
Zuoom 1st Gear October 18, 2010 Share October 18, 2010 what's the voltage draw on the car recorder? Link to post Share on other sites More sharing options...
Kurty Supercharged October 18, 2010 Author Share October 18, 2010 12V Link to post Share on other sites More sharing options...
Blackyv Turbocharged October 18, 2010 Share October 18, 2010 can show a bigger picture of the brand or logo of it?.. Link to post Share on other sites More sharing options...
Caravan 5th Gear October 18, 2010 Share October 18, 2010 This looks like those cheap chinese made adapter from dx. To think I just ordered some. Link to post Share on other sites More sharing options...
Palmer 1st Gear October 18, 2010 Share October 18, 2010 Check the current rating of your car recorder and any other stuff that was connected to the plug. If its still within the plug's rating, you have a case. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear October 18, 2010 Share October 18, 2010 There should be a fuse at the tip of the (black/red) plug!! I am surprised that it can burn up the wire until like that. Really scary...lucky for you it did not create anything worst. Link to post Share on other sites More sharing options...
Vid Hypersonic October 18, 2010 Share October 18, 2010 Autoba%# is an importer. they do not QC all the things in their store. Even if u complaint, at most they will do is replace or refund. Link to post Share on other sites More sharing options...
So_nice 6th Gear October 18, 2010 Share October 18, 2010 wtf. tats scary. nw u make me wonder if similar products are safe to use Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 18, 2010 Share October 18, 2010 hi, would like to share my last saturday encounter with this plug. item bought at August at autoba%#. driving along jalan besar, the wiring beginning to burn. lucky i quick pulled it out and run out of car in the middle of the road only using it to connect my car recorder during the incident... more details will be shared tomorrow. (i actually wrote to autoba%$ complaining about their product and services) It appears that the wires are undersized for the current drawn. Unlikely there is a fuse within the plug that can break the overloaded circuit. Hmm... layman bought from another layman some unsuitable product? Link to post Share on other sites More sharing options...
Kurty Supercharged October 19, 2010 Author Share October 19, 2010 Hi, I Link to post Share on other sites More sharing options...
Kurty Supercharged October 19, 2010 Author Share October 19, 2010 can show a bigger picture of the brand or logo of it?.. no brand but i remember it only reflect like socket extension, 12 V with USB. comes in black or white. still selling widely and in autobacs.. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 19, 2010 Share October 19, 2010 Max amp draw for cigarette light plug is 10amp. Most of the well designed cigarette lighter plug has a fuse built -in that comes into contact with the hot wire. From the photos is appears that the high heat starts from the multi outlet socket and travel towards the plug. There must be a short circuit in the multi outlet wiring. If there is overloading ,the high heat cause by high amp drawn will melt the plug first. Link to post Share on other sites More sharing options...
Ender Hypersonic October 19, 2010 Share October 19, 2010 Did you check anything wrong with your recorder? A possible scenario is your recorder is drawing a current, probably a faulty capacitor.. The 1st extension may be using a high current fuse (not surprising if it's mad in china), thus allow high current to past. the 2nd extension likely has the normal fuse rating, and got burnt off.... Link to post Share on other sites More sharing options...
Kb27 Supersonic October 19, 2010 Share October 19, 2010 These kind of cheapo extension usually has very thin wires and for usage of total less than 1 amp. Your car recorder sucks more than 1A and overheats the wiring. GPS will also suck more than 1A. The worse thing is that it may be fused but they put a 5A fuse inside which wouldn't blow until the wire insulation burnt and catch fire. Same thing will happen for those who mod their electrical at workshops without consideration for the wiring ratings, like those who go for 100W white light or extra powerful foglight. The wire insulation melt before the fuse does. That's how many cars catch fire. Link to post Share on other sites More sharing options...
Kurty Supercharged October 19, 2010 Author Share October 19, 2010 i did check on my recorder, even after the incident, i sent car for wire inspection at some audio shop. everything was fine, fuse was inspect and replace if required.. thinking of it, i was pretty shocked too. though i'm not a technical person, i believe such device should come with a breaker or fuse for safety in such event.. thank God i was in car.. otherwise... Link to post Share on other sites More sharing options...
Kb27 Supersonic October 19, 2010 Share October 19, 2010 The problem is that the fuse is overrated for the thin wire that they supply. It's the undersized wiring problem. Link to post Share on other sites More sharing options...
Majordan 2nd Gear October 19, 2010 Share October 19, 2010 man, that looks like some 12 yr old school science project! ↡ Advertisement Link to post Share on other sites More sharing options...
Old WW2 Relic disposals
Tool to change Spark Plug
How are you using the SkillsFuture?
Using blower to dry car
2021 3rd Generation Nissan Note (E13)
Those how have FAT belly please read this
Budget 2022 to air on Feb 18
