SimonTan 2nd Gear June 4, 2012 Share June 4, 2012 I thought 10 years ago, all HDB die die must change stainless steel screws. Many even kena summoned for not changing in time. So by right all new HDB n condos should be using stainless steels screw by now. How the 85% slipped thru inspections? AsiaOne Monday, Jun 04, 2012 More than 70 per cent of all fallen windows incidents are due to poor window maintenance, and at least 85 per cent of casement windows fell as a result of failing to retrofit the windows with stainless steel rivets. These were the findings of the Building and Construction Authority (BCA) and Housing & Development Board (HDB). In a joint statement, the two governmental bodies advised homeowners to check and maintain their windows once every six months, and repairing them if necessary, to minimise incidents of fallen windows. According to BCA, there were 35 cases of fallen windows from January to May this year, compared to the 20 cases during the same period in 2011 and 2010. All windows are subjected to wear and tear and may detach and fall when window parts become loose or defective. To counter this problem, homeowners are advised to follow three simple steps: For casment windows, they should 1) check that the fasteners are not rusty or loose 2) clean and lubricate joints or movable parts 3) change all rivets from aluminium to stainless steel For sliding windows, homeowners should 1) check that the safety stoppers and/or angle strips are in place or not damaged 2) clean the tracks and ensure the window panels can slide smoothly 3) change worn-out safety stoppers and angle strips BCA and HDB have also been stepping up efforts to create greater awareness of the importance of window safety. Besides the biannual Window Safety Campaign on June 6 and December 12, BCA and HDB are also reaching out to educate the community through roving exhibitions on windows safety. To further encourage residents to check and maintain their windows, toolkits for window maintenance are also given out during the exhibitions. BCA will also be carrying out windows inspections at both private and HDB estates to reinforce the importance of regular window maintenance. Under the law, homeowners or tenants could face a fine of up to $10,000 and/or receive a jail term of up to one year if a window falls due to lack of maintenance. In addition, if any fallen casement window is found with aluminium rivets, they can also face a further penalty of a $5,000 fine and/or jail term of up to six months, for failing to retrofit the window with stainless steel rivets. A list of BCA-approved window contractors and window maintenance tips can be found at http://www.bca.gov.sg/windows_safety and http://www.hdb.gov.sg/windows_safety. [email protected] ↡ Advertisement Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear June 4, 2012 Share June 4, 2012 I thought 10 years ago, all HDB die die must change stainless steel screws. Many even kena summoned for not changing in time. So by right all new HDB n condos should be using stainless steels screw by now. How the 85% slipped thru inspections? AsiaOne Monday, Jun 04, 2012 More than 70 per cent of all fallen windows incidents are due to poor window maintenance, and at least 85 per cent of casement windows fell as a result of failing to retrofit the windows with stainless steel rivets. These were the findings of the Building and Construction Authority (BCA) and Housing & Development Board (HDB). In a joint statement, the two governmental bodies advised homeowners to check and maintain their windows once every six months, and repairing them if necessary, to minimise incidents of fallen windows. According to BCA, there were 35 cases of fallen windows from January to May this year, compared to the 20 cases during the same period in 2011 and 2010. All windows are subjected to wear and tear and may detach and fall when window parts become loose or defective. To counter this problem, homeowners are advised to follow three simple steps: For casment windows, they should 1) check that the fasteners are not rusty or loose 2) clean and lubricate joints or movable parts 3) change all rivets from aluminium to stainless steel For sliding windows, homeowners should 1) check that the safety stoppers and/or angle strips are in place or not damaged 2) clean the tracks and ensure the window panels can slide smoothly 3) change worn-out safety stoppers and angle strips BCA and HDB have also been stepping up efforts to create greater awareness of the importance of window safety. Besides the biannual Window Safety Campaign on June 6 and December 12, BCA and HDB are also reaching out to educate the community through roving exhibitions on windows safety. To further encourage residents to check and maintain their windows, toolkits for window maintenance are also given out during the exhibitions. BCA will also be carrying out windows inspections at both private and HDB estates to reinforce the importance of regular window maintenance. Under the law, homeowners or tenants could face a fine of up to $10,000 and/or receive a jail term of up to one year if a window falls due to lack of maintenance. In addition, if any fallen casement window is found with aluminium rivets, they can also face a further penalty of a $5,000 fine and/or jail term of up to six months, for failing to retrofit the window with stainless steel rivets. A list of BCA-approved window contractors and window maintenance tips can be found at http://www.bca.gov.sg/windows_safety and http://www.hdb.gov.sg/windows_safety. [email protected] You may be aware that those windows are of unsuitable design. But most of them are like that: designed to fail/fall-off Link to post Share on other sites More sharing options...
Albeniz Turbocharged June 4, 2012 Share June 4, 2012 Nowadays, newer HDB flats are 40-50 storey high, can't imagine if the windows start falling. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear June 4, 2012 Share June 4, 2012 what was the old materials? aluminium? Link to post Share on other sites More sharing options...
Camrysfa Turbocharged June 18, 2015 Share June 18, 2015 Toughest bamboo pole . . . where to buy? http://singaporeseen.stomp.com.sg/singaporeseen/this-urban-jungle/bamboo-pole-pierces-through-cars-moonroof-in-amk-carpark a bamboo pole pierced through the moonroof a car at Ang Mo Kio Avenue 4 today (June 18) at around 10.30am. Link to post Share on other sites More sharing options...
Fett 2nd Gear June 19, 2015 Share June 19, 2015 Wah shit, this could have gone wrong in many other ways. and thats a brand new Lexus NX, so heart pain Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 19, 2015 Share June 19, 2015 Toughest bamboo pole . . . where to buy? http://singaporeseen.stomp.com.sg/singaporeseen/this-urban-jungle/bamboo-pole-pierces-through-cars-moonroof-in-amk-carpark a bamboo pole pierced through the moonroof a car at Ang Mo Kio Avenue 4 today (June 18) at around 10.30am. Will police do swipe for finger print on the bamboo pole & look for the culprit? Link to post Share on other sites More sharing options...
CarPark8 3rd Gear June 19, 2015 Share June 19, 2015 WOW this bamboo pole, gives the word POKING a whole new meaning. Respect bamboo pole. Link to post Share on other sites More sharing options...
Matrixx 3rd Gear June 19, 2015 Share June 19, 2015 Could that be the Lexus NX's radio antenna? Link to post Share on other sites More sharing options...
Count-Bracula Twincharged June 19, 2015 Share June 19, 2015 Someone's remote control car? Link to post Share on other sites More sharing options...
Mockngbrd Supersonic June 19, 2015 Share June 19, 2015 got falling bra and panty? 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 19, 2015 Share June 19, 2015 going to be costly repair..... Link to post Share on other sites More sharing options...
Pocus Turbocharged June 19, 2015 Share June 19, 2015 got falling bra and panty? Someone found this. You want? Link to post Share on other sites More sharing options...
Mockngbrd Supersonic June 19, 2015 Share June 19, 2015 Got like this one? Link to post Share on other sites More sharing options...
Nzy Twincharged June 19, 2015 Share June 19, 2015 Toughest bamboo pole . . . where to buy? http://singaporeseen.stomp.com.sg/singaporeseen/this-urban-jungle/bamboo-pole-pierces-through-cars-moonroof-in-amk-carpark a bamboo pole pierced through the moonroof a car at Ang Mo Kio Avenue 4 today (June 18) at around 10.30am. The bamboo pole tough or the glass easily broken? Link to post Share on other sites More sharing options...
Blackyv Turbocharged June 19, 2015 Share June 19, 2015 The bamboo pole tough or the glass easily broken? what car is that huh?? looks nice but cant figured it out.... Link to post Share on other sites More sharing options...
Camrysfa Turbocharged June 19, 2015 Share June 19, 2015 (edited) The bamboo pole tough or the glass easily broken? Bamboo poles don't shatter , sunroofs do, haha http://www.thisismoney.co.uk/money/cars/article-2552135/Our-Kia-Sportage-panoramic-sunroof-imploded-two-years-ownership.html Edited June 19, 2015 by Camrysfa Link to post Share on other sites More sharing options...
Beaver 2nd Gear July 9, 2015 Share July 9, 2015 Hi Folks, Anyone can recommend a HDB approved window contractor ? One of my window I think the arm is half broken liao....but I think it is also about time to change all the casement window to sliding window to play safe. Flat is almost 20 years. 10 years ago we changed all the screws as required by HDB new ruling. Think we should change the window now... Hope someone here know some honest contractor that will not cut our throat. TIA !! Regards ↡ Advertisement Link to post Share on other sites More sharing options...
News for racism and Racial Discrimination
Near Misses and Other Misc News
News: Singapore most influential family
A Idiom a day, Motoring Edition
2026 Corolla Concept WAH JIN SWEE LEH! Best since AE86 GT-Apex
windows tinting...
windows tinting...
BREAKING: Senior Minister Tharman Shanmugaratnam announces intention to run for Singapore's presidency.
