Do NOT engine flush
Mllcg
https://www.google.com.sg/amp/blog.amsoil.com/is-an-engine-flush-good-or-bad/amp/
Always look at both sides of the argument...
Maybe the conclusion in this article is engine flush only for regular upkeep of engine but not for very old engines with old seals?
Hard to conclude either way, but maybe reduce frequency of doing it as well?
the author of that article is the technical writer of a company that sells an engine and transmission flush.  :D
if engine flush is required, it would be included in the car manual. for regular upkeep of engine, using a good quality engine oil and filter with regular OCI would suffice. for neglected engines, a safer approach would be a shortened OCI.
  • Praise 5
Twincharged
They actually say the flush is not required... if you use their products.
Haha...
I have owned more than 10 cars and kept most to 10 years. I have never done engine flush and never had any engine failure (other than a painful skipped timing belt years ago).
I can't say for cars older than 10 year old, but I would say engine flush is BS for cars with normal mileage (<250K km).  In fact I usually won't bother to change the engine oil in the last 1.5 years before COE expiry! [laugh]
  • Praise 6
Why Nissan cars don't need to change spark plug ourselves?
You should always change the spark plug yourself unless you drive a Nissan.
When you put the spark plug in you will do it gently and not just force it in and damage
the thread. Then if you love your car you will not over tighten and if you really
love your car you will use the torque wrench. Most mechanics are not exactly
university trained engineers and most learn from monkey see monkey do.
I had my radiator flushed and after the whole process the reservior tank still has the old
green coolant after they put in the new pink coolant. This is how much they know.
Trust them? if they were really experts they wouldn't be working changing oil and tyre etc.
:D
Hypersonic
Some models the spark plug is very hard to get at
and need to remove some parts blocking it. Might be
easier to let the professionals do it unless very adventurous.  [thumbsup]
:D
  • Praise 5
10 units X 10 years =  :o  Smelly Smelly 100 years old  :a-fun:   What a healthy Singaporean  :a-m1212:
  • Praise 3
I don't buy them at year zero lah!
and it's >10 plus some while stationed overseas too.
[wave]  Sorry, my poor maths [thumbsdown]  failed badly   :secret-laugh:
  • Praise 6
Over inflate is better than under inflate especially in high speed driving.
quite disturbing to read comments that seems to advocate higher pressure is bad and dangerous for high speed driving.
  • Praise 3
Depends if it is spec'ed in the tyre placard.
me too
I am a believer in engine flushing ...... for others.
Engine flush is like colon cleansing....
Some advocate it and do it once a year, some just let nature takes it own course!
err....this thread is on engine flushing leh.  :D
but i definitely agree with you on this air pressure issue. an under-inflated tyre causes the sidewall to flex a lot more when driving. the increased friction causes the tyre to overheat, which could potentially result in a premature blowout.
for sustained high speed driving, all tyres should be slightly over-inflated.
